If you ever look at the internal structure of the Flite Streak ARF nose, the faulty engineering is apparent. The nose area itself, which absorbs engine stresses, is built up, not a solid piece. I believe that even the engine mounts are not solidly surrounded by balsa. Two of the Flite Streaks that I saw fail, one my own, another a club member's, were powered by LA25s. Smooth running engines. Mine never had vibrations issues. After a 100 or so flights the noses came off both planes. Another ARF Streak, powered by an LA40, had the nose fail spectacularly, after considerably less flying. Since there is so little internal structure where stresses are highest, I advise cutting a new fues, if you expect to fly the plane long term. Also, wings and tail surfaces are good enough to survive much higher power. These planes are a gas when flown fast. Many were flown in combat at one time. Thrilling to see a Streak powered by a Fox Combat special running all out. Great fun. Also, there are no covering issues with theses ARFs. It stays stuck.
