  • July 10, 2025, 08:50:50 PM
Author Topic: Bearcat at Huntersville  (Read 1374 times)
« on: October 08, 2015, 05:59:26 PM »
I got to finally fly the new Pat Johnston Bearcat at the Huntersville field with Don Jenkins today. Plane flew fine but seemed to turn to quick for me. A heaver muffler will go on it for next flight. Some calm weather and some quite windy and it did fine in both. Plane weights 49-50 ounces so it is very light. The line pull surprised me for such a light plane. It flies straight ahead not aimed out at all.
« Last Edit: October 09, 2015, 03:59:14 PM by EddyR »
Offline Gene Martine
  • Started flying 1952 (AMA 2903)
Re: Bearcat at Huntersville
« Reply #1 on: October 08, 2015, 06:21:12 PM »
 y1 y1 y1 y1 y1 y1 y1
 Can't wait to see it next week.
Gene
Online wwwarbird
« Reply #2 on: October 08, 2015, 07:22:03 PM »
 Looks great!
 If I remember correctly, Brodak kit with an LA.46?
Online Matt Colan
« Reply #3 on: October 08, 2015, 09:36:32 PM »
Looks awesome Ed!! Looking forward to seeing it next week!
« Reply #4 on: October 08, 2015, 09:58:35 PM »
Stunning .  ;D With the big fuse. theres a bit of windage or airflow there compared to most . The Fuse gets to be a bigger % of the aerodynamic forces than usual . Hence the GB's knife edge capeability , even though its ROUND . Maybe Al will do a F2B GB ?  :! VD~
« Reply #5 on: October 08, 2015, 10:01:39 PM »
I got to finally fly the new Pat Johnston Bearcat at the field with Don Jenkins today. Plane flew fine but seemed to turn to quick for me.
have you considered narrowing your handle spacing as opposed to altering the CG,, Assuming you have it balanced on the design CG?
Nice finished weight,, Pat would be proud of it for sure!
What kind of lap times are you turning?
« Reply #6 on: October 09, 2015, 06:04:17 AM »
 With only two flights on it I can't answer many questions. I am not going to tighten handle any more than it is. I narrower it between flights. I tend to fly all my planes with a much farther back CG than most people. It may be to far back. Controls are very slow setup. Speed was fast as motor increased RPM at takeoff both flight. Very odd for a ST/46. The plane would fly easily with my Rustler/40 but it a lighter motor. I will check the CG today.
 It is very flyable as is if I did nothing.
Offline Steve Fitton
« Reply #7 on: October 09, 2015, 11:55:36 AM »
Looks great Eddy!  Looking forward to seeing it in person  :)!
Offline Will Davis
« Reply #8 on: October 09, 2015, 01:57:52 PM »
Very nice  scale paint scheme, Good weight and one of your great running ST 46 ... Can't wait to see it fly.
Will Davis
"Carolina Gang"
