  • July 18, 2025, 01:43:32 AM
Author Topic: Aldrich "pinched" Nobler Tank  (Read 1893 times)
Offline Herman Green
« on: September 14, 2006, 12:25:47 PM »
The question for anyone who may have powered an ARF Nobler with a Fox .35 and used the Aldrich design pinched corner tank provided in the kit.  Does it hold adequate fuel for the entire pattern?  I know it did when George used it, but does it still do it today?  Not sure if the tanks are exactly the same size as Georges.
Herman Green
Herman Green - 164164
Offline Greg L Bahrman
Re: Aldrich "pinched" Nobler Tank
« Reply #1 on: September 14, 2006, 01:12:52 PM »
Bummer, I'd like to run a 4 1/2 oz. in my ARF Nobler but it just won't fit. It needs to be about 1 3/4 wide.   :'(
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Roger Vizioli
  • CLiner
« Reply #2 on: September 14, 2006, 01:36:06 PM »
Hi Greg,
Saw your post!
Chk Brodak catalogue for actual tube positions -
4.5 oz. Brodak wedge tanks - 1 3/4" wide as follows:
         BH p/n - desc. - H x W x L
BH490 - All tubes fwd, uniflow  1 x 1 3/4 x 5 1/4
BH-483 - Med. wedge/uniflow -  1 x 1 3/4 x 5 1/4
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline James Lee
« Reply #3 on: September 14, 2006, 02:17:08 PM »
Herman
Yes, I've got an Aldrich piched type tank (uniflow) in my ARF Nobler with a Fox 35 Stunt.  I set the motor on 3/32 alum pads and was able to make the tank 1 3/16" thick and still center the NVA...   1 3/4 wide to fit the inside of the fuselage and as long as I could get it and still stuff it in there.  It turned out about 4 1/4 oz approx...   Will run a stock or semi stock Fox fine....  Problem is the Silver Foxx 35, which I would prefer to run is not a very fuel  efficient motor!  Power comes at a price....   But that tank runs out to the end VERY nicely.
Jim
« Reply #4 on: September 14, 2006, 02:59:31 PM »
Well, I was afraid the supplied tank looked a little small.  I'll check the Brodak tank and look into building one as well.  the .35 I'm planning to use on it has a .36 piston, sleeve and head.  It may be a little more thirsty in a 4-2-4 than the tank can bear.
I had built a couple of the Aldrich tanks in years past and seems as though I remember it held about 3-1/2 ounces.
Thank Guys,
Herman
« Reply #5 on: September 17, 2006, 07:22:44 PM »
Tom Morris sells a pre-plumbed uniflow clunk tank that fits into the ARF Nobler and holds a little over 4 oz.
Bill <><
« Reply #6 on: September 18, 2006, 08:05:51 AM »
I ordered a couple of the 1-3/4" wide 4-1/2 oz. tanks from Brodak.  When I get time, I'll try one of them.
Herman
