  • June 27, 2025, 03:43:07 AM
Author Topic: Rebuilding my Sig Twister  (Read 789 times)
Offline Andrew Saunders
  • 2013 Nats
« on: February 24, 2014, 04:55:42 PM »
Have finally found time and materials to start rebuilding the sig twister that Arlie Prezler helped me build. I was able to save the wing  as it survived the crash. Everything else had to be replaced. Surprisingly, the wing is straighter now then before it crashed. Heres the latest pics.
Re: Rebuilding my Sig Twister
« Reply #1 on: February 25, 2014, 08:42:22 AM »
Looking good, now to go over doing it like some I know.   It is a design to get you in the air and flying.   Keep it straight and light.
« Reply #2 on: February 25, 2014, 08:51:02 AM »
Hi Andrew,
Looking good!  I know it will make you happy to get it back in the air.
I had the opposite problem with the Zero prototype I built for John Brodak.  The fuselage was fine but the outboard wing was destroyed.  Had to build another wing!  I would have rather it been the fuselage!
Good Luck!
BIG Bear
RNMM/AMM
