  • August 05, 2025, 04:40:19 AM
Author Topic: Glow Plug for COX .049 Head  (Read 1897 times)
Offline Mike Griffin
« on: February 22, 2022, 05:01:35 PM »
I have come by some COX engines that have a head adapter with a glow plug that replaces the standard COX head.  I have some Thunderbolt RC long plugs.  Will that fit and work or what do I need to buy something else for plugs for those engines.
Thank you
Offline Dan Berry
Re: Glow Plug for COX .049 Head
« Reply #1 on: February 22, 2022, 05:27:04 PM »
You'll need to pull the adapter to see if you want a long or short plug.
Generally there is a power loss with these units. If you're not flying speed or duration Free Flight you won't notice the power loss.
« Reply #2 on: February 22, 2022, 05:51:39 PM »
Hi Dan,
I am just flying for fun Dan and just getting back into free flight.  Does the adapter accept a long or short plug or just a short one?
Thank you
Offline Dan Berry
« Reply #3 on: February 22, 2022, 06:05:38 PM »
Hi Dan,
Thank you
SWeveral adapters are out there. I've never used one. ZPull the head and screw in a plug. You want the plug to be relatively flush to the top of the combustion chamber.
« Reply #4 on: February 22, 2022, 07:58:06 PM »
Is there a Nelson plug adapter of Cox .049'S?
Offline Carl Cisneros
« Reply #5 on: February 22, 2022, 08:19:52 PM »
if they re still in stock, then, yes there is a Nelson adapter for the Cox.
Carl
https://kamtechnik.com/product/ktk-21/
Carl R Cisneros, Dist IV
Control Line RB
Offline kenneth cook
« Reply #6 on: February 23, 2022, 06:17:44 AM »
              Mike, Mecoa made a long and short adapter. The red anodized one was for long and the purple was for shorts. There was also Charlie's adapters that appeared to look like a modified burnt out Cox plug which was mill finish and really no flats to tighten it up. They used long plugs. For the most part if the long plug is protruding too far into the combustion chamber, it's incorrect. The above adapters rob rpm's considerably and I've tried to use them only to relinquish them to the shelf. The adapters you would want would be a Nelson adapter or a Turbo plug adapter which is available through the Kamtechnik link I posted and some have already mentioned it.
             If they can be sourced, Merlin made a 4 part kit for 1/2A. The package came with 3 head buttons and a clamp ring. This setup required many head gaskets as it really bumped up the compression which can cause issues if not adjusted. The Nelson and Turbo head can and will do the same so you certainly will require head gaskets. Head gaskets are available through many and the problem is that none are the same in terms of thickness. You could possibly require 8 vs 4 due to the thickness.
Offline John Lindberg
« Reply #7 on: February 23, 2022, 06:39:45 AM »
Here's a source for replacement heads:http://www.the-printer.net/DookCat.html Here's another one:http://www.flyfreeflight.com/Site/Modified_Glow_Heads.html
« Reply #8 on: February 23, 2022, 06:48:04 AM »
Here's one:http://www.flyfreeflight.com/Site/Modified_Glow_Heads.html
Offline bob whitney
« Reply #9 on: February 23, 2022, 10:39:37 PM »
Glo Bee made and sold a glo plug and adapter for the cox'a they were as good or better than the stock plugs ,i could let go for about $5 ea plus shipping
rad racer
« Reply #10 on: February 23, 2022, 10:46:02 PM »
Sending you a PM Bob
Offline Paul Wescott
« Reply #11 on: February 23, 2022, 11:15:48 PM »
Nope.  Bob Mattes only has adapters listed for .09’s and .15’s and he has dropped the .020 dangit!
PW
« Reply #12 on: February 24, 2022, 06:45:44 AM »
I have one head (.049) that was drilled out and tapped for a short glow plug. It works fine, I'm just a sport flier.
Offline bob whitney
« Reply #13 on: February 24, 2022, 09:46:32 AM »
check classified
rad racer
« Reply #14 on: February 24, 2022, 11:34:23 AM »
check classified
Bob just sent you a PM on the sport plugs.
