  • July 22, 2025, 01:28:58 PM
Author Topic: P-51, swept forward X-plane?  (Read 1497 times)
  • Gravitywell
« on: April 25, 2011, 07:48:28 PM »
I came across this rubber powered scale plan by Pres Bruining and was hopeing I could get some info on the plane.  Was it a design concept only, or was one built?  Did it fly?  Anything would be appreciated.  Thanks H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
  • Gravitywell
Re: P-51, swept forward X-plane?
« Reply #2 on: April 25, 2011, 08:45:59 PM »
Thanks for the info.  By the way.....google may be your friend, but whenever I try to find something I come up with everything but what I'm looking for! LOL H^^
Glenn Reach
Westlock, Alberta
« Reply #3 on: April 25, 2011, 08:47:16 PM »
I don't know about the real one, but I'll guarantee the model flew, and very well.
  • Gravitywell
« Reply #4 on: April 25, 2011, 09:34:16 PM »
Pres did design some beauties didn't he? H^^
Glenn Reach
Westlock, Alberta
Offline Larry Renger
« Reply #5 on: April 26, 2011, 12:09:15 PM »
Forward sweep works well at subsonic speeds for a variety of reasons:
Tip stall is gone so you can drive the wing really hard in corners
For a flying wing, the cg is forward of the wing root so that there is room for tank and engine (or battery!)
The wing lifts like a high aspect ratio one, but has pitch dampening like a very low aspect ratio.  Thus, no bobble in hard corners.
With the forward sweep, the elevator has a good tail length to generate turning force with little drag penalty or disturbance to the root wing lift.
It looks WICKED in the air!
I am nearly ready to publish this baby, the Sky Streak.
Flying Models wants it.  Part sets will be available from rsmdistribution.
250 sq.in.  Weighs 6.7 ounces finished.  Flies like a dream (no not a nightmare!)
Further comments on this model will be found in the 1/2A section, I shall not divert this interesting thread further.  I MAY still have a photo of a factory display model of the FSW P-51. I'll look for it and post it if available.
« Last Edit: April 26, 2011, 07:20:08 PM by Larry Renger »
