  • July 14, 2025, 03:13:34 AM
Author Topic: Bad fuel, what is it, how to determine, how to fix?  (Read 1498 times)
Offline frank mccune
« on: June 03, 2021, 09:33:24 AM »
     Hello All:
     The subject of”bad” fuel came up this past week.  As one can see from the title of the subject, this may be a complex quest.  What are the symptoms, inconsistent engine run, blown plugs, engine stopping in flight, inconsistent needle valve settings etc.
     I have been learning a bit about bad gasoline in Lawnboy 2 cycle engines this Spring and this carried over to fuel questions in glow engines.
     Suggestions/Comments
     Tia,
     Frank McCune
Online Peter in Fairfax, VA
Re: Bad fuel, what is it, how to determine, how to fix?
« Reply #1 on: June 03, 2021, 10:20:33 AM »
My experience is that well stored glow fuel from the start of the glow era (1950) is still good.
« Reply #2 on: June 03, 2021, 10:32:32 AM »
   It is not that complex. If you think you have a problem with fuel, get a brand-new unopened can of well-respected (Powermaster or SIG) standard fuel, and use that. If the problem persists, it is probably not the fuel.
Offline BillP
« Reply #3 on: June 08, 2021, 06:17:35 AM »
Signs of bad fuel...doesn't needle as usual and/or runs poorly, hard to start, starts with short bursts and stops. Won't stay running. Fuel can still look good but isn't.
Bill P.
« Reply #4 on: June 08, 2021, 07:59:28 AM »
     Hello All:
     Tia,
     Frank McCune
      You will more than likely have gasoline for your mower go bad before properly stored glow fuel goes bad. The problem with the gasoline for your Lawnboy mowers is the ethanol in the gasoline. It draws moisture if you don't keep it tightly capped and stored in a cool, dry place, and water easily affects gasoline by binding with the ethanol, and then it varnishes quickly. If you can find a gas station that sells non-ethanol gasoline use that for all your lawn and garden equipment. There are websites that show where gas stations in your area are that carry it. In large metropolitan areas like St. Louis, they are pretty much non-existent. I used to have to drive for several hours to Effingham, Illinois to get it but I used to deal with a friend there in vintage Penton motorcycle stuff, so whenever I went to his house I would always take any empty gas cans with me and fill up. We finally found another source at a convenience store in the other direction that is just outside of St. Charles County, MO that is only about an hour. If you don't need more that a small amount, most hardware stores are now selling premixed two stroke gasoline in quart cans but it is 6 or 7 bucks a quart!! If you check on You Tube, there are videos on how to extract the ethanol out of pump gas using a clear container and water. Whichever method you use, it helps to add some stabilizer to the gasoline if the premix oil you use doesn't already have it in it. I use Opti-2 premix oil in everything I have including my vintage dirt bikes and love it. It has stabilizer in it already and being a concentrate it mixes at a higher ratio so you have more gasoline in your mix, and you can often lean out you mixture a bit for more cleaner running engines. In short, make an effort to use non-ethanol gasoline in small two stroke engines, or any small engine, period.
     If glow fuel goes bad, it can happen right away. I had a jug of fuel that was down about half way, and it went bad from one flight to the next. I put in a flight at Buder, and when my turn came around again, the engine would stay running without the battery clip attached. As soon as I pulled the battery, the engine died. Changed plugs and same deal. Changed fuel and I was able to put the old plug back in and it ran fine. Since then I never run a jug of fuel completely empty. When it gets down to about 1/4 full, I start a new one and then when there is room in the new jug for the left overs in the old jug, I pour that in so nothing is wasted. As Bill P. mentioned, you may also have trouble with it needling and acts like you always have to adjust the needle after starting. Keep your fuel in a cool, dry and dark place when not in use. I try to keep my fuel out of the sun also when at the flying field.
Offline Phil Spillman
« Reply #5 on: June 08, 2021, 11:34:35 AM »
Bad model airplane fuel, once identified, makes excellent weed killer! Use appropriately the entire batch Do Not Bring It back in the house to get confused with really good fuel!
Phil Spillman
Phil Spillman
« Reply #6 on: June 08, 2021, 11:49:22 AM »
          Hi All:
          Thanks for all of the replies.
            Will switch to alcohol free gasoline for my Lawnboy mowers.  As the glow fuel is concerned, I will do a bit more research to attempt to get things sorted.  After all, how difficult ca s be? Lol
            Stay well,
              Frank
Offline BillP
« Reply #7 on: June 10, 2021, 01:21:13 AM »
To get non ethanol gas when not available...The antique outboard guys add water to ethanol gas to absorb the ethanol. It stays on the bottom in the water. Then they carefully pour off the gas leaving the water behind.
Bill P.
Offline bob whitney
« Reply #8 on: June 10, 2021, 07:59:13 AM »
i have heard that ACETONE will obsorb water
rad racer
