  • June 17, 2025, 07:49:06 PM
Author Topic: copper tubing  (Read 1163 times)
Offline Bootlegger
copper tubing
« on: July 16, 2016, 03:03:58 PM »
  Guy's I am needing some 1/8" x 12" copper tubing to build some fuel tanks.
 Where are you getting yours?
8th Air Force Veteran
Gil Causey
AMA# 6964
Online Robert Zambelli
Re: copper tubing
« Reply #1 on: July 16, 2016, 03:57:48 PM »
Brodak sell all sizes.
Be sure and anneal it before using.
Offline Garf
    • Hangar Flying
Re: copper tubing
« Reply #2 on: July 16, 2016, 04:06:20 PM »
Try auto shops. It is used for installing oil pressure gauges. Also at A/C shops and plumbing supplies.
Re: copper tubing
« Reply #3 on: July 16, 2016, 05:43:26 PM »
Any place that has a K&S rack will have copper tubing. Also annealed brass if you want that. Copper is available in 1/16",3/32", 1/8" and 5/32" I believe. All of the  mail order places stock and sell K&S products. My local True Value Hardware store even has a K&S rack. I always keep at least two or three packs if 1/8" on hand and use the copper in any Sullivan plastic tanks I use. Already annealed in the package also.
Online M Spencer
Re: copper tubing
« Reply #4 on: July 16, 2016, 09:54:57 PM »
Meant to get a roll of 1/8 from the builders supplies. they all had it. Held off. NOW THERES NONE . in Aus. boo hoo .
BEWARE = the Thick Wall  1/8 is ideal for   vent / uniflow pipes & bends good, but is o.k. for a G-15 or a .25 stunt, .
but marginal on a .35 and USELESS on a .40 up .
Leaned of above 45 Deg Up on the FSR Consitantly .
Dunno How it got in as a FEED PIPE , I mustve picked up tthe wrong tube doing the tank.
Advantage with the small bore on the vent is It Doesnt SURGE ( Pressure ) as bad , in rough air / Tight Corners .
