  • July 12, 2025, 07:29:31 AM
Author Topic: B Yak 9 suggestions  (Read 3609 times)
Online Carl Cisneros
B Yak 9 suggestions
« on: November 23, 2014, 01:25:22 PM »
There we go folks
I know Pat, that is a great kit, but I am building the Brodak Yak9 for the 2015 Brodak contest.
Dennis, I do have the retro fit kit as well, but if memory serves I can not use that for OTS.
Please correct me if I am wrong here.
Am thinking about using the Series 21 McCoy in it tho.
Oh, I am still working on Santa for the Buster 45 kit you are just releasing for Christmas Pat. (Her majesty is still out on deliberation at this time   D>K )
Here are a couple of pics of my new Brodak Buster I just finished for fun flying.
and yes, I do know about the cases on the old red heads.   H^^
Almost forgot, it is all done in Towerkote iron on film. (Painting these days really gets me feeling very light headed and bad feeling.)
« Last Edit: November 23, 2014, 01:45:12 PM by Carl Cisneros »
Carl R Cisneros, Dist IV
Control Line RB
Re: B Yak 9 suggestions
« Reply #1 on: November 23, 2014, 01:54:47 PM »
For Old Time the gear must be on the fuse.   My Yak 9 I had backin the early 60's had my old McCoy .35 Redhead.   Was a blast for a kid fresh off the farm that knew nothing about flying stunt.
Offline Ron Cribbs
« Reply #2 on: November 23, 2014, 02:06:50 PM »
As to Yak engine choices, if it were me either the OS .30/35 or K&B stallion. Actually I would use a Fox .35... ;D
Good job on the Buster.
« Reply #3 on: November 23, 2014, 02:56:44 PM »
I am using a Veco .19 BB on my Sterling Yak 9.
BIG Bear
RNMM/AMM
« Reply #4 on: November 23, 2014, 05:59:44 PM »
Thanks for the compliment Ron.
This is the first CL kit build I have since, dang I  can't remember the last time I built a CL kit.  LOL
must be getting older these days ya know.
I am looking forward to building the kit over the winter in the garage and flying it in early spring time and learning the OTS
pattern.  Should be a hoot.
Control Line RB
Offline Ron Cribbs
« Reply #5 on: November 24, 2014, 10:12:45 PM »
The OTS pattern is challenging, not so much the actual stunts, but getting the old designs to do it. I think the Yak is capable of a decent pattern and a good choice. It would be nice to see. I have been wanting to compete in OTS with a PDQ Super Clown.
Are you omitting the flaps?
Offline Serge_Krauss
« Reply #6 on: November 25, 2014, 09:51:39 PM »
The Sterling Yak-9 was my first "big" CL model. I flew it on 52' lines with a nicely broken-in McCoy .35 ($5.98 special). I had a ball with it, and leaned out, it flew with no problems at all. Of course I knew nothing of "the pattern", but did horizontal lazy-8's, wingovers, and vertical lazy-8's, which were sometimes successful, a significant accomplishment, since they did not fill up much more than 60-70 degrees. Mine had flaps and the V-shaped flap connector. The plane is sort of short-coupled for flaps, but mine was purely stock and flew quite well. I lovd that plane! I built another, started around 1960 and finished in 2002, after my 40-year hiatus. It's too heavy.
« Reply #7 on: November 26, 2014, 08:02:00 AM »
Ron
I have not decided on the flaps or not flaps as yet.
just been looking at the plans and building instructions for now.
Control Line RB
« Reply #8 on: December 01, 2014, 07:19:31 PM »
Ron
I built my Sterling Yak-9 last winter. There's a lot of good reading over at Stuka about these kits. More people than not tried talking me out of hinging the flaps, but I'd never built or flown a flapped plane before and just wanted to, so I did. And I'm glad I did, it's one of the most fun planes I ever flew. It is rock steady in the level laps in both directions and goes wherever I point it. It'll do tricks that remind me of a 1/2A, or make big round turns too. I was pattern flying with no trouble last week on a calm day. But I can't say whether it would be quite as dreamy on a more challenging day.
Actually Ron cribbs gave me the old kit and Fox Stunt 35. I made a laminated fuselage that weighed a lot less than the sterling lumber. With the Fox 35, that lamination turned out to be a blessing too because it's developed a few hairline fractures that I'm sure won't penetrate the epoxy center.
This plane is a blast. You won't be disappointed.
The only thing I don't like is my cheesy looking canopy. One of these days I'll get around to the exhaust headers.
Rusty
« Reply #9 on: December 02, 2014, 08:02:38 AM »
Great looking plane Rusty
I plan on doing mine up in the Winter paint sceme like you did on yours.
Will probably put wither a McCoy 35 or OS 35S in mine.
Carl
Control Line RB
« Reply #10 on: December 02, 2014, 07:23:25 PM »
Hey guys: I saw Carl's Buster.  His job on the Towercoat covering is about as good as you can get.
Carl: be sure to ask Dick H. about what happened to his Yak 9 at the bottom of his third vertical eight at the Norfolk Nats.... S?P
Scott
« Reply #11 on: December 05, 2014, 12:14:53 AM »
Thanks Scott
That means alot coming from you guy.
Yeah I just might ask Dick about that.
Control Line RB
« Reply #12 on: December 05, 2014, 05:41:47 PM »
I built one up as a Spitfire, changing the stab/rudder outlines an making pointy elliptical tips  and curved flaps.  The V-shaped flap connector worked fine for the life of the plane.  McCoy 35 and a Fox 35..
Flew quite well and should have no problem with the OT pattern
« Reply #13 on: December 06, 2014, 06:28:28 PM »
Thanks Phil
been cold and rainy here in the N. VA area lately.nit too cold to go out to the garage and build.   :(
Control Line RB
« Reply #14 on: December 06, 2014, 09:09:33 PM »
How far are you from Summit Point race track?
« Reply #15 on: December 07, 2014, 09:05:06 PM »
probably about 3 hrs. max depending on traffic I would guess.
Control Line RB
« Reply #16 on: December 12, 2014, 07:59:32 AM »
Ok, I thought Woodbridge was close to the track since my kart club is named after it.
