  • July 01, 2025, 09:06:33 PM
Author Topic: bearcat 55 inch u-contrlol kit  (Read 1721 times)
Offline Jeffrey Soule
« on: September 06, 2013, 01:00:51 PM »
YES IM BYING A BEARCAT 55 INCH WING U-CONTROL KIT. BUT HAVE SOME QUESTIONS...WHAT TYPE OF COWL DOES IT HAVE ? WOOD PLASTIC FIBERGLASS????
IS THE FUSELAGE SHEET COVERED OR MONOKOTE??IS THE TAIL BUILT UP OR SHEET ??  ....ANYTHING OUT OF THE ORDERNARY I NEED TO KNOW??
                                                 THANK YOU!!!!!!!!!!!!!!!!!
Offline Dan Bregar
  • Field Marshall
Re: bearcat 55 inch u-contrlol kit
« Reply #1 on: September 06, 2013, 01:26:15 PM »
Jeffrey
It would be helpful to know what kit you are talking about ?
AMA 33676
Offline Dick Pacini
« Reply #2 on: September 06, 2013, 01:40:18 PM »
Sounds like the Brodak  #CLB-30 kit.  I have one NIB but am too lazy to go downstairs and drag it out.
If indeed it is the Brodak kit, give them a call or send an email.  They are very helpful.
AMA 62221
Re: bearcat 55 inch u-contrlol kit BRODACK SKU# CLB30
« Reply #3 on: September 06, 2013, 01:42:31 PM »
YES ITS A BRODACK KIT SKU NO#CLB30  THANK YOU
« Reply #4 on: September 06, 2013, 02:11:00 PM »
If it's the 55" wing kit, I suspect it's designed by Pat Johnston. You can email Pat to ask any questions you have.
« Reply #5 on: September 06, 2013, 02:53:34 PM »
Cowl is part of body,wood. Body is sheeting. Tail is built up and sheeted. Not a good plane for a fist time stunt plane. Usa at least a .46 in it H^^
Offline RC Storick
« Reply #6 on: September 06, 2013, 03:10:23 PM »
I talked to him and it's not his first plane.
« Reply #7 on: September 06, 2013, 03:34:11 PM »
YOU WHERE GREAT THANK YOU SO MUCH
Offline Dick Pacini
« Reply #8 on: September 06, 2013, 04:31:26 PM »
Is your Caps Lock stuck?
AMA 62221
Offline Douglas Ames
« Reply #9 on: September 10, 2013, 05:24:50 PM »
Quit YELLING!! Posting is caps. is the equivalent.
Get your powerplant sorted out first before you start - Electric or IC (Internal Combustion)?
Two different setups with regard to mounts and tank/ batteries.
AMA 656546
