  • July 19, 2025, 07:10:20 AM
Author Topic: Need some 7/64" wire  (Read 1114 times)
Offline Bootlegger
« on: December 10, 2014, 11:28:08 AM »
  Fellows I am looking for some 7/64" wire to make landing gear, so I need to be able to bend it and it needs to have some spring in it also.
 Thanks for your help...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Need some 7/64" wire
« Reply #1 on: December 10, 2014, 11:35:03 AM »
That's an exceedingly oddball size -- why not 3/32" or 1/8"?
If you absolutely must have that size, try McMaster-Carr or Amazon.  There's a good chance you'll find it sized in mils -- 7/64" is 0.109", I found some 0.110" stuff on McMaster, but there's multiple options, all of which will require you to think through your assumptions.
Offline Bootlegger
« Reply #2 on: December 10, 2014, 11:52:42 AM »
 Tim thanks for the reply/question, I am building a 15 size model that I'm gonna put a .10 engine on and 3/32" might be too small and 1/8" will be too large.
 Thanks for the heads up on Mc Carr
Gil Causey
AMA# 6964
Offline John Craig
« Reply #3 on: December 10, 2014, 01:31:54 PM »
In bygone days it was not uncommon to see the 3/32 wire with a 1/16 wire brace wrapped & soldered.
« Reply #4 on: December 10, 2014, 02:24:46 PM »
Hi Gil,
I do believe you can use 3/32 and maybe add a spreader bar.  I have always used 3/32 on .15 size models.
BIG Bear
RNMM/AMM
Offline jfv
« Reply #5 on: December 11, 2014, 05:17:00 AM »
I have some .105" music wire in 12" lengths.  If that works for you I'll send you a few pieces.
Jim Vigani
