  • July 19, 2025, 07:26:34 AM
Author Topic: Blank  (Read 7914 times)
Offline Rusty
Blank
« on: December 07, 2014, 06:24:09 PM »
Blank
« Last Edit: March 12, 2022, 04:10:39 PM by Air Master »
Re: Baby Ringmaster from Outerzone downloaded plans
« Reply #1 on: December 07, 2014, 06:40:18 PM »
Wow!
Looks like Coast Guard. Nice!! H^^
What kind of paint did you use?
Offline John Cralley
« Reply #2 on: December 07, 2014, 06:56:23 PM »
Very nice Rusty, I think the plans you used are probably Pat King plans. Pat has a laser cut Baby R kit for not a whole lot of money. patdk@aol.com
John Cralley
AMA 52183
Central Illinois
Offline Ron Cribbs
« Reply #3 on: December 07, 2014, 08:38:00 PM »
Looks nice!
The reason it's a little different is because it's a shrunken Jr. Ringmaster. It's actully a nice rendition though!
Ron
Offline Russell Shaffer
« Reply #4 on: December 07, 2014, 09:03:36 PM »
Yes, it will fly all right.  It would do well with a Baby Bee - that TD will be a screamer.
Russell Shaffer
Klamath Falls, Oregon
Offline John Kelly
« Reply #5 on: December 07, 2014, 10:03:53 PM »
   ...Hey Rusty, Looks really nice... should fly fine. To get the area, add the root chord to the tip chord and divide by two, then multiply times the wingspan.  Cheers,  John
AMA 11416
« Reply #6 on: December 08, 2014, 06:45:30 AM »
wingspan?
Offline Larry Renger
« Reply #7 on: December 08, 2014, 07:35:52 AM »
I think it should handle 40' lines. .008 steel or 10 lb spectra.
Offline Roger Vizioli
  • CLiner
« Reply #8 on: December 08, 2014, 08:32:16 AM »
          A great flying RM of this size is Pat Johnston's RM 207.
          In our club we have (2), one electric powered and one Norvel .061 powered. Bob Whitney's Electric has functional flaps, my .061 powered, below, has fixed flaps. Both are fully capable of flying a decent pattern.
           Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #9 on: December 08, 2014, 10:19:02 AM »
Rusty, that wing area is appropriate for a Babe-Bee or other detuned 049.  It would be too small for a 020 reedie, although it may work with a TD.  You should be fine with what you have, although you may want to go with a Medallion venturi to tone it down.
(If the engine seems to run nicely, I'd just go with longer and longer lines first, though -- if you use spectras, the experimentation should be cheap).
Offline John Kelly
« Reply #10 on: December 08, 2014, 11:28:39 AM »
   ...Hey Scott, Wingspan is the length of the wing from tip to tip. Cheers, John
AMA 11416
« Reply #11 on: December 08, 2014, 11:40:39 AM »
Tim, I detuned it by putting a medallion crank in it.  Maybe I will take the TeeDee cylinder off and put a standard on it too?   Thanks
See how it flies, first.  IIRC the Medallion venturi is smaller than the TD: I suggested what I suggested to improve fuel draw, not just to make the engine run slower.
« Reply #12 on: December 08, 2014, 07:22:05 PM »
John: you bad!  n1
Offline John Kelly
« Reply #13 on: December 08, 2014, 07:40:28 PM »
   ...Hey Scott, Took me a minute to figure out what was wrong. That's what happens when I post when I'm running out the door. I don't know Rusty and didn't know if he might be familiar with different terminology, asking what wingspan was. Then the Light went on when I realized it was you asking him what the wingspan was on his bird. ROFLMAO. I'm not bad... just not the brightest bulb in the pack.  Cheers, John
AMA 11416
« Reply #14 on: December 08, 2014, 07:42:42 PM »
Actually, I thought it was pretty funny!
« Reply #15 on: December 08, 2014, 07:59:10 PM »
Actually I was wondering the same thing about the wingspan of the airplane.  For that area it must be only about 20 inches.
The airplane looks bigger than that in the picture.
« Reply #16 on: December 08, 2014, 08:10:38 PM »
Tim, here is what my investigation found, see pic for proof.
The ID of the TD venturi is .116"
The ID of the Medallion venturi is .157"
But the Medallion venturi has this honkin' big spraybar that gets stuck through it: the TD venturi doesn't.  I don't know the diameter of the spraybar, but I'm sure that the area that's left in the Medallion venturi after it's in is way less than the area of the TD venturi.
Offline John Kelly
« Reply #17 on: December 08, 2014, 08:18:39 PM »
   ... Hey Randy, Outerzone lists it at 22" , but says to check scaling when printed out before cutting wood.
AMA 11416
  • CLiner
« Reply #18 on: December 08, 2014, 08:27:41 PM »
Thank you, Roger.  If you don't mind my asking, is your plane the same as mine?  What is the wing area and weight of yours?
Rusty,
no, it's not the same plane. the wing area is 207 sq in, airfoil is "modern" ie thicker!
It is out back in the shop and it is pouring right now, forgot the weight, will weigh tomorrow if rain stops.
Pat also has a RM307, 307 sq in wing. I am using a Norvel .15 in mine but it is too much engine for the plane, planning on trying a Norvel .074 when time permits.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #19 on: December 08, 2014, 08:45:13 PM »
The Tee Dee will run on suction, but not very well. A few layers of pantyhose material will reduce airflow enough to make it work. Those plastic carby bodies are really vulnerable to crash damage, so be careful with it!  D>K Steve
Offline John Kelly
« Reply #20 on: December 08, 2014, 09:30:16 PM »
   ... Hey Rusty, I have to agree with you 100% on that! I don't know if you know this, but if you click on "more pics" under the picture of the blue and white bird and scroll down... He'd like modelers  to send photos of models built with his plans. I think it would be a great way to say thanks, especially since yours came out so nice! It's got me wanting one! Not to mention the pics of a nice stooge operated dolly launcher for those who like to go gearless!    Cheers,  John
AMA 11416
Offline pat king
    • PDK LLC
« Reply #21 on: December 09, 2014, 07:52:34 AM »
Very nice looking airplane. If it is not in the 150 square inch range it is too small for a front rotary Cox or Norvel .049 . My Ringmaster 150 is designed for front rotary .049 engines, it is not enough airplane for .061 engines. The original Baby Ringmaster is a 21" span, 95 square inch airplane for radial mount reed valve engines. Brodak sells what they call a Baby Ringmaster for beam mount engines, but they only sell beam mount .049 engines.
Pat
Pat King
Monee, IL
AMA 168941
  • CLiner
« Reply #22 on: December 09, 2014, 08:19:56 AM »
Rusty,
Roger
Rain stopped! :-)
wing span is 31", wt = 9.3 oz as shown in pic.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #23 on: December 09, 2014, 01:00:29 PM »
Isn't 31 inches more like a Junior Ringmaster or did you hit the wrong key?
« Reply #24 on: December 09, 2014, 04:12:53 PM »
Yeah the Ringmaster Jr is 32 inch span.  I suspect a modern .061 puts out about the same power as my OK Cub .14 which is what I had in mine in 1954 (I think).
It actually worked pretty well!
Roger's airplane actually looks more like a Flite Streak wing than a Ringmaster!
Offline pat king
    • PDK LLC
« Reply #25 on: December 09, 2014, 09:55:40 PM »
The fuselage shape and tailfeather shapes of the plans on Outerzone are reduced size Ringmaster Jr. shapes. The Ringmaster Jr. shapes are considerably different from the original Ringmaster S1. The thin wing of all the Sterling kits was not as good as the thicker wings we typically use today. Unless an airplane is going to be entered in OTS it should have the thicker wing.
Pat
Pat King
Monee, IL
AMA 168941
  • CLiner
« Reply #26 on: December 10, 2014, 07:56:14 AM »
Hi John,
My error if I inferred it was a Baby Ringmaster. Never flew a RM other than the S-1's (since 1952 or 3?) before this one
Span is 31". I will have to compare it to RM jr plans. Pat calls it a RM207 becuse of the 207 sq in wing area.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #27 on: December 10, 2014, 08:12:52 AM »
Hey Rusty!
I use the white glue also and prefer it to CA.  have you tried this: I use the Gorrilla white and dilute it about 10% with water, that seems to make a stronger joint as the glue then penetrates better.  I notice that some of the carpenter glues are so thick that they sit on top of the balsa and under stress just delaminate from the balsa at the glue line.  I also bought a little glue bottle applicator from Tom Morris and it works great.  He has also converted me to using his "one dot of glue every quarter of an inch".  That avoids creating a glue line that is so hard to sand.
Happy building!
Scott
