  • June 22, 2025, 06:38:24 AM
Author Topic: OS LA .40 Back plate and OS NVA???  (Read 1778 times)
« on: October 14, 2006, 06:37:40 PM »
Any one know the part # for the back plate and standard NVA for the OS LA .40?
I want to get rid of the remote NVA and get a metel back plate.
I have been chasing engine runs all day and I have had it.
PS- I tried searching the site but came up empty.
Offline Leester
Re: OS LA .40 Back plate and OS NVA???
« Reply #1 on: October 14, 2006, 06:41:23 PM »
Paul:  Cover plate is 23307000, NVA is22311000
Leester
ama 830538
« Reply #2 on: October 14, 2006, 06:57:39 PM »
Backplate for OS .35/.40 FP fits. Tower has them in stock for $5.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCF99&P=OW   This link will give you a link to popular OS & ST needle valve assemblies, so you can get them all from Tower. I don't care for the OS NV Assemblies, tho others prefer them. They have a failure mode that ST's do not.  I'd suggest the ST G.51 unit from Tower.  http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFY25&P=M
 AP^ Steve
« Reply #3 on: October 14, 2006, 07:22:46 PM »
Steve,
Do you have to drill out the vent to get the ST NVA to fit?
« Reply #4 on: October 14, 2006, 07:33:03 PM »
Affirmative. I use a #20 drill (.161"). There are lots of .156" spraybars made, but very few .135". More options when you break one, maybe will keep you flying instead of waiting. When the OS NV assembly gets crashed, it can start working funky, not following the tweeks, changing in the air, etc. The ST types either work or are broken, nothing in between. That's good, IMO.   :P Steve
Offline Willie Johnson
« Reply #5 on: October 14, 2006, 07:39:37 PM »
Paul,
You will have to drill the case and venturi if you go with a Super Tigre.  Let me know if you need a drill bit.  I should have some extras.
Willie
Willie Johnson
AMA 774461
« Reply #6 on: October 14, 2006, 08:47:01 PM »
Not sure I want to drill out the hole. Once I do that I can never go back.
I think for now I will stick with the OS.
Leester that part number you give is for the .25, is that the right one?
Offline Leester
« Reply #7 on: October 14, 2006, 08:56:15 PM »
Paul: Yes it's the NVA for the 20-40 FPS and is used on the LA's
Leester
ama 830538
