  • July 27, 2025, 10:09:19 AM
Author Topic: Inexpensive fuel line  (Read 1952 times)
« on: December 23, 2013, 12:51:56 PM »
Inexpensive fuel line Can be found at Home Depot.  In the plumbing department I spotted this 'micro-fuel line' in IDs of 3/32", 7/64", and 1/8".  Ten foot roles are $3.99.  It looks and feels like the old Perfect line we got at the hobby shop except it has an orange cast to it.  I still like silicone but got some to try out.  Even if you have to change it often its surely cheap enough.  Won't pin-hole like silicone either.  Being called a 'fuel line' maybe it will stand up to some of the stuff we are known to cram down the pipe.
Re: Inexpensive fuel line
« Reply #1 on: December 23, 2013, 01:19:04 PM »
« Reply #2 on: December 23, 2013, 03:03:49 PM »
 If it's Tygon type or a similar compound, that may be why they colored it and call it "fuel line," because it is for kerosene. Just a guess. Should work for glow fuel if it is.
Offline Norm Furutani
« Reply #3 on: December 23, 2013, 03:15:22 PM »
Looks like its polyurethane. See http://media.wattswater.com/ES-PolyMicroFuel.pdf
Norm
« Reply #4 on: December 23, 2013, 03:26:18 PM »
So, where is micro fuel line used around the home?
Offline Russell Shaffer
« Reply #5 on: December 23, 2013, 04:11:12 PM »
In your still, Tim.  It also works for Ugly Stick lead out guides.
Russell Shaffer
Klamath Falls, Oregon
Offline L0U CRANE
« Reply #6 on: December 23, 2013, 05:23:57 PM »
Dan, and all ...
I like an occasional diesel. Tygon stands up well to ether/kerosene fuels, and I expect also to gasoline-base spark fuels (? new spark OS engines, too?) A local small-engine shop (riding lawnmowers, karts, etc.) carries Tygon. Crossed my mind it might be a reasonable-price alternative to silicone for glows.
To simplify things... Only one kind of fuel line to work with... Silicone is unusable for gasoline and kerosene/ether fuels. It swells - fast and dramatically - in them.
As a test, I soaked a short piece of Tygon in 25% nitro fuel. Within a few days, it hardened and shrank. Color cleared and darkened, too.
Another source of inexpensive "fuel line" is used for aquarium air pumps. Kind of like the old, clear Perfect stuff, and hardens in a short period of time. Weeks, for example, a pre-flight inspection consideration, but at a very favorable price. Works with glow, diesel and gasoline fuels.
\BEST\LOU
Offline Richard Koehler
« Reply #7 on: December 23, 2013, 05:43:20 PM »
Thanks for the info, looks exactly like what I've been looking for!
« Reply #8 on: December 23, 2013, 07:23:21 PM »
Chain saws weed eaters and the like use tygon tubing now. It seems to hold up better than the old neoprene they use to use.
« Reply #9 on: December 24, 2013, 08:14:11 AM »
Thanks Dave, will have to stop by and get some.   I change fuel line quite a bit it seems like.   MERRY CHRISTMAS
« Reply #10 on: December 24, 2013, 09:22:45 AM »
I think it will work.  Thanks Doc.  Merry Christmas to you and to all the stunt family!
Offline bob whitney
« Reply #11 on: December 24, 2013, 09:28:42 AM »
ACE Hardware has it in diff sizes
rad racer
