  • July 23, 2025, 09:03:46 AM
Author Topic: battery question  (Read 2755 times)
battery question
« on: May 07, 2009, 12:11:15 PM »
OK, for you electrical genius types (I freely admit I know nothing).
Is there such a thing as a non-rechargeable (as in alkaline or similar - Duracell/Energizer) sub-"C" battery? All I can find in this size are ni-cads and NMiH types.
Offline phil myers
Re: battery question
« Reply #1 on: May 07, 2009, 01:48:47 PM »
Hi Randy, I'm no expert either but just had a look on www.duracelldirect.co.uk and they have the 'c' type alkaline batteries (code MN1400) you're after. Hope this helps.
Phil
« Reply #2 on: May 07, 2009, 02:20:16 PM »
Phil,
Yea, they are standard "C" sized. These are sub-"C". They are smaller than "C" cells. Used in glow plug igniters. I just found it strange that you can get them in ni-cad and NMiH and other rechargeable forms, but not as a regular use once and dump type of battery. Just make it easier to have a couple around when you're rechargeable type dies and you don't have a charger with you.
Offline Larrys4227
« Reply #3 on: May 07, 2009, 02:50:17 PM »
I've got so many NiCad cells around from making my own 6-pack sticks, that I used to carry charged extras in my box, just in case of moments when you find yourself with a dead one. Even if its been sitting around for awhile, there was always enough charge to get a few flights. I now use a SuperShot 5000mh igniter .... charge it at the most once a month. That thing is great!
FlySafe!  Larry (Larrys4227)
« Reply #4 on: May 07, 2009, 03:04:03 PM »
Randy,
If you just go ahead and convert to electric power you wont have to worry about those battery problems,,
well ok so THAT battery problem anyway S?P
« Reply #5 on: May 07, 2009, 03:46:36 PM »
Now you know why one of my ni-cad head lock battery is in the woods up in Iowa.  I use a pit box with power panel and 12  volt battery.  Oh I still one ni-cad in the box.  DOC Holliday
posthole_digger
« Reply #6 on: May 07, 2009, 04:41:34 PM »
Gee, Doc. We recycle batteries differently in the rest of the country!
Offline James C. Johnson
« Reply #7 on: May 07, 2009, 10:39:35 PM »
I use the sub C ignitors but I also make a battery pack out of 4 D cells.. it lasts a long time and never needs "recharging" .. plus I feel it gives the plug a little more fire than 1.2v..   1.5v. I still will use one but it sucks when they die. Maybe a solar charger is the answer..
Jim
Offline Scott B. Riese
  • Just a student of stunt
« Reply #8 on: May 08, 2009, 12:22:28 AM »
15 Propel Sub C 4500mAh 10C - 20C NiMH Battery with Tab
0 Bids:$34.35Time left:13h 18m
DHA BAY
Scott Riese
Portland, Oregon
AMA 528301
Offline Peter Ferguson
« Reply #9 on: May 08, 2009, 11:30:01 AM »
Randy I think the answer is no. I looked a few years ago when I had one of that type.
 Radio Shack makes some single C or D size holders that allow easy alkaline cell replacement. I used two glued together and wired in parallel for a reserve pack . It lasts a full season easily with 2 cells and isn't as cumbersome and heavy as soldering together 4 cells.
Peter Ferguson
Auburn, WA
« Reply #10 on: May 08, 2009, 01:40:21 PM »
Pete,
As you know, I use a flight box with power panel and 12V battery. Problem is, on those cold days we fly, we often have to flip the plane over to start and my lead wire isn't nearly long enough to reach from the panel to the plug. So have a small igniter is often the best thing. It was just curiosity. I thought either I was looking in the wrong place for the battery, or one wasn't made. And if that is the case, I just thought it was kinda weird that a sub-"C" would be available in one and not in the other type.
Offline Steve Scott
« Reply #11 on: May 08, 2009, 05:05:27 PM »
Use the one I do - Duratrax makes a empty glo ignitor - just put in your own standard "C" or "D" 1.5v alkaline cell.
I believe Tower (or someone) makes one for AA 1.5v alkaline cells.
« Last Edit: May 08, 2009, 07:16:24 PM by Steve Scott »
Offline Patrick Rowan
« Reply #12 on: May 08, 2009, 10:43:30 PM »
I use the Tower empty igniters with C alkalines.
Fly Stunt
75750
Poland, Ohio
Offline George
  • Love people, Use things.
« Reply #13 on: May 09, 2009, 08:54:45 AM »
For those using "C" size NiCd cells, check the capacity when replacing them. Some C's are actually sub-C cells with spacers so they will fit in C applications.
George
George Bain
AMA 23454
Offline Garf
    • Hangar Flying
« Reply #14 on: May 09, 2009, 11:25:48 AM »
The same with the supposed D cells.
