  • June 28, 2025, 08:16:19 PM
Author Topic: Where to buy a good metal straight edge.  (Read 2143 times)
Online James Mills
« on: May 04, 2009, 10:10:29 PM »
Where can you buy a good straight edge for building and how can you tell if it's really straight or not?
James
AMA 491167
Online Geoff Goodworth
Re: Where to buy a good metal straight edge.
« Reply #1 on: May 05, 2009, 03:05:03 AM »
James
How long do you want?
While we have metal rules in sizes 6", 12", 24" and 1 metre (I am in Oz!) in my shop, when I must have absolutely straight, I use the 1200 mm aluminium frame spirit level that I bought when I built my house some years ago which has not been knocked around.
Cheers, Geoff
« Last Edit: May 05, 2009, 04:18:22 AM by Geoff Goodworth »
Offline Bootlegger
« Reply #2 on: May 05, 2009, 05:33:06 AM »
  I picked up a couple (36" & 48") at the local Home Depot store. I had to remove the cross at the end of both as they were set up to cut sheet rock and the tee was used as a guide.
  Hope that this helps.     H^^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Jim Oliver
« Reply #3 on: May 05, 2009, 08:20:52 AM »
Got mine at Home Depot, 48" and 60", without the "T".  Actually made in the USA, Lowe's had china made stuff.....
To determine straightness or lack thereof, I take two of the straight edges and lay them flat, edge-to-edge, and then turn them over and check the other two edges, again edge-to-edge.  If the edges are not straight there will be a gap between them, also use the MK I Eyeball test---more precise than you might think.
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #4 on: May 05, 2009, 09:16:53 AM »
I bought mine from Tacoma Screw, a metal and mechanical supply house. 12", 24", 36" and a 50" one. Seem prett straigh and have a thin cork backing.
Offline Neville Legg
« Reply #5 on: May 05, 2009, 11:41:14 AM »
Can't remember how I came by the one I have, but it came from the Shorts aircraft factory in Rochester! It is 36"x3" in a wooden sheathe. with Shorts W/shop No. on it! Probably used in the building of Sunderland flying boats or Stirling bombers! (I like to think so anyway!)   ;D
(not) Descartes
Offline Allan Perret
  • Proverbs
« Reply #6 on: May 05, 2009, 12:21:06 PM »
James
Use a piece of thread/string pulled taut as a reference..
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Bootlegger
« Reply #7 on: May 05, 2009, 01:34:03 PM »
  Another way to check for straightness, is that a word?, is draw a line down one side, turn it over draw another line down the same side, if one isn't on top of the other then it isn't straight...
Gil Causey
AMA# 6964
  • Proverbs
« Reply #8 on: May 05, 2009, 02:06:45 PM »
The Bootlegger is right.  And the best way to do it is put a couple of pins or nails in work top to register the straight edge against, that eliminates the parallax error if you eyeball it.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Rob Killick
« Reply #9 on: May 05, 2009, 03:32:25 PM »
Hi ,
Staedtler Mars (sp) used to make a good 36" , bevelled edge straight edge .
I'm not sure what they're worth these days (or if they still make them) , but I'm sure they're worth a "pretty penny" , yet the straight edge is of good quality .
Rob Killick
Rob Killick , MAAC 33300
