  • July 02, 2025, 05:23:33 AM
Author Topic: aviastar engines  (Read 2573 times)
Offline Brad B
aviastar engines
« on: September 26, 2008, 05:14:16 PM »
Does anyone know anything about these engines?  Aviastar 46 and a 53  I was just wondering about the quality of them.   Thanks, B
Re: aviastar engines
« Reply #1 on: September 26, 2008, 07:57:05 PM »
http://www.sigmfg.com/cgi-bin/dpsmart.exe/MainMenuFV4.html?E+Sig
Click "engines" on the menu in the left margin, then "R/C Gow Engines 2 Cycle .51-.60"
I recalled seeing them mentioned in a SIG ad, but didn't investigate at the time. So, I just did. Looks a lot like the old series of Magnum XL engines, with maybe some extra case fins added. I'd bet that the same case casting is used for both, so probably the .53 is lighter than the .46 (more air inside). The Magnum XL .53 is fairly popular here in the NW, so I think you might have found a gem. The parts might well swap, too. Keep us posted!  y1 Steve
Offline Greg L Bahrman
« Reply #2 on: September 26, 2008, 09:44:22 PM »
From the Sig site. The .46 is 13.4 oz. at $49.99 and the .53 is 14.4 oz. at 69.99. A little on the heavy side but the prices are really reasonable for sure.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Vincent Corwell
« Reply #3 on: September 27, 2008, 12:37:22 AM »
I saw these on Brodaks web site
and at different prices ?
Vincent
Offline Ralph Wenzel (d)
« Reply #4 on: September 27, 2008, 03:31:50 AM »
Vincent
Whew! Ambitious pricing, compared to SIG!
Ralph
Ralph Wenzel
AMA 495785 League City, TX
Offline Brad B
« Reply #5 on: September 27, 2008, 07:17:14 AM »
Really expensive venturi I suppose.   ~^
Offline Andrew Borgogna
  • Andy
« Reply #6 on: September 27, 2008, 09:58:06 AM »
It would seem Sig has redefined the ABC engine.  Their "true ABC construction" has a "steel alloy" cylinder and I always thought it was chrome plated brass oh well live and learn. ~^  Still for the price it might be worth investigating.
Andy
For instance, the connecting rods use the same aluminum alloy as found in some full size aircraft engines. Crankshafts are one piece hardened Cr steel. A specially developed "KK" bronze alloy is used for the conrod bushing which allows it to withstand high RPMs. Cylinders are made of a special heat treated Cr steel alloy to insure a hard and true cylinder that will not distort at high temperatures. Piston rings (1.2 - 2.0 in3 engines) are made of the same steel alloy as found in some racing motorcycles. The .46 in3 is true ABC construction. All engines contain high quality dual ball bearings.
Andrew B. Borgogna
Offline Leester
« Reply #7 on: September 27, 2008, 05:35:33 PM »
The Super Tigre 51 venturi and nva work in them just fine.
Leester
ama 830538
« Reply #8 on: September 27, 2008, 05:44:25 PM »
The steel sleeve probably applies to larger ringed engines...which may include the .53. In any case, advertising folks don't always know what they're talking about, right?  R%%%% Steve
