  • June 15, 2025, 04:26:13 PM
Author Topic: Prop Chart  (Read 1694 times)
Offline Mike Griffin
Prop Chart
« on: May 28, 2020, 08:31:01 PM »
Does anyone have a prop chart that give you suggestions on what size props to use specifically for control line engine sizes?  I have seen one in the past for RC  but cannot seem to find it and do not know if it would be the same for control line.  Thank you
Offline Tony Drago
Re: Prop Chart
« Reply #1 on: May 28, 2020, 09:08:41 PM »
Would this help
Re: Prop Chart
« Reply #2 on: May 28, 2020, 09:44:13 PM »
Would this help
Yes Tony, thank you.
Re: Prop Chart
« Reply #3 on: May 29, 2020, 12:50:27 AM »
For the most part, the recommended props would not be used for stunt.
    For exampleI have run 61s since 1999, I use 12.5-3.75 3-blades. It easily handles more diameter, however, that has too much impact on the cornering.
   None of these charts can be compatible with every application just considering engine displacement. If you have an engine in mind, I am sure we can figure out a good starting point.
Offline Oldenginerod
Re: Prop Chart
« Reply #4 on: May 29, 2020, 02:09:07 AM »
Trying to insert an image of an Enya prop chart, which shows differences for R/C, C/L & FF applications.  I can't seem to get it to attach the image.  I watched a tutorial and got to the point of "Choose File", which I did, but then there seems to be no way to then attach it.  The name of the file is sitting in the "Attach:" box after the "Choose File" button, so where do I go from here?  Using an iMac.  Can someone help please?
Re: Prop Chart
« Reply #5 on: May 29, 2020, 02:10:37 AM »
Ok, forget what I just said.  Seems it attaches automatically, but can't be previewed by the look of it.
Sorry the picture is so poor.
Re: Prop Chart
« Reply #6 on: May 29, 2020, 02:11:41 AM »
Then there's this one.
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Prop Chart
« Reply #7 on: May 29, 2020, 05:35:38 AM »
Hello
I think Brett is correct in that a simple chart is not practical here as not only do engine types vary but the make and design of props varies so much.
Eg Fox 15 baffle, OS FP15 and ST G15 can all end up with very different props to suit their power band and application.
Even in stunt a ST46 wants a very different prop to a AX46 .
The exhaust system even makes a big difference , maybe a tacho would be just as useful as a chart?
Regards Gerald
Re: Prop Chart
« Reply #8 on: May 29, 2020, 11:48:34 AM »
Thank you Brett,
These are the engines I use: (mostly)
OS LA .46
G21 ST.46
ST .51
Any help would be appreciated.
Re: Prop Chart
« Reply #9 on: May 29, 2020, 11:58:34 AM »
I can't speak to the other two engines, but for a 46LA you want pitch between 3.75 and 4.5, and diameter around 11-12.
The reason for the range is that on a really light plane you want the APC 12.25x3.75, and on a heavy plane you need to unload the engine by going to something like the APC 11x4.  In between (i.e., my porky 54 ounce Twister) you want the ThunderTiger 11 x "5" (with the pitch in quotes; folks who've measured it say it's really a 4.5).
I wouldn't go outside of the APC 12.25x3.75, 11.5x4, 11x4, and the TT 11x5, at least not until I was more of an expert than I am now.
Re: Prop Chart
« Reply #10 on: May 29, 2020, 03:28:44 PM »
Thank you Tim.
Re: Prop Chart
« Reply #11 on: May 29, 2020, 07:48:21 PM »
The Thunder Tiger 11 x "5" is labeled as 4.5" pitch, so I think you should look at your propeller with a magnifier, Tim!
And, I have to ask Mike G. which ST .51 he uses, because I know of at least 4 Super Tigres of that displacement, and more would not surprise me.   D>K Steve
