  • July 17, 2025, 05:20:16 PM
Author Topic: Flaps vs Trim Tabs?  (Read 1462 times)
Flaps vs Trim Tabs?
« on: December 17, 2010, 08:14:59 PM »
I decided not to connect linkage to the Phaeton II C/L conversion-lower wing[flaps].....I'm planning to use them like trim tabs. Are there any precedents for such an idea? What might be the pros and cons? All ideas and input greatly appreciated. H^^
Offline Ward Van Duzer
Re: Flaps vs Trim Tabs?
« Reply #1 on: December 18, 2010, 09:47:50 AM »
John,
See my recent post on RECKON THIS WILLL FLY?
Ward
« Reply #2 on: December 18, 2010, 04:20:54 PM »
Saw that Ward, thanks...that's what Ill do. Couldn't figure out any real benefit to having adjustable flaps. I made them static.
« Reply #3 on: December 20, 2010, 09:12:23 AM »
As I was told by our local stunt guru,  if flaps are lined up with each other, fix the warp or add a trim tab.  Just think a little about what the flaps are doing if they are not lined up with each other.   H^^
« Reply #4 on: December 20, 2010, 11:34:58 AM »
Yep.....trim tab is added....flaps are glued in place! H^^
