  • July 04, 2025, 09:07:03 PM
Author Topic: Anchor Bond alternative  (Read 1110 times)
Offline Paul Pomposo
« on: January 11, 2016, 12:45:50 PM »
I'm getting ready to sheet a foam wing. Last time I did, I used Anchor Bond epoxy. Since this is no longer available, I am looking for the best thing to use as an alternative. Any thoughts?
Offline Phil Krankowski
Re: Anchor Bond alternative
« Reply #1 on: January 11, 2016, 01:11:29 PM »
West System and System Three are two of the best epoxy products available.
I have used West System for many things.  They have a full line of additives, although you can use other brands of additives.
http://www.westsystem.com/ss/
I have heard and read good things about System Three, but have not used it myself.
http://www.systemthree.com/
However I have not done the task you are about to...
Phil
Offline Mike Griffin
« Reply #2 on: January 11, 2016, 04:29:17 PM »
I wholeheartedly agree with Phil.  West is the best....hey, that rhymed.
« Reply #3 on: January 11, 2016, 06:28:13 PM »
Thanks! Used the 105 before for carbon gears. It did set up well using the bagging system. I'm curious if balsa skins will have the same result.  mw~
Offline Mike Scholtes
« Reply #4 on: January 11, 2016, 07:16:26 PM »
Hi Paul:
I use West Systems epoxy and can recommend it highly, though have not used it to attach balsa to a foam core.
You best source is probably Bob Hunt, who has been doing sheeted foam wings for about 50 years give or take. I suggest looking at his web site or giving him a call. I have a set of Bob's sheeted wings/stab/elevator and they are excellent.
