  • June 25, 2025, 09:01:29 AM
Author Topic: Why Counter Clockwise?  (Read 2355 times)
« on: February 27, 2019, 09:27:58 AM »
I have always wondered why our engines are predominately counter clockwise?  I am not trying to spark a discussion of which is better for us but I am curious why clockwise was not picked for CL back when it first started?  Seems to me that either works for everything else but clockwise, especially in speed and maybe in Stunt is better.
Offline Steve_Pollock
Re: Why Counter Clockwise?
« Reply #1 on: February 27, 2019, 09:44:35 AM »
I think primarily because clockwise rotation (when viewed from the rear of the engine) tends to tighten the prop nut; counter-clockwise rotation tends to loosen it.
« Reply #2 on: February 27, 2019, 11:42:21 AM »
Good enough reason especially if left handed dies were in short supply.  I heard once that the very early control line planes flew clockwise.  I doubt that any of us were around then.
« Reply #3 on: February 27, 2019, 12:35:12 PM »
Leo Mehl was. Alan Resinger maybe. He’s pretty old.
Offline Steve Thompson
« Reply #4 on: February 27, 2019, 01:43:16 PM »
CCW from front so they are like "real" airplane engines.  CW from the back so they are like car engines.  But mainly CCW from front so angular momentum vector points forward.  Very important for piece of mind.
« Reply #5 on: February 27, 2019, 02:36:13 PM »
Given the fact that the majority of humans are right handed - it makes sense to be flying in front of your field of vision AND turning the natural way - ie looking where you are going.   Clockwise you will be turning backwards and having to watch the plane -  so makes it a little hazardous
Maybe I wasn't clear (I do that a lot), but I was referring to the rotation of the prop, not the direction we fly, that part makes sense.
ken
« Reply #6 on: February 27, 2019, 06:37:33 PM »
So that RH propellers make the plane go forward and LH propellers make it go backwards!  LL~ Steve
« Reply #7 on: February 27, 2019, 07:08:32 PM »
Only if you get the ESC right.  LL~
« Last Edit: February 28, 2019, 11:56:54 PM by Ken Culbertson »
« Reply #8 on: February 28, 2019, 11:12:43 PM »
Only if you get the ESC right. y1
Ken, you might check the OP's (you) first post. It said "engines". Didn't say "motors". ESC's are not useful items on IC engines. TUTs may be, but we may never find out.   y1 Steve
Offline Pepe Llopis
« Reply #9 on: March 01, 2019, 01:44:39 AM »
To start them with the right hand?
Offline Istvan Travnik
« Reply #10 on: March 01, 2019, 04:54:15 PM »
...And Gene Schaffer, too, as I am right...
https://stunthanger.com/smf/nostalgia-30/gene%27s-stunt-machine/
« Reply #11 on: March 01, 2019, 05:53:43 PM »
    Most events that go in a circle go counter clockwise. Car race events . bicycler indoor racing. Ice skating racing events.  ~^
« Reply #12 on: March 01, 2019, 06:36:26 PM »
This has really drifted off of my original question which was why clockwise prop rotation did not become the standard.
« Last Edit: March 02, 2019, 05:50:29 PM by Ken Culbertson »
« Reply #13 on: March 02, 2019, 06:44:46 AM »
Ken I think what people are telling you is it seems more natural to turn left . Not all early model motors were counter clockwise rotation as viewed from the front. S?P
Offline Doug Burright
  • Legacy, Brodak kit
« Reply #14 on: March 02, 2019, 04:30:03 PM »
Our left-handed friend who is new to the hobby, has a difficult time starting the engines, because of the direction of rotation. We told him to flip them backwards, which is more natural for him, and the engine will start, and run in the correct direction, because front rotor engines, and the timing makes them want to run CCW, unlike reed valve engines. We just hate to see electric starters used on engines.
I will build it. It's gonna be really difficult to find me with an ARF. I know every bit of my airplane!
