  • July 13, 2025, 07:18:38 AM
Author Topic: Would like line size advice  (Read 3366 times)
Offline Wayne Collier
« on: January 11, 2010, 09:07:56 PM »
Thanks in part to my thoughtful and loving daughter, I ended up with a brand new OS .25 this Christmas.  It is an R/C version, but since I'll probably only be using it for sport flying for the time being, I'll probably just wire the throttle open for now.  Because of other things going on at this time, I'm thinking I may get a Brodak ARF Flying Clown instead of trying to outright build a plane at this time.  Since I have never owned a .25 or a Flying Clown, I'm a little uncertain what size and length of line to use.  I would appreciate suggestions from some folks with more experience than me.
Re: Would like line size advice
« Reply #1 on: January 11, 2010, 10:52:04 PM »
Well, with the new rules on  pull tests, .012 or .015 should be strong enough, assuming the plane is light. y1 H^^
   It will be going like a bat out of hades, so I would suggest .015x62 to start. 9-4 APC, about 11,000 RPM on the ground to start, 4.6-4.8 sec laps. .012 would make me a little nervous unless they were in perfect shape.
« Reply #2 on: January 12, 2010, 03:39:20 AM »
Again, I personally have no experience with the OS .25.  Would a larger airplane be smarter?
My first thoughts had been either a ringmaster or a shark 402.  Then I thought about an ARF to save time.  Most of the CL airplanes I've owned have been either kits or scratch built.  None have been .25 sized.
Offline Larry Fulwider
« Reply #3 on: January 12, 2010, 07:53:48 AM »
Here is a quote from Brett Buck, lifted from another thread
       . . . Another off-topic but interesting point. Flite Streak ARF+25LA+9-4 APC= very good combination. This was a rear-needle engine, and despite their reputation, it was bulletproof and dead steady in the air. That's what I had found on my previous attempts with rear needles on the Fox and the 15FP, too. . . .
       . . . One it got going, it might have been as steady as the 20FP with very similar performance. For whatever reason, although it has the same muffler, it was noticeably louder. The airplane flew *great* with just one trim adjustment. It didn't turn as nicely as the Skyray but round maneuvers were like falling off a log. That's generally true of elevator-only airplanes, but this one stood out.
For what it is worth, Brett and a few others have been touting the Skyray / FP 20 as a super combo for some time. To put the ARF Flite-Streak in the same class is high praise indeed from a "top gun". I'd bet the farm he was on 60 X .015 lines, although he didn't say.
       Larry Fulwider
Offline Chucky
« Reply #4 on: January 12, 2010, 08:06:01 AM »
Wayne,
The LA-25 is WAY too much motor for a Flying Clown.  Brodak sells many models in the 400 sq in arena that this engine would work well on.  The Shark 402 would be a good candidate.  If you're intent on an ARF, get the Super Clown.  I fly mine on a mid-weight Brodak Flite Streak.  With an FP-20/25 NVA and silicon sealed metal backplate, my blue LA-S is a one-flip starter that rarely disappoints.
Chuck Winget
Alan Hahn
« Reply #5 on: January 12, 2010, 09:03:25 AM »
I didn't know there was a Flying Clown Arf (could be wrong).
« Reply #6 on: January 12, 2010, 10:29:15 AM »
     The lines were .015x62, as I recall. I didn't remeasure them. I know that in the past 58 was unnecessarily short. When it was set right, the lap times were about 4.8 seconds at the beginning down to about 4.6 at the end, running suction on a clunk tank. Fuel for a full pattern, 10/18 Powermaster (left over from the Team Trials) at about 50 degrees and 15 feet above sea level, was right around 2 oz.
   On the topic of the LA, I was primarily commenting on the remote needle. Despite the common wisdom, it seemed to work just fine straight out of the box. That doesn't necessarily mean that they are all good, but I don't see any reason it wouldn't work. It may have been harder to start, although I never found that to be the case with the 15FP or Fox remote needles. This particular LA *was* surprisingly hard to get to start, but it was also brand new, so I don't know if this is a function of the remote needle or not. The run was *dead steady* and very effective. Back to back with the 20FP, with relatively little fiddling, it was unclear to me if the 25 was going to be able to be adjusted to have that just perfect power variation that you can get with the FP and 40VF. The  first 4 runs on the 20 also weren't exactly right - I was chasing the needle as the day warmed dramatically and also as the old congealed oil and teaspoon of after-run cleared out of it. Only the last two flights were dead on as far as the needle goes. For the record, for mine, with a suction tank, with muffler pressure, and a clunk, it needed to be set just barely into the 2-stroke.
   When I did the extensive tests on the various .15-.28 scheurle engines available in 93/94, almost all of them were capable of giving excellent results and very steady runs - presuming you put on the correct prop and ran them as intended, i.e. in a two-stroke. The 20FP stood out in that with the right prop it would have that perfect amount of power increase in the maneuvers. The 25FP would do it about half the time, and the 20 was just about every time. Of course you had to hit the needle right, but other than that, it was time after time on engine after engine - at least 20 of them locally. All three of mine ran exactly the same to the point you could predict the rate of fuel consumption change as they broke in. I flew one of them brand new at a contest with no break-in and no test flights. Took it out of the box, hooked it up, fired it up, and flew an official flight for about a 520 - in a 15 MPH wind!  There's not a whole lot of engines I would have trusted to be that predictable.
    But a little lost in the endless 20FP discussion/argument was the second interesting finding from the experiment - that ALL of the engines I tried were quite satisfactory straight out of the box. As long as you didn't try to run them like a Fox 35. None needed any aftermarket modifications, Dremel tool "expert reworking for lucky best stunt run", nothing, including the stock mufflers. Get a 4" pitch prop of an appropriate, relatively small diameter, fire up, peak out, back off a bit to keep it from going over the top lean at the end, launch, stunt happiness ensues.
     The time has been ripe to re-run similar experiments with current engines with the same ground rules -  4" of pitch, ~11000 launch revs, 2-stroking in level flight, and a Flite Streak or Skyray 35. I am not going to do it, so someone else can take up the torch. If I had to ditch my 20FPs tomorrow, I would start with a 25LAS-RN.
Offline Hoss Cain
« Reply #7 on: January 12, 2010, 11:47:30 AM »
Thanks in part to my thoughtful and loving daughter, I ended up with a brand new OS .25 this Christmas.  It is an R/C version, but since I'll probably only be using it for sport flying for the time being, I'll probably just wire the throttle open for now. >>>>>>>.........//snip//
Wayne, you are using an RC engine with throttle wired into position. I say DO IT if you wish to. Once you get the hang of your engine and airplane, you can start reducing the throttle a little at a time. You can arrange the throttle wire back through a wheel collar or such and set it as YOU like.
Not only are you arranging for reduced engine output, but you will be getting better fuel-draw with the reduced throttle opening. After all, you are SPORT flying, Enjoy and have a ball.
It has been written: "Too much power is ALMOST enough and NOTHING beats CUBIC INCHES!"  %^@
Horrace Cain
AMA L-93 CD and Leader
Offline Rudy Taube
  • Ret Flyboy
« Reply #8 on: January 12, 2010, 11:52:53 AM »
Hi Wayne,
"What Brett said" :-)
I have an OS .25 in my Flightstreak (with the CL insert from Tower). It is perfect. I mount the RC style plastic tank on the inboard side (more room for it there). It is my last "wet" airplane, but I keep it for nostalgia reasons, (flew one as a kid ;-). The OS is a great engine, I use an electric starter and it starts up every time. :-)
The Super Clown ARF would also be great. Here are the links:
       http://www.brodak.com/shop_productdetail.php?ProductID=8095
OS insert:
       http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCW99&P=ML
I think wiring the RC TH open should work, but I don't know anyone who has done this for CL with this engine.
Have fun,  H^^
Rudy
AMA 1667
« Reply #9 on: January 12, 2010, 11:54:49 AM »
An OS 25 is OK for a Super Clown, the one with the flaps.
The usual failure mode for a Brodak ARF Super Clown is the flaps falling off.  So upgrade the hinge attachments.
Offline Chucky
« Reply #10 on: January 12, 2010, 12:40:05 PM »
I've flown three of the 25 LA-S on a Flite Streak, Ringmaster, and Buster over the past three years and pretty much agree with all of Brett's findings.
I use about the same lines as Brett: .015 x 60'.
I use home-built metal tanks that are copies of the Brodak 3 oz deep wedge.  They hold way too much fuel for a broken in engine, so I short tank 'em.
The box stock engine worked just fine and the RNV is fine if you don't do inverted landings.  I did a few learning to fly inverted with the Streak and busted the NV off, which is fragile and tore up the back plate as well.  Found the FP-20/25 NVA to be more tolerant of this type of flying with the added bonus, for me, of a cleaner engine cutoff than the RNV.  I don't like RNV's because engine cutoff is ragged with the tanks I like.  Have never run a clunk tank like Brett and Dan did, so this may be the critical difference.
Have had problems, over time, maintaining a good seal with the plastic backplates.  Have sealed 'em with high temp silicon but have to check the screws periodically because they seem to loosen over time.  If an engine starts running erratically, this is usually the cause.  Got an FP-20 backplate before Tower ran out of 'em which solved the problem on the Streak.  Am still running plastic on the other two, so clearly it's not that big of a deal.  When I ordered a couple of .15 LA's recently,  I got the .15 FP backplates and NVA's for 'em based on my experiences with the .25.
All of the 25 LA-S that I've used or seen at my club were hard to start when new.  Once started, they run fine, but be patient and have an electric starter handy for the first few runs.  They're easy to break in, but require it none-the-less.  All of mine how have at least a couple of gallons through them and are one-flip starters.
I launch at 10.8K with an APC 10x4 on the Streak and 11K with an APC 9x4 on the others.  Have started using a tach on everything based on experience with the LA's and are enjoying the flying a whole lot more.
Chuck Winget
Offline Russ Danneman
« Reply #11 on: January 12, 2010, 01:10:11 PM »
why we are on this subject, what size lines for a brodak p40/ la.46 would you guys recommend?thanks russ
FLY LOW FLY FAST  RISKY BUSINESS
« Reply #12 on: January 12, 2010, 01:22:38 PM »
For the 46-powered P40, I would use .018" x 60'.  Some will say .015", trading safety for increased performance.
.018 was the law of the land until this year, and downsizing to .015" will bring trouble to some.
« Last Edit: January 13, 2010, 06:23:28 AM by Paul Smith »
« Reply #13 on: January 12, 2010, 05:00:11 PM »
   I just double checked myself and realize that I committed an error in my first post.  I was thinking of the Super Clown (38" span) when I typed Flying Clown.
If I understand what I've read here, if I do go with the Super Clown, .015x60' should be a good starting point?
Offline Rudy Taube
  • Ret Flyboy
« Reply #14 on: January 12, 2010, 10:19:30 PM »
Wayne, ...... YES.  :-)
As mentioned, you will be much happier using any flap and EL hinges EXCEPT the CA hinges that come in most ARF/ARC componet kits. I like the Robart barrel hinges, but the pined hinges are very good too. The CA hinges are fine for most RC planes, but not for any CL planes.
Russ, ...... I use .015 x 62' on my Brodak P-40, over 350 flights (I do change my lines about every 200 flights just to be safe, I don't know if this is too cautious, or not cautious enough, but it makes me feel better and it has worked well so far. ;-)
Rudy
AMA 1667
« Reply #15 on: January 13, 2010, 12:19:56 AM »
  The R/C carb is  fine, no need for the C/L venturi unless you need absolutely perfect runs. On 4-strokes the carb seems to cause problems, with occasional little speed changes that are essentially beyond fixing without sleeving the throttle barrel or something like that. That goes back to the pioneering 4-stroke experience back in 1985, and was rediscovered in the more recent 4-stroke experiments. It's probably something leaking, or the barrel slightly shifting, but whatever it is, it seems to be exacerbated on 4-strokes. On 2-strokes it hasn't seemed to be nearly as noticeable and only occasionally in some situations can you even detect it.
    Then I suggest a Zalp 2.5 speed motor on a Lil Jumpin' Bean.  3 hp at 50,000 RPM on a 3/4 oz airplane, should be a killer. Too heavy? Then try a Cyclon 1CC.
    One of the absolute key findings of the little engine experiments was that it's extremely important to match the engine to the airplane. The intent was to replace a Fox on "35-sized" profile, but the nearest apparent equivalent was the 40FP. On Twister-sized airplanes it was notorious for screaming runaways to the point that an entire industry started to rework it. The problem was that if you cranked it up to where it liked to run (or it cranked itself up), it was tremendously too fast, even with 4" of pitch. If you tried to needle it down to a reasonable speed, say, 50%, it wouldn't stay there, or it was vastly too aggressive. The normal rework is designed to kill the power above about 11,000 rpm so it is manageable.
    After a bunch of examples that were staring us all in the face since the 70's, it finally dawned on me that there was a much better way to get an engine that ran at 50% of a 40FP - get one half the size! The 20 runs at about 90% to fly a Twister or Flite Streak, and at that setting it's quite happy and very stable. It can't run away since it's already close to peaked out. A stock 40 is on the wrong side of the power curve, the 20 is over there at the descending, stable side. It was really that simple. The LAs are a different kettle of fish - they roll off naturally at relatively low revs because they don't have boost ports. You need a bigger LA to get the same performance as an FP, but that actually works out perfectly for our purposes.
   Of course we are using huge engines on "real" stunters, but those generally have either tuned pipes, or are custom built to roll off at relatively low revs, so they are stable regardless of the size. Same with 4-strokes, those generally go over to the stable side of the hill at very low revs - maybe even too low. But they are certainly stable at stunt revs with 4" of pitch. We aren't getting any more power out of 75s than we used to out of 40s, but we are getting better run characteristics.
Quick guide -
15FP = perfect for Ringmaster
20FP = Perfect for Skyray 35, Flite Streak, light Twister/Banshee
25FP = Perfect for Twister/Banshee/Nobler
40FP = too big for any of the above unless you modify it somehow
« Reply #16 on: January 13, 2010, 12:26:06 AM »
   .018s are overkill, I think. It would be perfectly legal to fly it on .012s and that would probably be OK. .015s  have a very good margin of safety on these light little airplanes.
Online ray copeland
« Reply #17 on: January 13, 2010, 05:48:14 AM »
Wayne, i fly a Ringmaster, Flitestreak and a Magician with .25la. All had the r/c carb wired open with muffler pressure and 3 oz. Hayes clunk and they do great, no probs with the needle at all.
Russ, i fly my P40 on .015 x 61 and it does okay, maybe a little fast. Plan to try 63 ft. this spring.
Brett , i notice you didn't mention the FP35?
Offline Geoff Goodworth
« Reply #18 on: January 13, 2010, 11:15:34 PM »
To add to Brett's list, the FP 20, straight out of the box or with the well described Brett setup is excellent for the Brodak Shoestring. I'm using .012 x 60 ft lines.
Cheers, Geoff
« Reply #19 on: January 19, 2010, 10:40:00 PM »
Cheers, Geoff
Hi Geoff,
I bought into Brett's Fp 20 set up a long time ago. ;D  It is about the closest thing i have run to a PA on the pipe!  Or the Aero Tiger 36.......... It will fly all the *old* Fox 35 profiles unless they are really heavy dogs.
Mongo
