  • July 15, 2025, 06:33:27 PM
Author Topic: Anyone flying a K&B 61 in stunt? How'd it do?  (Read 1443 times)
« on: November 08, 2023, 06:41:34 PM »
I've got a friend with one of these who wants to build a stuntship for it.  Anyone fly stunt with one of these?  How'd it do?
Re: Anyone flying a K&B 61 in stunt? How'd it do?
« Reply #1 on: November 08, 2023, 07:23:46 PM »
I haven't flown one but a few years ago someone was flying one at a contest I went to and I was impressed with how it sounded and flew.  Sort of have wanted one to mess with since.  I have several of the regular K&B and Veco .61s.  They are well built-just sort of heavy.  I'd think they would perform along the lines of the Tigre .60 if you weren't concerned about the weight.
Offline Norm Faith Jr.
« Reply #2 on: November 08, 2023, 09:07:24 PM »
I have flown both in my Thai Angel. The Clarence Lee version and the Twister version, both from MECOA. The Twister engine, IMHO, had a little too much vibration for me. The Lee version is better in the area of vibration, but is extremely sensitive when it comes to venturi's and NVA's. I changed the OEM out to a ST NVA and Jim Lee Venturi. Both versions are not hurting for power. I also did away with the OEM muffler and went with a Randy Smith Muffler. Most of my engine runs have been consistent, but I have had symptoms of "surging." Over all both are well built engines and seem to be getting better the more they are run in.
Norm
Circlepilot   AMA9376
« Reply #3 on: November 08, 2023, 09:44:06 PM »
  Russ Gifford used to use K&B .61 engines and one of his last model I saw had the Twister version in it. Like Dave says, they sounded nice and seem to have plenty of power for the big models that Rus built. I have a Twister and several other K&B/Veco .61's to try in an appropriate airplane just to experience them.
Online Motorman
« Reply #4 on: November 08, 2023, 10:39:32 PM »
I would bet that engine would benifit from a sealed front bearing.
« Reply #5 on: November 09, 2023, 05:49:45 AM »
Thanks all!  But what is a "Twister" version?  What version of K&B 61 (with the unique-looking gold head) do I have pictured in my original post?  Are your comments referring to the engine I have pictured?
Would a Legacy be a good match for it?
« Reply #6 on: November 09, 2023, 06:15:33 AM »
Scott you are showing the Twister version with the smooth gold head.
« Reply #7 on: November 09, 2023, 07:31:01 AM »
    Read any instructions or paperwork that came with the engine. The engine is called a Twister because you can rotate the head to alter the compression. There should be a special spanner wrench to fit those two holes in the top of the head. That's about all I remember about mine, and I have never run mine.  I think the .60 sized Legacy would be an excellent choice for it. You might want to think about shortening the nose a tiny bit to allow for the engine weight.
« Reply #8 on: November 09, 2023, 09:05:25 AM »
Thanks guys - this was very helpful!
