  • June 26, 2025, 06:08:01 AM
Author Topic: Fox 35 Stunt High Compression Head  (Read 4881 times)
Offline Bill Mohrbacher
« on: July 07, 2012, 01:31:24 PM »
Folks on the other forum were asking about this high compression head for a stunt 35.  I was talking to MArvin Denny and he hadn't ever seen one; hard to believe!!
So here it is Big Iron!
Sorry folks, I can't get my pictures to post; that's a first, too!
Big mystery, I'll have to try later - I can't even post pictures that I have posted with no trouble earlier!
Ok, sneaky work around.  MECA has started a new Bulletin Board - I've listed the pictures there:
http://modelenginecollectors.oli.us/index.php?topic=17.new#new
« Last Edit: July 07, 2012, 02:07:48 PM by Bill Mohrbacher »
Re: Fox 35 Stunt High Compression Head
« Reply #1 on: July 07, 2012, 01:42:16 PM »
"And behind door number 2 is?"  (no picture Doc! LL~ LL~ LL~ )
BIG Bear
RNMM/AMM
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #2 on: July 07, 2012, 03:43:29 PM »
I'm struggling to understand why anyone would want such a thing for a stunt Fox?  It's not like it's gonna outrun anything regardless.  Sort of like running a speed prop on it, with hi nitro.  What's the point?
--Ray
AMA902472
« Reply #3 on: July 07, 2012, 04:41:32 PM »
UHHHHH your mad at the crankshaft ??   ;D
Randy  LL~
« Reply #4 on: July 07, 2012, 05:04:21 PM »
Randy  LL~
   A crankshaft crossed him once. You can't let that stand unanswered.
Offline De Hill
« Reply #5 on: July 07, 2012, 06:12:07 PM »
You would do better asking what year it was produced.
De Hill
« Reply #6 on: July 07, 2012, 06:12:51 PM »
       And is that what makes one cranky!!???
   (Couldn't resist)
« Reply #7 on: July 07, 2012, 06:24:22 PM »
The fox .29 and .35 were used a lot in FF and that is the head that was used  for that event. The Fox worked well in FF models. Using a 10/4 and that head in a RamRod 750 was a good combination. The engine run was only 15 seconds.
Offline Frank Imbriaco
« Reply #8 on: February 20, 2016, 06:27:54 PM »
Anyone who has one gathering dust- PM me
« Reply #9 on: February 20, 2016, 09:12:33 PM »
I make them and they're stock appearing on the outside.  Never seen one from the factory.
Offline Bill Adair
  • AMA 182626
« Reply #10 on: February 20, 2016, 10:14:06 PM »
Those should be popular, with the folks who race Fox 35 engines now. How much MM?
« Reply #11 on: February 20, 2016, 11:02:54 PM »
$1,000,000.00
« Reply #12 on: February 20, 2016, 11:15:46 PM »
$1,000,000.00
I once flew a very nice Nobler of Don McClave's that had a Fox .35 running high RPM and low pitch...totally weird in the world of Foxes but by far the best flying Fox powered stunt ship I've ever flown.  Don't know if it had a high compression head on it but the earlier description from Eddy R. about Foxes in free flights with 10X4 props and hi comp heads makes my retired stunt guys mind ponder what was under the hood.
Ted
« Reply #13 on: February 21, 2016, 06:03:44 AM »
pictures that never were posted
« Reply #14 on: February 21, 2016, 06:44:10 AM »
That high compression head looks very much like the head from the 36X. I think they fit the 35S. Seems the approach would allow richer setting with lower nitro fuel.
Best,       DennisT
Offline dennis lipsett
« Reply #15 on: February 21, 2016, 06:47:58 AM »
Yes it looks just as crude as everything else on a Fox 35
Offline Garf
    • Hangar Flying
« Reply #16 on: February 21, 2016, 08:58:16 AM »
I believe it was intended to enable the Fox to be run on no nitro fuel.
Offline frank mccune
« Reply #17 on: February 22, 2016, 06:40:32 AM »
      Hi Bill:
      I have two of these HC heads.   Do they improve anything? I have never tached the engines with or without the heads.
      I talked to Duke many years ago about the No. 2 head and he told me that when  K&B came out with their.35, he designed the HC head to be able to compete with them.
      I use no nitro in my engines with the HC head and they run very well
     Will I see you at the Lebanon Flea Market?
        Be well m friend,
        Frank McCune
« Reply #18 on: February 22, 2016, 04:54:26 PM »
I'll be there.  Sorry you missed David's Collecto. We had a good time.  It was possibly the last one.  Poor attendance.
