  • July 17, 2025, 08:19:20 AM
Author Topic: gremel scroll saw  (Read 1845 times)
Offline Bootlegger
gremel scroll saw
« on: December 20, 2012, 12:42:04 PM »
 Went to the dremel web site looking for scroll saw blades, didn't see any, anybody got some suggestions?
          Thanks, and Merry CHRISTmas,,,
8th Air Force Veteran
Gil Causey
AMA# 6964
  • Gravitywell
Re: gremel scroll saw
« Reply #1 on: December 20, 2012, 12:53:03 PM »
When I had my old saw....now gone to a better place....it had the type of blades that were flat and held in with a pinch block.  I could only buy the type that had the little pins, so I just took a hammer and knocked them out.  They came out easy as pie.  Maybe this helps? H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
« Reply #2 on: December 20, 2012, 01:44:30 PM »
Brother Gil,
You *might* find blades that will work at Lowes.  I do not have a Dremel, but did find *generic* blades that work perfect.  Mine needed to be smooth on the ends with out pins.
BIG Bear
RNMM/AMM
  • Gravitywell
« Reply #3 on: December 20, 2012, 02:09:17 PM »
I forgot to mention....the blades I bought were also too long, so I just snapped them off at the length I needed them and they worked fine.  Lot cheaper than the actual Dremel blades too. H^^
Glenn Reach
Westlock, Alberta
Offline Bootlegger
« Reply #4 on: December 20, 2012, 03:10:05 PM »
  Guy's thanks a lot, but this "blind hog found an acorn", Dremel has some and set me two pkgs.
  Sure do thank all y'all for the help...
Gil Causey
AMA# 6964
« Reply #5 on: December 20, 2012, 03:49:18 PM »
 If they're the short 3" or whatever with the pins on each end like mine uses, the actual Dremel brand is all I've ever found.
Offline Bootlegger
« Reply #6 on: December 20, 2012, 06:19:29 PM »
 Wayne, that is almost an exact replica of the one that I have, it is probably 35-40 yrs old, and still works.
Gil Causey
AMA# 6964
Offline Norm Furutani
« Reply #7 on: December 20, 2012, 07:16:48 PM »
Just to be sure, you guys know there is a feature on that saw allowing you to raise the table so you're moving to a fresh/sharp part of the blade?
Just checking!
- Norm
Offline Mike Keville
« Reply #8 on: December 20, 2012, 07:20:33 PM »
They're available at Ace Hardware.
« Reply #9 on: December 20, 2012, 07:37:34 PM »
They're also available at Woodcrafters!
Randy C.
« Reply #10 on: December 20, 2012, 08:08:57 PM »
 Mine's got a LOT of miles on it and still runs like new. ;D
Offline Garf
    • Hangar Flying
« Reply #11 on: December 20, 2012, 09:12:47 PM »
I got mine from Sears.
« Reply #12 on: December 21, 2012, 09:37:40 AM »
I've had to rebuild mine a couple of times.   And Ace Hardware is where I get my blades.
  • Gravitywell
« Reply #13 on: December 21, 2012, 10:41:00 AM »
Mine was one of the old pressed steel ones and vibrated itself to peices in about a year....so much for $11 bucks! LOL
Glenn Reach
Westlock, Alberta
