  • July 27, 2025, 10:07:30 AM
Author Topic: tool to help accurate building (with pics)  (Read 1559 times)
Offline pipemakermike
« on: December 22, 2013, 08:25:35 AM »
Whilst juggling with the tips and ribs of the teosawki I had an idea.  a month ago I bought a cheap tool designed for setting helicoptor blades (the model kind) and I have thought of several ways of using it but for the current requirement I came up with a very simple jig.
I made a very precise rectangular plate in 1/4" ply making very sure that the sides were parallel and perpendicular.  I then fitted 2 accurate pins for the device to clip onto.  It has worked very well.  It has proved a very easy way to make sure that the tip ribs are parallel with each other and with the fuselage.
The total cost was $16 for the device from EBAY and about 30 mins work
Mike Nelson
Offline Will Davis
Re: tool to help accurate building (with pics)
« Reply #1 on: December 22, 2013, 09:50:49 AM »
Nice tip,
Will Davis
"Carolina Gang"
Offline Andrew Tinsley
« Reply #2 on: December 22, 2013, 10:26:05 AM »
Hello Mike,
I am not into model helicopters, so I am not familiar with the cheap pitch gauge(?). Is it simply an electronic spirit level. If not what exactly is it?
Andrew.
BMFA Number 64862
« Reply #3 on: December 22, 2013, 11:17:24 AM »
Yes just a really cheap and light electronic spirit level with a clip feature but so cheap that it would  be rude not to buy one  It only works from 0° to +90° or -90° and its resolution is 0.1°
I was originally intending to extend it for checking the accuracy of wings and tails and making sure that the incidence of all parts of a model are true
Mike Nelson
« Reply #4 on: December 22, 2013, 11:40:52 AM »
Thanks Mike,
My immediate thoughts were to use it to ensure wing incidences etc were correct, so you are a jump ahead of me! I also build vintage stuff, so my wing and tailplane incidences are not always 0-0.
  Is this another Hobby King offering? If not maybe you could point me in the direction of a UK supplier?
Andrew.
BMFA Number 64862
« Reply #5 on: December 22, 2013, 11:43:11 AM »
Hi Andrew
I got mine from EBAY and they are still available and a dollar cheaper than when I bought one:-
http://www.ebay.com/itm/171034746472?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Mike Nelson
« Reply #6 on: December 23, 2013, 03:37:35 AM »
Thanks Mike,
I think I shall get Santa to bring me one!
Happy Christmas,
Andrew.
BMFA Number 64862
Offline dave siegler
  • sport flier
    • Circlemasters Flying club
Dave Siegler
NE9N extra class
AMA 720731
« Reply #8 on: December 24, 2013, 04:05:15 AM »
I just use my iphone
Well, I tried but couldn't get a signal indoors. Perhaps I am on the wrong network<G>
Mike Nelson
