  • June 22, 2025, 02:24:44 AM
Author Topic: K 77  (Read 946 times)
Offline Donald Main
K 77
« on: April 24, 2019, 11:31:10 AM »
I received my back plate for the K 77 and put a 12 3/16" x 4.4" prop and fueled it with no nitro fuel and she ran line a top. Working on an Impact to put the motor in. More pictures later.
Offline Pepe Llopis
Re: K 77
« Reply #1 on: April 24, 2019, 11:42:08 AM »
Very nice but without nitro fuel and without pipe, why use this engine instead of others like the stalkers or discovery retro?
Offline Donald Main
Re: K 77
« Reply #2 on: April 24, 2019, 12:05:29 PM »
This motor is made by Stalker with the specs coming from Kaz Minato. I think it was his answer to a PA motor. I have a pipe for it but was getting my break in runs done. The manufacture recommends using a FAI type of fuel. A slightly better back place pic.
Re: K 77
« Reply #3 on: April 24, 2019, 01:04:51 PM »
   Please note this thread, it is not a PA75 replacement:
https://stunthanger.com/smf/open-forum/k77-shunt-engine-(replacement-parts)/
   and will apparently be damaged and wear rapidly if you try. I have no comment on how it works as a muffler motor with high pitch, since no one appears to be running it as intended, or at least not around here.
