  • July 30, 2025, 08:58:03 PM
Author Topic: As luck would have it I do not need a stripper.  (Read 1601 times)
« on: June 08, 2008, 04:11:05 PM »
Well I wrapped the fuse in silk span when I built the plane and for some reason when I cut the wood down I have a few places where the silk was laying over. I started to pull and it is pealing off like wall paper. Kind of easy. I will have a few areas that I need to sand but for the most part it is cleaned off.
Notice how slim the nose is now. Also on a side note I measured the thickness of the paper and all the paint. It was .0070 inchs thick! HB~>
Thanks guys!
Paul  H^^
Alan Hahn
Re: As luck would have it I do not need a stripper.
« Reply #1 on: June 08, 2008, 04:15:33 PM »
Paul,
It is worthwhile to invest ~$30 in one of the small electric scales that are available. That way you can see what you are achieving (or not!). It makes it easier to figure out what it is worth to invest your time and effort in changing.
« Reply #2 on: June 08, 2008, 06:20:45 PM »
Yup. Someone has given me a heads up on a cheap scale at Wal-Mart.
I will stop by and pick one up on my next trip into town. y1
Paul H^^
PS- My hobby time is not worth much.
« Reply #3 on: June 08, 2008, 07:20:21 PM »
Oh, you meant that kind of stripper.  ;)
Offline Keith Spriggs
    • khspriggs
Alan Hahn
« Reply #5 on: June 09, 2008, 10:39:20 AM »
Paul H^^
Paul,
Maybe your time doesn't seem worth much to you, but I bet a "redo" is worth the cost!
« Reply #6 on: June 09, 2008, 11:16:18 AM »
Well maybe so, but I just can not give up just yet. This will be my last attempt at making this plane fly a patteren.
I will try to do a pattern with this plane or.... kill it trying. ~~>
Offline Steven Kientz
« Reply #7 on: June 09, 2008, 02:29:55 PM »
If it won't fly the pattern then use it to mentor a new flier. Bound to be some young person in your area that would like to fly.
Steve Kientz
AMA 855912
