  • July 19, 2025, 01:15:22 AM
Author Topic: This plug-in not supported  (Read 599 times)
Offline big ron
« on: March 18, 2015, 07:52:04 PM »
May not be the right place but  some videos that are posted on here has This plug-in not supported attached to them am I doing something wrong?
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline qaz049
Re: This plug-in not supported
« Reply #1 on: March 18, 2015, 09:23:39 PM »
Yes the problem is at your end. You need to tell your browser which video plugin program you wish to use to view them. Can you view any videos? If the problem videos are on youtube then just google something like "youtube video  plug-in not supported" and follow the suggestions given there. Otherwise ask any 12 y/o boy for help. They know these things intuitively these days :-)
If you are using Firefox, just go to the Tools dropdown menu and select Options, and then Applications..
A new small window will open. Scroll down till you see the word Video mentioned in the left hand column. Select the RHS of the line it's on.
The screen should look like the image below.
On my machine it was the third line down. Another smaller Window will open. Here you do your Plugin choosing. The problem may be that none has been selected. Select either Realplayer or Quicktime if they are not selected. Otherwise select the alternative plugin.
Other Browsers will have similar choices.
Good luck.
« Last Edit: March 18, 2015, 09:53:49 PM by qaz049 »
