Frank,
I did similar one, but not the same implementation. Mine had a piece of CF tube down the wing and you used a long "T" handled 3/32" hex wrench to set the tab. A screw went through an aluminum plate glued to the tab and into a chunk of hardwood with a "T" nut. Worked fine. I also had one that had a sort of circular aluminum plate on the tab and it swung through a hardwood block with a nut. There are lots of ways to attack this issue. The easiest with the most leverage is still the horn with the clevis setup shown above.
