  • July 13, 2025, 10:28:20 AM
Author Topic: Ball Links  (Read 2991 times)
Ball Links
« on: April 11, 2024, 03:58:25 PM »
Does anybody have any experience with Uxcell or HobbyPark M3 ball links?
Online Carl Cisneros
Re: Ball Links
« Reply #1 on: April 12, 2024, 05:09:09 PM »
I have used the hobby park m3 ball links on my 90 hydros rudder in the past
they worked for me..
never had one fail.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Re: Ball Links
« Reply #2 on: April 12, 2024, 05:27:39 PM »
never had one fail.
Carl
I got an order of them in today.  They are very free and appear quite strong. Maybe too free, I am concerned about slop.
Also they appear to be identical to the Uxcell.  Probably the same store branded.
« Last Edit: April 12, 2024, 07:25:17 PM by Ken Culbertson »
Offline Crist Rigotti
Re: Ball Links
« Reply #3 on: April 12, 2024, 08:13:40 PM »
Where did you get them Ken?  I surprised that you would use anything other than the proven ball links and control hardware from Central Hobbies.  Why take the chance with anything else?  Just ask Matt.
Re: Ball Links
« Reply #4 on: April 12, 2024, 09:46:30 PM »
You mean this one?
https://www.central-hobbies.com/
My control system requires 10 ball links.  I needed some quick that I could use to mock up the controls and make the pushrods.  Those were all I could find "next day" delivery on.
Re: Ball Links
« Reply #5 on: April 13, 2024, 08:56:55 AM »
I discovered a great website that caters to RC Pattern fliers. It has a ton of stuff that we can use, including very high quality ball links. The website is F3A Unlimited.com, and I ordered two packages of Secraft 4-40 brass ball links from them. They are very free and come with standoffs for each link if you have a need for them. They are going in my next build for sure!
Here's a link to the ball links I ordered: https://www.f3aunlimited.com/secraft-ball-link-4-40-qty-10
Later - Bob Hunt
Thanks a bunch for the link.  The Ones I just received from HobbyPark are really not for PA and I am just using them as place keepers in the build.  I just ordered 2pkgs.  If I read it right they will take an M3 bolt - or not.  I am trying to go metric on everything and not having much luck.  DuBro links will only take a 4-40, an M3 won't fit in the ball - Aggh!
Re: Ball Links
« Reply #6 on: April 19, 2024, 09:36:29 PM »
Later - Bob Hunt
My order came today and they are beautiful.  So free but I can't detect any slop.
Thanks Bob for the link.
Re: Ball Links
« Reply #7 on: April 20, 2024, 10:05:56 AM »
The link says they are out of stock. ???
Online Doug Moisuk
Re: Ball Links
« Reply #8 on: April 20, 2024, 10:35:35 AM »
Brodak is showing them.
Doug Moisuk
MAAC 3360L
Re: Ball Links
« Reply #9 on: April 20, 2024, 10:42:59 AM »
Maybe I bought them all!   VD~
Re: Ball Links
« Reply #10 on: April 23, 2024, 10:38:35 AM »
Before you get any of these make sure you have 4-40 taps, both left and right.  They come untapped and the rubber is very hard, much harder that a DuBro.  They will not self thread using a bolt.  The hole is deep so you can tap it a full 1/2".  Once tapped, links are very easy to turn with just enough hold to keep them from rotating on their own.  I tested one with only 4 turns in the threads and it held for as hard as I could pull on the pushrod.  In my bag of 10, all 10 of the balls were tight and very free.  In my last bag of DuBro about 1/2 were too tight to use.
Just curious, does anybody make a 3.75-40 tap just for ball links? LL~
Re: Ball Links
« Reply #11 on: April 23, 2024, 12:27:55 PM »
    I think you want one with a different class of fit, Class 3x for one or both sides of the interface. . But, there is a similar question about getting class 3 4-40 taps. You might do better on the male side, dies are adjustable, or single-point threading. In plastic you might get an interference fit since it will spring out a bit while tapping it.
    I only have a thread on one end, the other end has a pretty classic-looking 3/32 music wire with a keeper. If you have left/right threads like a turnbuckle, then you have to worry about them turning themselves and do something to prevent it.
Re: Ball Links
« Reply #12 on: April 23, 2024, 12:45:14 PM »
     Take a 4-40 bolt and using the thinnest cut off wheel you have, cut a flute the length of the threads. Two or three is our call. Taper the end a tiny bit and you have a tap that will work in wood, plastic and and can chase existing threads in anything. I have never tried cutting new threads in aluminum or brass. It may make the threads in the ball link body a bit more snug. Threads on things like push rod ends, wheel spokes and such are not cut with a die. They are rolled in a series of sharp wheels and that is what raises the threads above the diameter of the rod they are made in. I wish I had a dollar for every time some one came into the hobby shop I used to work at and asked for a die to make threads on push rod ends longer!! I know a guy that had a small machine for rolling threads and I'm trying to see if he'll part with it just because it's the only one I've ever seen!!
