  • July 12, 2025, 03:06:05 AM
Author Topic: Appearance Points  (Read 13738 times)
Offline curtis williams
Re: Appearance Points
« Reply #50 on: April 28, 2022, 10:06:27 AM »
How do you factor in foam wings/foam flaps and foam elevator, made by someone else?
And what about lazer cut kits?
Shouldn't we all be cutting out from plans?
Online Paul Walker
« Reply #51 on: April 28, 2022, 10:26:14 AM »
Appearance has near the weight of any of the maneuvers, yet you have no control over it since every judge is free to determine what he/she considers average and where that number is in the scope of things. What does a zero look like?  What does a 20?  What gets extra points, what is simply expected?
[/quote]
And how is that different than the flight scores. Both are subjective evaluations.
20 points is 1/2 of a maneuver score. I don't consider it "near". I agree with Sparky, bring back 40 points!
But will all of this discussion make any difference...no!
The original question was about how it is judged. Trying to define a set of guidelines that can be used is a difficult task. The current rule that specify how much can be purchased and how much has to be done by the pilot is a compromise that was finally voted into the rules. The question of who built what on the model is very difficult to get agreement on. The foam wing is an example. The pilot didn't build it, but was generally accepted as being BOM legal. The current rules define what is acceptable in that area.  The finish is another story. How do you put objective rules on such a subjective evaluation.
The appearance score is a giant can of worms. Good luck trying to put objective guidelines on that one.
FWIW, I won most of my Nat's while scoring only 17 points.  That was my goal for many years. I figured I would make that up in the first maneuver or two. In other words,  it never bothered me. In fact it inspired me to work harder at flying. Maybe some should take that attitude.
« Reply #52 on: April 28, 2022, 10:28:12 AM »
Somehow this thread has drifted off into the BOM black hole.  Any chance of getting back to the intent of how we award those 20 points?  Here is all I can find in the rules:
    Yes, inexplicably a troll post about BOM drew a lot of responses. Particularly this one, which sat with no responses for the better part of a year. Fred revived it with a reasonable question- and then it, wonder of wonders, turned into yet another BOM flamefest.
"Judges shall exercise prudence in assigning points, and reserve excellent point values for those models which are decidedly above average."
    You have exactly the same "control" you have for the maneuvers, and the judging is just exactly as subjective. The "solution" to how to award points for appearance is exactly the same as for maneuver scores - the opinion of the judges. The one material difference is that, unlike maneuver scores, you have *all* the airplanes there at once, so you can determine what "average" and "decidedly above average" might be for the entire group at once. That makes appearance judging, for the most part, easier and more definitive. Since the absolute number doesn't matter, you can spread it out however you want from 1-20, for any set of airplanes. Since it is only used at that particular contest, you apply relative values in the same way for everyone.
   So, even if you give someone a 20 and someone a 1 - you at least be pretty sure that the judge thought the 20 was much better than the 1 by comparing them side-by-side. Since it is all relative, that's all you need to do.
   But aside from that, and some examples of what *some* experienced judges use as criteria (like Keith Trostle did over on SSW - and then, predictably, got raked over the coals by the anti-modeling crowd, including a claim that he rigged his criteria to favor *Windy*!), it is exactly like maneuver scores - a matter of opinion.
   So, you have no "control" over any of the scores - you do the best you think you can, you ask someone to give their opinion, and maybe they like it and maybe they don't. If you don't like the results, tip your cap to the winner, shake everyone's hand, and resolve to try harder or do something different next time.
« Reply #53 on: April 28, 2022, 10:30:25 AM »
   Sheeted foam components have been allowed for a long time. They still need to ne finished further, assembled into a fuselage that you built and then the final finishing system applied. The wording in the rules is or was something about being components found in an average kit. A lot of those kinks were worked out several years ago. Go to the AMA website and read up on it.
    As far as a guide for what to judge for appearance points, if one does not exist, we should coral the remaining 20 point winners that are still living and have them collaborate on something and /or any of the past, better appearance judges throwing in their 2 cents worth.
Offline fred cesquim
    • Fred Cesquim Aeromodelos
« Reply #54 on: April 28, 2022, 11:00:41 AM »
thanks Brett, my intention was to find the set of rules ( still nothing) and not to open this topic again
i forsee what will happen here in brazil if i suggest such event.... modellers here spend 90% of the "modelling available time" on whatsapp and the 10% remaining sorting throught terabytes of plans saved on their hd´s....
« Reply #55 on: April 28, 2022, 11:15:12 AM »
  Understood, but there are too many people taking every opportunity to get in their digs again. In real life, there is no consequential debate about it and very little controversy aside from the occasionally whining. While the internet has brought immense value to our hobby, allowing every random twit to spew nonsense to thousands for free is the cost.
     The appearance point "rules" are mostly non-existent. Almost anything goes, and it is entirely subjective. As mentioned above, several world-class modelers have provided their general guidelines, but usually that gets them a lot of grief, so I could understand why they might be a bit reluctant - and clearly nothing has changed.
  In my personal opinion, Keith's were far and away the clearest and most reasonable, perhaps we can prevail upon him to post them again.
« Reply #56 on: April 28, 2022, 11:55:59 AM »
When I refer to the value as being equal to a maneuver I am thinking more in terms of the spread than the absolute score.  In an Expert class in the parts of the country I am familiar with the individual maneuver scores for all fliers are going to average somewhere in the mid 30's.  The range will narrow closer to the top where you have maybe 2 or 3 points per maneuver between the best and worst(excluding screwups) of those making the podium.   To me, that makes the high/low range on appearance just as valuable as a maneuver.
Will the discussion make a difference?  It may to Fred who posed the question in the first place and from what I can gather did not get answer.
I was shocked when I returned from Vietnam to find the 40 appearance points gone.  I didn't like the differences in opinion over what made up originality and realism but some rule clarification would have fixed that.
« Last Edit: April 28, 2022, 12:13:23 PM by Ken Culbertson »
« Reply #57 on: April 28, 2022, 12:09:23 PM »
I have read through this stuff several times.  Why does people just leave the appearance points where they are required, Open, Senior and Junior classes.  The PAMPA classes let you fly any plane you want, with out the worry of appearance points.   If you want to win you have to try harder and learn more.  I myself do not like finishing planes as many will attest to.  I do like to build/contruct planes.   So why don't we leave things as they ar as far as appearance points.   R%%%%
« Reply #58 on: April 28, 2022, 01:12:45 PM »
  I think it would prove a little trickier than you think, particularly "originality". I would lobby against "realism" if it were to come back - I don't think we should be attempting to emulate full-scale aviation, since the rest of the event holds very little correspondence with full-scale.
« Reply #59 on: April 28, 2022, 02:19:00 PM »
An extra maneuver , I like that Paul W.
I vote to never bring this up ever again.
Can I hear, a hell ya?
« Reply #60 on: April 28, 2022, 02:20:25 PM »
A good friend of mine built a Jetco Shark and painted it just like the kit box.
I built a Midwest PT-19 and painted it a different way.  I beat him by 3 points in originality.
You would really need an original design that didn't look like a modified Nobler to bag the whole 10 for Originality.
The original BOM Rule said the modeler had the build The Whole Model.  At some time they allowed store bought props.  That was the original sin.  The crack in the wall the brought modeling down to just flying toys.
« Reply #61 on: April 28, 2022, 03:28:21 PM »
Actually, I think it would be very tricky!  What I miss are the full "scale" cockpits, jet style planes with realistic markings.  Some judges carried originality and realism to ridiculous levels.  I once got the minimum for a 63" 620 sq twin tailed original design with wing mounted gear because the judge claimed it was a modified Nobler.  At least he could have called it a modified Fury or Olympic, neither of which I had heard of at the time.  I wasn't there for the change to 20 so I don't have a clue what prompted it other than the difficulty of judging those categories.  Having known both Gieseke and Rabe, they probably were part of that discussion, maybe even started it LL~. Perhaps in the late 50's there were still a lot of new looking designs.  Today, original is really moot.  I have never quite grasped the concept of minimum points for appearance either.  So Curtis, since I can assume that there will be no concrete standards coming forth, I can add my "hell ya".
Offline RC Storick
« Reply #62 on: April 29, 2022, 04:02:31 AM »
This is for the people who think the spirit of the BOM is to build everything It's not. Who is going to open a mining company to mine Ore for aluminum steel  ETC... Open a chemical plant for the manufacture of paint a paper company for the paper and most of all fly down to Ecuador to open a balsa plantation Harvest saw and plane every stick. Don't be ridiculous. That is not the spirit of the rule.
Think about a common pencil. How many people and companies did it take to manufacture it? A whole lot of people had a hand in the making of it. If you want to fly with the big dogs build your own airplane.
in 2017 My dad came to NATS with me. A modeler in his own era 1949 (speed). While in the 180 building he saw a ratty airplane on the last row He told me he felt bad for the Kid but remembered when he built it like that. He said if the kid has the desire he would improve and move up.
Offline Dennis Moritz
« Reply #63 on: April 29, 2022, 06:11:51 AM »
Windy got a few 19s and a 20 or two without elaborate color schemes. If I remember correctly. Workmanship. Originality of design, his twins for instance, may have been given consideration. I think Derek's eye popping original, intricate, work was second row not first row, one year. Some planes score very high in appearance while repeating a similar color scheme or modeling a known shape. Originality of design (functional and aesthetic) does not count towards the 20 points, far as I can tell. Which is why I brought up my initial point. In Open at the NATs emphasis is on fit and finish (workmanship), no points for originality. Is that an Impact I see before me on the first row. Again.
« Last Edit: April 29, 2022, 08:35:13 AM by Dennis Moritz »
« Reply #64 on: April 29, 2022, 10:02:37 AM »
  Just remember - these guys claiming to insist on making your own wheels, etc,  don't believe that, either. They are taking the reasoning to an absurd extreme, just to make the entire notion seem fraudulent or ridiculous. It's call arguing reductio ad absurdum, and while sometimes it's valid, it certainly isn't in this case. They are trying to win a silly rhetorical argument, because they know for certain that they can't win in a sensible argument.  Just another silly and pointless word game.
    There are certainly people with good sense and an understanding of the event that we should probably at least pay attention to (Bob Hunt, for instance). But snipers from the sidelines, people who don't fly now but "I might be interested if you changed the rules" or using sophistry to try to find a "gotcha" (frequently so they or their buddies can make money selling airplanes) - dismiss out of hand or ignore them.
   I think many times we make a big mistake as a group bothering to treat obviously silly points like they were sober truth - instead of just blowing it off.
« Reply #65 on: April 29, 2022, 12:24:40 PM »
where can i get the set of rules for appearance points?
looking forward to do something similar here in brazil
Beyond the AMA rules it's all tribal knowledge, and inexperienced judges following experienced judges until they, too, are experienced.
Personally, and I'm just a local yokel not a Nationals judge, when I judge for appearance I'm looking for flaws, and I'm looking for a plane that's subjectively pretty.
So a plane that's absolutely flawless, and has a nice color scheme is going to get 19 or 20 points from me.  I'm not a big fan of undue panel lines, or other complication in the color scheme that's just for the sake of complication.  If your complicated color scheme looks ugly to me or there's so many panel lines I think it detracts, rather than adds, you may get a lower score than the next guy who has a simple but pretty (to me) color scheme.
If you want to start the ball rolling in Brazil, then the best thing you could do would be to come up and visit.  Next to that, get some of the people around you who make the best-looking planes, and see if you can get them to judge for appearance.
I think if I had any personal guide at all, it'd be something like:
First five points for the attempt.  I think someone would have to show up with the World's Rattiest Airplane to get just five points from me.  If all the wheels are different sizes, and the finish is a patchwork of monocoat, silkspan & dope, shipping tape, and maybe an unpatched hole or two, if I'm on the verge of saying "nope, you can't fly, it's going to fall apart in the air" -- then five points.
Fifteen points if you have a plane that's freshly but inexpertly covered, or that was nice ten years ago and you haven't maintained the finish.
(obviously there's a vast wasteland of judgement calls in between five and fifteen).
I think the lowest appearance score I've given someone was 11.
I'd probably max out at 16 or 17 points for a profile, unless the tank is painted in a matching color and someone obviously went to some effort to detail the engine, landing gear, and other usually-ugly exposed parts.  A profile with a matching-color tank, an engine that's either obviously polished or obviously black anodized just for looks, and has all the exposed tubing covered in metal braid with fake Aeroquip fittings on the ends -- that may get 20 points just for chutzpah, if the rest of the airframe was equally worthy.  But you'll probably have to work harder to make a profile that'll get 20 points from me than a full-fuselage model, and when you're done, I may not be judging.
(In other words -- show up with a profile and I won't say "ugh, profile, 16 points".  I'll say "hmm, engine could look better, oh my, the exposed pushrod doesn't match the color scheme, my, those pink fuel tubes look horrid against the blue and white overall color scheme", etc.)
If everything is shiny, and if I can't find any flaws (like seams, or unfinished spots where ribs meet spars, or uneven spots in silver paint, or paint lines top & bottom that don't meet at the tip), and the bottom looks nice, and the color scheme isn't too bad -- 20 points, and good for you!
Offline EricV
« Reply #66 on: April 29, 2022, 12:55:33 PM »
I was always under the impression, and it seems to hold true in my experience at the 180 building for AP day (with a relative hack like me being able to garner 17AP being the proof), that the simpler you kept it, the less opportunities you give the judges to ding you an AP point. IE: Lots of panel lines, more opportunity to ding you for a wavey line or X'ed line intersection. More trim colors, more opportunity to ding you for a raised paint line bump, color bleed, etc. It can work against but also for you too, a busy scheme can help hide surface variations, etc. too. I think of it just like one of the maneuvers, the AP judge is starting with perfection, and deducting from there. Give him less to deduct.
The trick is to do good carpentry work to start with so as to minimize fill, which can / will shrink and show over time, block sand and level everything, including trim colors edges at the appropriate stages. If you are trying to keep it light, (who isn't?) picking the time to stop filling is very tricky and takes experience to know when you are 99.9% filled, and you know that paint & clear will take that last bit out...I'd rather error on the side of having a little grain show than have a chunky monkey, but that's me. As long as you block sand the clear and put a second coat of clear so the clear itself is flat/level before you buff a shine into it, grain in the color underneath is very hard to see.
Picking a scheme and colors to your best advantage, not just for static judging, but for in-flight as well, could be a consideration if you like playing that game. Long straight lines on the fuse can give the impression of a flying yard stick and make your flats look flatter, but can also make your rounds look less than round, and if you make an over turned square, it can emphasize your dropped tail, and so can a flashy tail paint scheme. A descending line can make it look like you flying tail low, etc. You get the point.
It's all give and take and calculated risk, and is part of the fun of building a better mouse trap. It's showmanship, art, sport, strategy, etc all rolled into one and what makes the event such a fun challenge that people chase it their whole lives, like Jack Lemon still chasing that perfect golf game at the end of Bagger Vance, LOL! Do tempers flare and people feel slighted at times? Sure! Do they get over it and keep having fun? YUP!
That may all sound like total BS to some, but it's been my personal take and has worked well for me. YMMV.
EricV
« Reply #67 on: April 29, 2022, 02:22:12 PM »
It's but an Impact of the mind, a false creation, Proceeding from the heat-oppressèd brain.
« Reply #68 on: May 03, 2022, 10:54:46 PM »
Yes. Thank you Howard. I was having a Macbeth delusion. Again.
Online kevin king
« Reply #69 on: May 04, 2022, 12:58:51 AM »
As Windy pointed out, Having the bottom painted just like the top as opposed to nothing on the bottom really increases the Wow factor and i definitely agree! If the bottom of your plane looks as nice or nicer than the top of the plane beside it...You're going up a Row. I love it! 😁 Practice on the bottom then knock it outta the park on the top. The fastest way to separate the men from the boys is ask to see the bottom of their plane.
Kevin
« Last Edit: May 04, 2022, 03:33:35 AM by kevin king »
« Reply #70 on: May 04, 2022, 08:52:27 AM »
one of the best things iv´re read in years, and this is not only model related, anything "web" can benefit from this.
« Reply #71 on: May 04, 2022, 09:13:38 AM »
At contests in St Louis, they judge the model just before you start it, in the circle, like the rules say. At another contest, farther west, I found begging will get me an 18 vs a 17 for appearance points. I think the judge  did this just to shut me up.  LL~ LL~ LL~ LL~ LL~
Back in the day, when they did the 16-40 point thing, the judge would just walk by when you were fueling and write down a number just like the other fifteen 4-point stunts.
If you argued for one more point on appearance, you might get the one point and lose a lot more than one point from the other 600 judgement points.
« Reply #72 on: May 10, 2022, 09:44:00 AM »
I have been traveling for the past several weeks and missed out on this discussion.  Since Brett brought up the "guide lines" that were written several years ago regarding appearance judging, these are attached.  This package was prepared by Charles Reeves and myself after a Nationals more than a few years ago.  Charlie and I did the appearance judging at several Nats.  One of those times, there was an uproar created when a particular model received only a moderate number of appearance points.  Its builder had received the Concours award at the previous Nats.  At this Nats, the builder had a new airplane.  It was quite attractive, in fact from a distance, it was just outstanding.  However, the bottom of the airplane was not finished in the same manner as the top and there were other quite obvious flaws in the construction and finish.  The Event Director asked us what we saw in the airplane.  We pointed out why we made the assessment we made and he understood  our score.  Nevertheless, there was a considerable discussion on the forums about the lack of any written standards on how appearance should be judged.  So, around 2001, Charlie and I prepared an outline of what we considered to be a reasonable guide on how appearance of a model could be judged.  This outline was published in Stunt News and later, it was published in an issue of Flying Models.  This package was not intended to be a hard and fast "rule" on appearance judging.  It was intended to serve as a guide for the various factors that could be considered while assessing the number of appearance points for any given model given what the rule book contains.
One interesting side note here regarding cockpit detail.  Clear canopies, painted on canopies and cockpit detail is discussed in our package.  Is a lot of cockpit detail necessary for maximum appearance points?  I think not.  I can remember at one Nats when I was an appearance point judge, there were maybe five airplanes on the front row, like the 19 point row.  Three of those airplanes had painted on canopies.
Here is the package that Charlie and I prepared at that time.
From about 2001:
There have been some questions and discussions of the method of appearance judging at the recent Nationals, and in this article we will attempt to explain how we have done it for the last three years.  In 1999, Arlie Prezler, Keith Trostle, and Charles Reeves did appearance judging.  In 2000 and 2001, in Arlie’s absence it was done by Keith, and Charles.
In most local contests, the appearance is judged just prior to the contestant’s first flight, many times with the lines hooked on and the starting equipment close at hand.  However, at the Nationals the judging is done on the afternoon prior to the start of flying competition, and all planes are judged together in one room in a two to three hour period.  Initially during this process, the planes are roughly grouped with the better planes in the front of the room and the others toward the rear.  Then each plane is closely inspected both on top and on the bottom for the quality of workmanship and its overall appearance for its final placing in the group.  In general, the front row will be 19 or 20 points with the rows behind it receiving fewer points, as the judges deem appropriate.  Only after the planes are arranged in the rows of similar quality are points assigned to each row.  Sometimes there are enough planes of similar quality that two rows will be assigned the same appearance points.  The appearance points assigned to a particular airplane/row in this process are relative to the appearance of other airplanes/rows.  There is no set standard that establishes what score a model will or will not receive based on specific aspects of a model’s appearance.  We emphasize that no particular plane is given a certain number of points unless it is judged to be so outstanding that it is given a perfect 20 point score.  Similar points are given to each group of similar quality.
The inspection of each plane is as thorough as can be done in the time period allowed.  In most cases, a particular plane is inspected several times prior to its final placing.  Both judges inspect and agree to the placement of each plane before its final placing, asking each other if the plane is where it should be placed, or should it go one row forward or one row backward.  They also consider if there is a plane in the row ahead of it or behind it that should take its place.
The quality of the workmanship is judged by many factors.  Some of these are listed below.  This list is not all-inclusive, but is our interpretation of craftsmanship and aesthetics that determine the appearance of a model.
Finish
If the plane has a painted finish, was enough paint put on the bottom of the plane to fill the grain of the wood or the pores of the covering material, or was just the top of the plane filled, painted, and rubbed to a high gloss?  The bottom is judged just like the top, and the better planes look just as good on the bottom as they do on the top.  We realize that sometimes less paint is applied to the bottom than to the top to keep weight down and improve the flying ability of the plane.  That may help the flying, but it doesn’t help the appearance!  It’s the pilot/builder’s choice.  Models with film covered surfaces can receive maximum appearance points if the application of the film is accomplished in a manner that shows skill the overall appearance is attractive.
Gloss
Some paint schemes call for a high uniform gloss over the entire airframe.  Other color schemes/airplane designs can be awarded high appearance points with a semi-gloss or even a matte finish if the finish is uniform and appropriate for the model and/or paint scheme.  Inappropriate gloss of lack thereof, or the non-uniform appearance of the finish will result in loss of appearance points.
Color Trim
The color trim is judged higher if there are no places where the color has bled under the masking material, the adjoining trim colors such as checker trim meet properly, the edge is not discernible to the touch, and lines such as pin stripes are straight and not irregular in width.  Use of many colors do not make a first class color scheme.  Many colors applied well in and aesthetic manner do warrant consideration of higher appearance points.
Panel Lines
If you are going to put panel lines on your plane, make sure that the lines do not cross where they are not supposed to, that there are no runs under the straight edge, that the ends meet where they are supposed to, and that the screw slots start and stop where they are supposed to.  Again, lots of panel lines do not make a first class job.  Lots of panel lines done well do add to the appearance of most planes.
Construction
Quality of the fit of components, glue joints, alignment, symmetry, and straight/unwarped flying surfaces all contribute to the appearance of a model.   Poor construction techniques that detract from the appearance of the model will result in a loss of appearance points.  An example would be flaps that are tweaked unevenly, or a tab added to a flap to correct a warped wing.
Cowl and Removable Panels/Components
A nicely fitted cowl and any other removable components with closely fit and barely visible parting lines and hidden bolts or at least flush mounted attaching bolts/screws are  judged higher than a poorly fitted ones and/or those attached with visible bolts and/or screws, Particularly if the bolts/screws extend beyond the surface of the airframe.  Flush or hidden methods of attachment are judged higher than extended and/or visible bolts, screw heads or threads.  Uncovered access holes are a cause for loss of points.  On some planes, the cowl extends or panels are used to cover the pipe tunnel (if the plane is so equipped), and if well executed will be judged higher than models with an open pipe tunnel.  Generally accepted and uniform clearances around the power plant components that extend beyond the cowling such as the engine head, glow plug, needle valve, muffler or pipe exhaust are judged higher when done well than if such openings are wide open or not executed well or if the entire engine area is uncowled.
Landing Gear
A landing gear bolted on with no cover over the bolted connection is not judged as highly as one that is covered, with bolts hardly visible, or not visible at all as in some cases such as permanent gear.  Socket head bolts used as axles on aluminum or carbon fiber gear should be cut off flush with the nut and filed or polished for maximum points.  Wheel pants attached with a couple of screws with visible heads not flush with the mounting surface are certainly not judged as highly as those faired and filleted to the landing gear for a permanent attachment.  Removable wheel pants that show a high degree of workmanship will be judged higher than those that appear just bolted onto the model.  Wheel well covers and landing strut details if well executed will receive more appearance points that a poorly executed assembly.  A tail wheel is judged higher if the attachment is not visible, or is at least recessed and faired in.
Hinge Lines
Close fitting hinge lines with no paint sticking in them are judged better than widely gapped hinge lines with paint broken loose from the surfaces.  Some pilots use hinge line tape to close the gap.  That may help the flying ability of the plane, but it doesn’t help the appearance.  In the case of cloth hinges, no deduction of appearance points will result if their installation is neat and consistent with the overall appearance of the model.
Canopy/Cockpit
Well-executed realistic cockpit detail enhances the appearance and contributes to the award of more appearance points.  Bare, few, or poorly executed cockpit details detract from the appearance of a model.  However, it is possible to have a Precision Aerobatic model design that does not incorporate any semblance of a cockpit or canopy, yet can receive maximum appearance points.  This could happen if the model design is clearly for the function of flying Precision Aerobatics and its appearance clearly not be enhanced by the addition of a cockpit and/or canopy.  A nicely fitted clear canopy with interior cockpit detail is judged higher than a painted canopy.  However, a painted canopy with a simulated frame that appears straight and finely masked is judged higher than a clear canopy not faired in or poorly attached and finished.  For instance, a canopy just glued on top of the fuselage with tape poorly covering the edge of it shows poor craftsmanship.
Spinner and Propeller
A very closely fit spinner (or spinners) that matches the contours of the model is a sign that the pilot has worked hard to fit his engine(s) and spinner(s) to the front of the plane.  A uniform 1/32” gap between the back of the spinner(s) and the nose ring(s) is excellent.  A 1/8” gap isn’t.  The spinner(s) should be cut to fit the propeller(s) closely, and highly polished or finished in a manner consistent with the rest of the finish/design of the airplane to get maximum points.  The propeller(s) should be free of obvious service wear and tear.  It is to be remembered that the propeller(s) installed for appearance judging is(are) to be the same propeller(s) or exactly similar in appearance to the propeller(s) used for the competition flights.
Fillets
Are the fillets smooth or bumpy?  Do they have paint bubbled over them?  Do they have pits in them?  Are they symmetrical and uniform?  The smooth and uniform fillets with no paint bubbles or pits are judged higher.
Details and Protuberances
Other details that might appear on the model not described in the preceding sections could include but not be limited to visible provisions for an adjustable tip weight and adjustable leadouts as well as visible tank vents, vent lines and fuel lines.  Though these elements may be inherent to the overall function and/or look of a particular design, their appearance, if not executed in a neat and workmanship like manner will be cause for loss of appearance points.
Wear and Tear
The model is judged as it is presented to the judges, not as it might have appeared at some earlier time.  Visible service wear resulting in such things as scrapes, dings, weathering, age discoloration and deterioration, finish erosion due to fuel spills, and noticeable repairs all result in lower appearance points.
Aesthetics
The judges try to ignore their own prejudices and preferences and asses the appearance of an airplane on the basis of what should be accepted as reasonable standards of visual appeal.  However, some color combinations, decoration schemes and component shapes just do not fit on a model airplane regardless of how well the airplane has been constructed and finished.  Simply stated, a model that looks attractive will receive more points than one that is not attractive.
(As a literary work, this paper would not score very high in a writing class.  We have some inconsistencies where we use passive/active sentences and using past and present tense.  Some of the sentences are too long.  But if the purpose is to outline some guidelines that we use when we judge a model for appearance, we think this provides a basic foundation for that.)
« Last Edit: May 11, 2022, 08:48:50 PM by Trostle »
« Reply #73 on: May 10, 2022, 11:02:36 AM »
      And like the Junior problem, this is nothing new! You should read some of the letters to the editor in the model mags when Top Flite started to come out with their molded sheet parts and machined leading and trailing edges!! Some of those guys were pretty hot under the collar!  Top Flite's line of C/L scale kits was a particular target. What we call "ARC" models these days aren't new either. Cavacraft and a few others had kits with constructed sub assemblies and only needed to be covered and assembled.  I have an SE-5A ( or is it a Fokker D-7??) like that and it is actually pretty nice., So, really nothing new, but time and technology really kicked it up several notches.
« Reply #74 on: May 10, 2022, 11:39:11 AM »
    Right. And, always recall that this argument is almost entirely a matter of people exaggerating the issue or simply making stuff up from whole cloth to try to win the argument. A few responsible people also think we should get rid of it and make arguments based on their legitimate perceived points, but they are greatly in the minority and they don't make fools of themselves by making ridiculous wild claims and pointing the finger at people.
    Almost everything you see, however, is a few people who are not really involved in stunt, or hanging around the fringes, try to annoy the rest of us to death, hoping  that the rest of us get sick of it and give up. Unfortunately, this sort of thing has *kind of* worked in the past and we have indulged some of the same people and people using similar tactics on other topics - greatly to the detriment of the event. This sort of appeasement had the expected effects - emboldened them to try again.
     Of course, the line was crossed long ago, and now they have far less chance of success than ever.
« Reply #75 on: May 10, 2022, 11:58:32 AM »
Referring to Keith's last post about his and Charlie's experiences, I had the honor, pleasure, and whatever super adjective you wanna use to judge two years in a row with Charlie and Jim Lynch and if anyone ever doubted the integrity and knowledge of those two, don't.  I have never enjoyed judging anything as much as I loved that with them and the learning experience those two nats were!  The outstanding feature of each year was the common sense approach of those two joined to the care and honest interest in each and every airplane.
You wanna learn about judging appearance points, go see Charlie.  (And Keith.)
« Reply #76 on: May 10, 2022, 02:36:47 PM »
I had the top and bottom match and Phil Granderson berated me for not having the patterns meet at the leading edge, hence not meeting JCT standards.  Top and bottom patterns meet at the leading edge of my new dog.
« Reply #77 on: May 10, 2022, 04:49:40 PM »
But do they meet at the trailing edges?
A note on undersides of planes:  At local contests, where we all more or less know each other, I'll almost always judge the appearance of just the top of the plane -- because I'm lazy.  The one time they allowed me to judge appearance at the NW Regionals, we spent a lot of time looking at bottoms, and boy, were we judgy.
Online kevin king
« Reply #78 on: May 10, 2022, 11:48:58 PM »
Atta boy Howard! 😁👍I must have touched up and resprayed the invasion stripes on my Spitfire 10 times trying to get the wing and flap's invasion stripes to come out correct at the hinge line top and bottom.
« Last Edit: May 11, 2022, 12:29:36 AM by kevin king »
« Reply #79 on: May 11, 2022, 04:52:12 PM »
This talk, mostly towards the bottom of the list, kind of got lost in the details.
Went to a speed limit combat event a couple weeks ago.  I had two planes and no matches for over a year and was still very tired from illness.
I had fun and scored some good points but the best part was a young gentleman named Jesse.  He wondered onto the field about half way through.
He stood around for awhile watching and then started questions-  Where do you get the planes and motors?  What's the fuel made of?  How do you control them.
He kept making comment like "this is really neat" or" so you fly here often?
He had walked a couple miles through the Pinelands and found the field by hearing!
Anyway, we're going to try and keep in touch for later this year and maybe next year.
Younger people who are smart and inquisitive and know what they want are still around.
« Reply #80 on: May 18, 2022, 01:26:32 PM »
From about 2001:
Finish
Gloss
Color Trim
Panel Lines
Construction
Landing Gear
Hinge Lines
Canopy/Cockpit
Fillets
Wear and Tear
Aesthetics
thank you Trostle, that´s exactly i was searching for!
