  • June 27, 2025, 09:46:00 AM
Author Topic: Akromaster  (Read 4581 times)
Offline James Holford
Akromaster
« on: March 12, 2016, 08:43:58 PM »
Have not touched balsa in over 4 years...it's time to rekindle the fire!
 Got this kit at the Hobbytowne USA in Baton Rouge this past summer and finally caught the bug to build again... needless to say I'm not enjoying this particular kit but hey it could always be worse.
If in wrong forum I do apologize.
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re: Akromaster
« Reply #1 on: March 12, 2016, 09:18:52 PM »
1) Stack all the ribs up and match them for best fit. Mark with a Sharpie in the bottom of the top spar notches so you'll be able to tell at a glance that you haven't reversed some.
2) I'm not a fan of notching LE, TE or spars, and would likely take steps to mow off said notches. They're just stress risers, marking the places where they'll break in a rough landing.
3) If the Akromaster is like the Banshee, splice the spars, LE & TE together and make the wing as long as you can with what they give you. Make an extra few ribs if that's what it takes. It looks like you're going to build the wing in halves. Do not!
4) No, don't hinge the flaps and link them to the elevator.
5) Build light. Hold it very close to the sandpaper!
 y1 Steve
Offline Dane Martin
  • heli pilot BHOR
Re: Akromaster
« Reply #2 on: March 12, 2016, 09:41:46 PM »
What Steve is saying is correct, don't cut the leading edge or trailing edge logs. Leave them long. I ended up cutting out two more ribs and adding them into the ends. Right at the wing tip. The "added weight" is unnoticeable, and the added squares on the wing carry more weight any way. I've built three now. My latest is electric, it was a learning curve at first, but it is now great
Here's my wing, count the ribs, and notice the spacing. The instructions are a little weird on the spacing when splicing the logs together.
Re: Akromaster
« Reply #3 on: March 12, 2016, 10:03:43 PM »
  Construction of the Akromaster has been covered many times, so do a search on the model and read up on it. It's basically a good design and model. The already mentions adding two more ribs is a good idea, but not 100% necessary. Just make sure you get the leading and trailing edges put together straight, and with instant glue you can build the wing in your hands. The best improvement suggestion I could make is substitute the two inch bell crank for a three inch. This will slow the controls down and make them smoother. Build in a tip weight box on the under side of the out board wing also. Some guys put flaps on but it will fly just fine without them also. Just build it straight and square and that solves lots of problems before they start! Pick your poisen for power and watch the balance. Lines can be .012 or .015 in the 52 to 55 foot range.
   Good luck and have fun,
Re: Akromaster
« Reply #4 on: March 12, 2016, 10:06:01 PM »
Oh man I wish I'd had seen yall replies... I done chopped the logs.
Jamie Holford
Lafayette, La
AMA #1126767
Re:
« Reply #5 on: March 12, 2016, 10:07:56 PM »
I have a Enya IV .15 but it has a RC venturi on it.  It was my planned power.
Jamie Holford
Lafayette, La
AMA #1126767
Offline Terry Caron
Re: Akromaster
« Reply #6 on: March 12, 2016, 10:30:59 PM »
Randy Smith (see the Vendors Corner), for one, can supply a c/l venturi/NVA for your Enya (great engines!) but it'll do to wire/clamp/block open the throttle and try as-is.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline david beazley
Re: Akromaster
« Reply #7 on: March 13, 2016, 06:00:27 AM »
I had an Akromaster with the same engine on it.  Just wired the throttle open and flew it.  Great combination
AMA # 2817
Offline Carl Cisneros
Re: Akromaster
« Reply #8 on: March 13, 2016, 08:50:18 AM »
I did what Dane did to his wing as well. Mine has an Enya 19 V on it with CL ventury and flies great.
I fly mine on 58'  .012" lines and does what ever I ask it to do.
just my opinion, but you could carefully peg and glue the cut off portions back on, make the extra ribs and go from there.
Carl
Carl R Cisneros, Dist IV
Control Line RB
Re: Re: Akromaster
« Reply #9 on: March 13, 2016, 09:21:45 AM »
Carl
True. My only concern would it being a weak point in case of crash lol
Jamie Holford
Lafayette, La
AMA #1126767
Re: Akromaster
« Reply #10 on: March 13, 2016, 10:51:35 AM »
I have one my daughter built many years ago that was built box stock.  She put Monokote on and base coats of dope.  I sprayed the epoxy color on.  Power is a Cox Medallion .15.  I flies great in my opinion in that it got her to flying and doing loops.   It is a fun design and I don't think it was meant for all out stunt competition.
Offline Russell Shaffer
Re: Akromaster
« Reply #11 on: March 13, 2016, 11:57:00 AM »
Since the wing is already cut down I would just fly it that way.  It will be fine.  What I WOULD do is mount the landing gear wires solidly.  Don't use the rubber band shock absorbing system that the plans show.  On a hard landing, the wheels will swing back under the wing and break the lower wing spar.  If the gear is solid mounted you just bend it back straight and fly again.  I have had three Akromasters powered with an Enya 19, a Supertigre 15 and the last is electric.  Fun little airplanes.
Russell Shaffer
Klamath Falls, Oregon
Online Tim Wescott
Re: Akromaster
« Reply #12 on: March 13, 2016, 05:33:14 PM »
Yup -- if you've already cut the long wood down, just leave it as-is and complete the kit.
Offline Bill Johnson
Re: Re: Akromaster
« Reply #13 on: March 13, 2016, 06:55:53 PM »
I have 2 to build (and I just cleaned off the bench to start) so this is good timing. My club flies at a school parking lot, asphalt, so I don't have to worry about weak points in a crash. Just about every one of mine has been totaled.  n~
Best Regards,
AMA 350715
Offline Dane Martin
  • heli pilot BHOR
Re: Akromaster
« Reply #14 on: March 13, 2016, 07:04:24 PM »
My first one was built 100% box stock. With an OS15 LA. It was great! I wouldn't worry about adding if it's already cut. They've been proven to fly. Many many times... Lol
Re: Akromaster
« Reply #15 on: March 13, 2016, 09:35:42 PM »
 The Akromaster is a great little airplane, easy to build and fun to fly. "Back in the day" it was my first step up from 1/2A models, I still remember it seeming like a BIG model. I built, flew, and completely wore out two of them, each using the same Fox .19. Had a LOT of fun with those two models and I can't even imagine how many flights that old .19 had on it.
 I currently have one that I "kit-bashed" into a Cessna Agwagon...
Re:
« Reply #16 on: March 14, 2016, 03:59:00 PM »
Awesome! !
Jamie Holford
Lafayette, La
AMA #1126767
Re: Akromaster
« Reply #17 on: March 14, 2016, 07:37:27 PM »
   OOOOOOOOO I'm thinkin' 'Mini-Dusty!" Why didn't I think of that before! Did you drop the wing a bit and add the equivalent of dihedral? That's what I did on my larger Dusty and it worked out well. You do have a good eye and vision, Wayne! I was going to do a stock Akromaster  but can do a Mini-Duster at the same time. The Mini-Duster will get the stretched wing.
Re: Akromaster
« Reply #18 on: March 14, 2016, 09:33:55 PM »
« Last Edit: March 14, 2016, 09:50:42 PM by wwwarbird »
Offline Sean McEntee
Re: Akromaster
« Reply #19 on: March 15, 2016, 07:43:36 AM »
FYI:  I was looking the plans awhile back, and it is NOS 30 legal.   I wouldn't build one to take across the country to VSC or anything, but it would be a fun model to pull out and fly on occasion.
I think it would also do really well if the ribs were reengineered, similar to RSM Ringmaster kit.  Those "baseball bat" LE and TE pieces are heavy.  I just might work on that sometime....
Wayne:  I was 6 years old when I flew my first Akromaster, and compared to my Carl Goldberg Lil Wizard, it was HUGE!!!
