I beleive zero degree or maybe 1 to 2 degree positive trike gear. Neutral elevator and let it climb on it's own. Negative degree or down elevator will cause the plane to jump into the air after attaining air speed.
Mr. Holiday, IMO you are 101% CORRECT. Airplanes are airplanes regardless of the control method. Nose down on the takeoff roll will cause the wing to glue itself to the runway. (Lift vector becomes down-hold vector) Once enough speed is attained for the pilot to start lifting the nose, then the wing transitions from negative lift to positive lift
and then there is a sudden jump into the air. This - for several reasons - can create a less than neat take-off. As one that has taught many newbies in the RC world, that is one of the biggest detriments to the newbie with little or no aeronautical experience.
In the multitude of RC Trainers, most of the L-Gear wires are soft. After a few bumps the model sets nose high. The newbie will then try to take-off, the nose-high machine will then jump into the air prior to being ready to fly and SNAP over into the ground. GROUND ALWAYS WINS!
I have no idea how many times I have grabbed a landing gear and bent it back to set their model straight. So, no nose down and very little up on a trike gear system, especially with a symmetrical airfoil along with flaps opposite to elevator.
The same applies to a CL Stunter. Very slight positive attitude is overcome since the flaps will be slightly up if pilot applies light down elevator. This prevents premature take-off and allows the model to fly off when such down elevator transitions to neutral or light up. Those flaps can assist to make neat take-offs, but the transition is sudden, therefore as You, John, state 1-2 degrees positive is the way to go.
Way back when I was an active CL Stunt person, I flew a Nobler converted to Trike gear. Good Old (late) George was judge at several. He had a hard time with anyone that made any change to his "Nobler". Some Fun!
