So, I thought I'd strip my old Chizler down, recover and refinish it (the covering was splitting all over and the finish always sucked) and maybe drop in a VF .25 mit pipe just to make Uncle Mikey Keville cringe at VSC next year. Alas, my attempts to strip the old HobbyPoxy yellow was a disaster. I got some stripper made for polyurethanes and epoxies and tried several coats on the fuse and tail. For some reason it worked fairly well on the tail (covered with carbon veil applied with plain old dope...the stripper didn't touch the dope!) but the fuse is just a disaster. It took it off in a handfull of places (left the Brodak fillercoat in place...weird again) but for the most part it didn't touch it. Can't think of any other method of getting it off, so I've given up.
Instead, I just ordered an RSM Chizler kit because I've always loved the way the old airplane flew although the Big Art Max .35S was sometimes a bit challenged in Arizona heat and altitude. In an attempt to solve that issue I rummaged through the cabinets in the garage and came up with a handful of ST .46s that feel awesome after freeing up the old oil they hey been stored with (the last time any of them would have been run was the late '80s. Used one in the airplane that won the '86 Nats and shortly thereafter switched over to pipes and never looked back...til now.)
One's pretty much stock, the second has a Vic Garner twin ring mod and the last one (the one I'll probably use) has the plasma piston and liner that a fellow down under made a batch of (sorry, so long ago I've forgotten the name but P.J. will remember). That engine feels absolutely incredible. The seal is so good that it is almost impossible to get the piston to stop at the top of the stroke. The only time I ever tried hard enough to get it to stop up there I left it for a week or more and when I touched the prop it popped over just like you had flipped it. Awesome. I don't recall ever running it either, this was straight out of the "factory" with some air tool oil in it. It should be very reliable.
At any rate, it's going to be fun getting back into the ST .46 game just for giggles and should make for a very macho Chizler. Hope I can crank up the enthusiasm enough to get the thing ready for VSC next March....Schedule it late, guys!
Just a status report. Anyone built one of Eric's Chizler kits? I made the Ruffy from one and it was terrific. Got my fingers crossed the Chizler will be just as good.
Ted
Oh. one terrific p.s. from my cabinet rummaging. I also found another .46 I'm unlikely ever to run that I'd all but forgotten. It's a GMA ABC conversion by George himself. Has his signature etched into the edge of one engine mount and my name etched on the other and the head is etched with--as I recall--GMA .46. Beautiful brass liner with chrome plating and a beautfully sealed aluminum piston. Maybe not quite as good a feel as the plasma fit but not much worse...very tight as befits the classic tapered honing of the liner.
Eat your hearts out guys. This one is a treasure!
