  • June 20, 2025, 02:05:20 AM
Author Topic: About chicken hopper tanks.....  (Read 2529 times)
Offline Terry Caron
« on: October 27, 2015, 06:48:59 PM »
Having some grasp of the how and why of a uni-flo tank's MOL constant fuel delivery, and understanding that a chicken hopper can be either standard vent or uni-flo, in a standard vent chicken hopper it seems that, with MOL constant suction and atmospheric pressure on it's confined "available fuel" volume, it would achieve much the same effect as uni-flo - why doesn't it?
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Terry Caron
Re: About chicken hopper tanks.....
« Reply #1 on: October 27, 2015, 10:54:30 PM »
After mulling it over, and recalling a blinding realization achieved in the thread on uni-flo tanks (that we're working with a dynamic fuel system) I'll try to answer my own question (someone please correct me if I'm wrong!):
In any standard vent tank,including chicken hoppers, while suction and atmospheric pressure may not vary, during flight the fuel pressure at the pick-up does vary as the pressure applied by the fuel in the reservoir diminishes.
And applying muffler instead of atmospheric pressure to a non-uni-flo system doesn't change that.
Speaking of MOL constant-speed engines of course.
Right?
Terry
AMA 249824
NRA Life Member
Offline Douglas Ames
« Reply #2 on: October 28, 2015, 12:28:05 AM »
What's MOL?
AMA 656546
Offline Terry Caron
« Reply #3 on: October 28, 2015, 08:47:17 AM »
MOL = More or less.
Terry
AMA 249824
NRA Life Member
Offline Horby
« Reply #4 on: October 28, 2015, 07:08:07 PM »
Save grief and weight and go with a clunk uniflow. If I go back to ic I will never use metal tanks again.
Warren
Offline Terry Caron
« Reply #5 on: October 28, 2015, 07:17:24 PM »
I do fly clunk uni-flos Warren, along with standard vent, and having learned more (in another thread) about them since opening this thread I may go to them exclusively.
Terry
« Last Edit: October 28, 2015, 07:41:27 PM by Terry Caron »
AMA 249824
NRA Life Member
« Reply #6 on: November 01, 2015, 11:50:38 AM »
One reason muffler pressure can help is that it reduces the percentage change in the head pressure of the fuel(pressure due to the difference in pressure due to the height of the fuel above the fuel outlet).  A standard vented tank will always gradually lean out as the fuel runs out because the depth of the fuel changes.  It's only a pressure of less than an 3-4 inches of water, but that is enough to change the engine run from rich at the beginning of a flight to lean as it runs out of fuel.  Muffler pressure increases the the pressure on the fuel from nearly nothing to a couple of pounds per square inch, or the equivalent of about 50-60 inches of water.  That makes the fuel pressure change due to the 2 inches of fuel in the tank only 3-4% or so of the fuel head change, instead of a 100% change.  The fuel pressure goes from a fairly constant couple of psi above normal air pressure down to 0 psi above normal air pressure just as the engine runs out of fuel.
Offline Terry Caron
« Reply #7 on: November 01, 2015, 12:08:25 PM »
Thanks so much for your reply Phil - I didn't know muffler pressure was that significant.
So my conclusion was partly correct and your point is well taken.
Terry
AMA 249824
NRA Life Member
« Reply #8 on: November 01, 2015, 05:17:51 PM »
Me too, thanks Phil, that helped my understanding also. I run muffler pressure on most of mine regardless of std or uniflow.
Rusty
Offline Horby
« Reply #9 on: November 02, 2015, 08:37:40 PM »
Phil the only problem with mufler pressure is you can't get a 4-2-4 break like you can with a uniflow and keep a constant lap time at the same time.
Warren
Offline Terry Caron
« Reply #10 on: November 02, 2015, 08:46:13 PM »
Warren
Are you referring only to standard vent tanks or to uni-flos also, Warren?
Terry
AMA 249824
NRA Life Member
