  • July 21, 2025, 04:56:52 PM
Author Topic: After Run Oil  (Read 3750 times)
Offline Rick Henry
After Run Oil
« on: August 08, 2011, 11:34:34 PM »
I have started using 3 in 1 oil as an after run oil instead of the brand my local hobby shop sells.  I have also been told that air tool oil works well.  What do you use?
Rick
Offline BrianW517
Re: After Run Oil
« Reply #1 on: August 09, 2011, 12:49:05 AM »
  H^^  S?P Marvel Mystery Oil is my choice for decades.  :!  H^^
Offline Andrew Tinsley
Re: After Run Oil
« Reply #2 on: August 09, 2011, 03:35:52 AM »
According to most people, 3 in 1 oil is a no no. I am not sure why, but I am sure that any number of people will tell me! I use a very good quality airtool oil. It is designed for exactly the conditions we get in our model engines.
I live in UK so my brand won't be available in the US. Most people there seem to use Marvel Mystery Oil. NOTE! the ordinary Marvel Mystery Oil is NOT what you want. Only use the stuff deigned for air tools!
Andrew.
BMFA Number 64862
Offline Dan Bregar
  • Field Marshall
Re: After Run Oil
« Reply #3 on: August 09, 2011, 04:07:38 AM »
Marvel Air Tool Oil, or as George Aldrich  used to recomend, Rislone. Both will prevent rust in our engines, especially the bearings.
AMA 33676
Offline Neville Legg
Re: After Run Oil
« Reply #4 on: August 09, 2011, 04:11:38 AM »
I've used 3 in 1 for years without any problems? For long term storage, I flush them with IPA, let that evaporate and fill up with 3 in 1! I heard gun oil is ok too?
Cheers
(not) Descartes
Offline peabody
Re: After Run Oil
« Reply #5 on: August 09, 2011, 05:29:34 AM »
ATF works very well.....
Offline Dean Pappas
Re: After Run Oil
« Reply #6 on: August 09, 2011, 07:20:07 AM »
Hi All,
Mobil 1 is an excellent anti-corrosive.
The engines I ran with it had steel parts that looked brand new shiny after a whole season of heavy use.
  Dean Pappas
Dean Pappas
Online Paul Smith
Re: After Run Oil
« Reply #7 on: August 09, 2011, 07:20:16 AM »
Rislone and kerosene both work well, especially for long term storage.  3-in-1 locks up over time, but the otehr two don't.
Offline Gene O'Keefe
Re: After Run Oil
« Reply #8 on: August 09, 2011, 07:55:48 AM »
Like Dan said....Marvel "AIR TOOL OIL"  -- been using it for a gazillion years in my shop air tools & my model IC engines.
Gene O'Keefe
AMA 28386
Offline Joseph Patterson
  • AMA member- Supporter
Re: After Run Oil
« Reply #9 on: August 09, 2011, 09:08:59 AM »
  I used 3-in-1 for years in my engines, some of which were put up (2) or more yrs w/o any sticking problems. However, I always flush my engines thoroughly w/ WD-40 after flying, then  flood with the 3-in-1. Now I use air-tool oil because it is cheaper and probably inhibits moisture a little better than 3-in-1. I have had one of the very expensive after-run oils congeal in two of my Saito 40's and a couple of my 2-strokes after being put up for a year or so. Most of the guys here are using air-tool oil, or Rislone.
       Doug
Re: After Run Oil
« Reply #10 on: August 09, 2011, 11:03:31 AM »
Rislone or Randy smith's stuff,  either one.
Online Steve Helmick
Re: After Run Oil
« Reply #11 on: August 09, 2011, 11:10:50 AM »
Cheers
IPA = India Pale Ale...or IsoPropyl Alcohol?  DK^ Steve
Re: After Run Oil
« Reply #12 on: August 09, 2011, 11:48:48 AM »
Yeah...The IPA (India Pale Ale is best) but too much of it makes me seize up!
 #^ #^ LL~
Randy C.
Offline Rob Killick
Re: After Run Oil
« Reply #13 on: August 09, 2011, 12:23:49 PM »
Hi ,
I'm sure Rislone would be a very good choice for after run oil .
We used to use Rislone on our power plants ancient recip compressors , to remove carbon from the outlet valves .
It would probably work well on ringed engines , or any engine that needs a "de-gunk".
Rob K.
Rob Killick , MAAC 33300
Offline Ed Keller
Re: After Run Oil
« Reply #14 on: August 09, 2011, 01:07:28 PM »
Not sue anyone else has experienced this, but I would recommend that you remove any glow plug that you want to keep, or use. After using oil for storing the engine, or just after run anti corosion, I have found that the plug will not let the engine run correctly, but gives an erratic un-reliable run. Don't remember what the exact oil was, but I always use an old plug now, or some substitute for the plug when storing, & flush out the engine with fuel before putting in a good plug & using the engine. Regards, Ed
Re: After Run Oil
« Reply #15 on: August 09, 2011, 02:13:25 PM »
  I use air-tool oil (Sta-Lube brand because that's what I could get at Kragen's for $2) and I haven't had anything like plug poisoning with that. I really load them up, to the point that you can still smell it burning off for most of the first flight of the day.
Offline Allan Perret
  • Proverbs
Re: After Run Oil
« Reply #16 on: August 09, 2011, 02:46:35 PM »
OK, so what is your procedure for using after run oil.
Specifically, how can you get it to the front crank bearing ?
I dont think much if any will get to front bearing by just putting it the venturi.
Allan Perret
AMA 302406
Slidell, Louisiana
Re: After Run Oil
« Reply #17 on: August 09, 2011, 05:16:12 PM »
I'm with Brett - never had a plug problem, and I, too, load them up.  At least ten drops and then several flips.  when storing for any period of time, I use the starter to turn them over, ten MORE drops, and the starter again.
In the spring, I remove the prop, turn it with the starter, replace the prop, burp it, and fly.  Been doing it that way for a couple of decades now.
Offline George
  • Love people, Use things.
Re: After Run Oil
« Reply #18 on: August 09, 2011, 05:40:31 PM »
After the last run, I disconnect the fuel line, connect the glow driver and try to start the engine to burn off the last of the fuel in the crankcase. Remove the plug and squirt a few drops in the plug hole and intake (or exhaust if you don't remove the plug. I flip the prop after each squirt. Of course there are other ways, but this is how I do it.
I think the oil will get to the front bearing just like it does while running.
I like Rislone or air-tool oil. By the way, a few years ago a rep from Marvel Mystery Oil posted that Marvel Air Tool oil is MMO with rust inhibitor
George
George Bain
AMA 23454
Re: After Run Oil
« Reply #19 on: August 09, 2011, 07:20:46 PM »
One trick on four strokes is to load it up with oil thru the crank case vent, and then plug the vent and turn the engine over untill it forces oil out the front brg.
Re: After Run Oil
« Reply #20 on: August 09, 2011, 07:28:22 PM »
When you hang the plane by the tail, nose down, the oil will get to front bearings.   H^^
Offline Rick Henry
Re: After Run Oil
« Reply #21 on: August 09, 2011, 11:13:05 PM »
Thanks for the input guys.  I think I will pick up some air tool oil and give it a try.  I also hang my planes from the tail.
Rick
Offline Geoff Goodworth
Re: After Run Oil
« Reply #22 on: August 09, 2011, 11:33:07 PM »
G'day guys. Rislone has only just become available in Australia—and I've used auto transmission fluid until now.
WHich Rislone is the preferred? Two stroke oils or one of the oil treatments?
Offline John Eyer
Re: After Run Oil
« Reply #23 on: August 10, 2011, 07:16:51 AM »
d
« Last Edit: November 22, 2012, 11:15:35 AM by John Eyer »
Offline Brian Hampton
Re: After Run Oil
« Reply #24 on: August 10, 2011, 11:17:10 AM »
I use an ARO that mixes with the fuel so it's always liberally spread throughout the engine. I call it castor oil :). And before anyone jumps down my throat, there's a difference between an After Run Oil and a long term preservative.
