Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 22, 2025, 04:32:58 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
anybody else???
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: anybody else??? (Read 927 times)
Bootlegger
22 supporter
Trade Count:
0
Admiral
anybody else???
on:
July 15, 2011, 09:55:16 AM »
Running in a couple of S T 60's that are new, choke fuel into engine, back flip prop and darn if both didn't start and run backward!!
Has anyone had this experence???
Logged
8th Air Force Veteran
Gil Causey
AMA# 6964
Balsa Butcher
24 supporter
Trade Count:
0
Admiral
High Desert Flier
Re: anybody else???
Reply #1 on:
July 15, 2011, 09:59:49 AM »
Yes I have, it's what happens when you store them in the same box with Cox reed valve .049s. Not really, just a little over primed, not to worry.
Logged
Pete Cunha
Sacramento CA.
AMA 57499
W.D. Roland
AMA Member and supporter
Trade Count:
0
Admiral
Re: anybody else???
Reply #2 on:
July 15, 2011, 10:49:28 AM »
The 2 that I have in R/C use and the C/L conversion from R/C( 3 engines) will run backwards all day at low RPM throttle setting. Usually can reverse the run by grabbing spinner and releasing quickly would kick them back the right way.
I find that the C/L conversion with restrictor will run backwards from back flip sometimes will die sometime will pop and run forward and some times have to stop it manually.
These engines will almost always start first forward flip if it will bump on a pull through.
Unless your finger is slow they don't bite.
Use wood prop at least until it is sorted.
Logged
David Roland
51336
Bootlegger
22 supporter
Trade Count:
0
Admiral
Re: anybody else???
Reply #3 on:
July 16, 2011, 07:42:12 AM »
Pete C, Man you just ain't right, how did you know that they had been stored in with the cox reedies??
Logged
Gil Causey
AMA# 6964
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
anybody else???
