  • July 17, 2025, 05:54:50 PM
Author Topic: Alcohol proof glue  (Read 4360 times)
Offline charlie
Alcohol proof glue
« on: June 09, 2006, 05:43:10 AM »
I am looking for some glue that is totally impervious to alcohol and nitro fuels.  I know that epoxy is no good for immersion in glow fuel, but there must be some type of adhesive that is and can also be easily sourced.
Does anyone know of one?
Charlie
Charlie Stone  (The West Australian one)
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Alcohol proof glue
« Reply #1 on: June 09, 2006, 08:18:13 AM »
"GOOP All-purpose Contact Adhesive And Sealant".  I use it to build fuel tanks from plastic film cannisters.  I suspect "ShoeGoo" is the same stuff but can't be sure.
--Ray
--Ray
AMA902472
Offline charlie
« Reply #2 on: June 10, 2006, 04:19:20 AM »
Thanks for the reply Ray.  I have never heard of `Goop' down here, but will see if I can locate some.  Does it set up hard, or is it flexible when cured?  Do you know of any other brands?
Charlie
    • Minnesotamodeler
« Reply #3 on: June 10, 2006, 03:40:14 PM »
it sets up reasonably flexible, not brittle at all but not "soft" either.  I don't know of other brands...I've seen several variations for specialty uses (a la "Shoe Goo") and suspect they're all the same product, but not sure.  It's about the consistency of thick honey but can be thinned with, I think, acetone?  Larry Renger may know for sure.  I don't thin it.  It is extremely tenacious and inert stuff.
--Ray
--Ray
AMA902472
Offline Tom Perry
« Reply #4 on: June 11, 2006, 09:02:34 AM »
Charlie
I glued two popcicle sticks together with polyurathane glue (Gorilla) and soaked in a 20% ethanol, 80% nitro mix over night.  Did not get gummy and would not slide or break at the glue line.
Tight lines,
Tom Perry
 Norfolk, Virginia
