The term "global warming" is now "climate change" in order to better explain every weather abnormality, no matter what the season of the year is, or what the abnormality is.
It's only "climate change" when it is abnormally hot, if it is abnormally cold, that's just weather. Unless you point that out to someone, in which case, "we predict more extreme weather", in which case abnormally cold weather is *also* an indication of climate change.
When we have extreme "climate change" events, you will note that it says things like "this is the hottest it has been since 1921!". Meaning it was hotter in 1921 than now.
p.s. being from California, I have heard this entirely circular/non-falsifiable, er, "reasoning" for about the last 20 years incessantly. Particularly the last few weeks - when the "climate change emergency" apparently makes it take more than a year to repair a small tear in a piece of plastic over a pond, for which you have to drain it completely, not fix it for a year, then not fill it up for fire season (Santa Ynez reservoir - a potable water reservoir installed long ago to provide emergency fire-fighitng water for Pacific Pallisades , which just burned down) or that we are trying to keep an "endangered" fish alive by - very unnaturally - keeping the Sacramento River flow rate much more consistent that it ever was before we go here. Used to, the river would flow a bunch in the winter and spring, then almost dry up in the summer and fall. This caused massive floods, so we put in dams and levees and made it much more constant, and could use it as a reliable source for irrigation and drinking water.
But even that was not enough for the apparently suicidal delta smelt, so to try to keep them alive we flow water out of the reservoirs, taking a huge fraction of the rainwater and snowmelt that waxes and wanes on a 5-8 year cycle and pouring into the Sacramento River to keep the flow rate up in the summer and fall. And not building any more storage capacity despite enormous money allocated to do that. Far from it; a few months ago, our beloved Maximum Leader Gavin Newsom was bragging about how he was instrumental in removing a bunch of dams on smaller rivers to remove capacity and thus allow salmon to use these rivers again. Salmon are *not* endangered.
On the other hand, we have spent 30+ billion dollars ln a high-speed rail that voters approved to go from LA to San Francisco in 2 hours. Of course, there is no high-speed train, nor the tracks for it, and its not going to go from San Francisco and Los Angeles ever, its going to go from one small town to another small town in the central valley, if it ever actually exists at all ,and ill cost at least $109 billion with no defined completion data even for that small segment. You can currently get a plane ticket from San Francisco to LA or Burbank for $79 on most days and it takes about 45 minutes.
p.s. I looked it up, the snowfall in New Orleans - which is definitely unusual - was not a new record, it is the same as another freak blizzard in 1895. No one at the time suggest that we dismantle modern civilzation. Also - I predict that you can find someone, somewhere, that will claim the 1895 snowstorm proves that "climate change was already happening 130 years ago! And They did *nothing* about it, making the problem much worse and exacerbating the crisis!"
