Russell,
Emphasizing what Dwayne suggested a few posts above...
The "1/2A" bellcranks, IMO, have been the curse of the small models! Not so much strength, but feel. They are too small to allow a reasonable handle line-spacing and easy wrist motion.
A 3" bellcrank is heavier than that plastic miniature, but not a lot. The greater throws for the line motion are much more comfortable to fly. Remember, tho, to get the same relationship between the bellcrank pushrod radius and the elevator control horn. Or at least set up the elevator horn so you have a hole each side of one that gives you about 30° each way.
If it's too touchy, move the pushrod out on the elevator horn to slow response. And, vice versa...
