  • July 26, 2025, 06:57:49 AM
Author Topic: Ball barrings  (Read 1051 times)
Offline Bootlegger
Ball barrings
« on: July 28, 2014, 12:45:12 PM »
 How do you fellows order from Boca bearings?   Do you use the bearing part number, then ask for a cross reference, or another method?
      Thanks a lot
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Dennis Toth
Re: Ball barrings
« Reply #1 on: July 28, 2014, 01:41:41 PM »
The easiest way is to call them and they will get the correct bearing to you. Second option is to go to their website and look up the bearing by engine make and model. They have a pretty good chart. Third option is to measure the bearing you have and either find it in their charts or call them. They are friendly guys and very willing to help with information and options on grades/class of bearing, materials and technical specs.
Best,      DennisT
Re: Ball barrings
« Reply #2 on: July 28, 2014, 10:18:33 PM »
They were very helpful when I ordered bearings for my Thunder Tiger Pro 25. The most inexpensive bearing they sell is better quality than the OEM part.
Rusty
Offline Bootlegger
Re: Ball barrings
« Reply #3 on: July 29, 2014, 11:34:31 AM »
 Thanks Guy's,
  I ordered some this morning. Again thanks to y'all and Sparky
Gil Causey
AMA# 6964
Re: Ball barrings
« Reply #4 on: July 29, 2014, 12:11:31 PM »
Thanks Guy's,
Hi Gil
If your ordering ones for the  TT 36, I hope you get the right ones, there are more than 1 type/size in that engine , let me know if they don't fit
