  • July 18, 2025, 10:02:30 AM
Author Topic: Airplane hauler newer minivan  (Read 9293 times)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« on: April 30, 2007, 06:17:02 PM »
Well it looks like I might soon be in position to be able to replace my poor old Dodge Caravan. It has 220k on the clock, the roof paint is gone, it rattles a bit but the Darn thing still doesn't use oil.. Anyway I want to replace it with another Minivan but not sure if I will go with Dodge or not. Won't buy new, maybe couple years old with less than 50K on the clock, will have about $10,000 to spend.
I have heard the Honda is the best of the minivans but the people selling them are pretty proud as the prices they are asking is crazy. Looks like Fords are the bottom feeders as far as used prices go with Chrysler T&C right under Honda and Dodge in the middle..
Anyway, if you have a minivan what are your likes/dislikes and would you buy another of the same make ????
Please don't try to sway me away from a minivan.. That is a whole other subject...
Offline Larry Price
Re: Airplane hauler newer minivan
« Reply #1 on: April 30, 2007, 07:07:38 PM »
Bob,
     We replaced my wifes Dodge Caravan at 100K with a new Toyota Sienna. Hands down a much better van then the Dodge.  H^^  Oh, and occasionally I get to borrow it for hauling duties...  #^
Larry Price
Edgewood, WA
« Reply #2 on: April 30, 2007, 07:26:03 PM »
My GF had a Sienna, great vehicle, not sure you can find one in the price range you are looking. best ride of any I have been in. Myself, I have an Astro, more room inside, rides decent, but man all that room inside is awesome. I can haul my planes, and sleep in the back! Sienna gets better mileage, I get around 20 mpg with the astro.
Offline Crist Rigotti
« Reply #3 on: April 30, 2007, 08:04:52 PM »
Honda Odyssey.  It handles like  dream.
« Reply #4 on: April 30, 2007, 08:20:21 PM »
Larry Renger asked approximately the same question a couple of years ago.  Here's an updated version of what I told him then after I bought a 2004 Odyssey:
Minivans are made with hauling kids in mind.  The Toyota is probably even more kid-oriented than the Honda.  To get the options I wanted in the Toyota, I'd have had to buy a lot of stuff for the nonexistant kids: side airbags in the back, for example.  The Honda has a rear air conditioning system, so I can keep the planes cool.  I got the Honda because Consumer Reports said that it's good and it meets the 4x8-sheet-of-plywood criterion.  I've had two Plymouth Voyagers before, and I like the Plymouths better.   The Honda is designed for people less than 5' 4" tall.  My main complaint about the Honda is that I can't put my leg in the requisite positions to accommodate my bad left knee.  I was pretty crippled after the 2004 Nats trip.   Since then I found a fancy foam pillow that holds my leg in an acceptable position.  I drove to Muncie and back three more times without ill effect.
Other things I like less about the 2004 Honda than the 1995 Plymouth:
The Honda has two electric side doors.  This is, I think, really silly, and it's dangerous.  My wife hit the button to open the left side door when we arrived for a coaching session in Salem.  The door crushed a stunt plane.  It takes far longer to open or close one of these doors than it takes to open or close the manual Plymouth door, and it is more difficult to do.  The remote device makes it worse.  It requires a certain button push sequence, and it still takes several attempts to open the door.  The door will work manually-- you can turn the power off-- but the motor spins and sounds unhappy.  Eventually, when I need to get inside the doors for something, I shall take the motors out, but I resent having paid for them.  The 1995 Plymouth has one side door, which is sufficient.
The Honda floor is not level.  It has lumps where the seats mount.  When the seats are out, if you put something just inside the door, it will fall out.
The rear seat on the Plymouth can be removed.  I removed it when I bought it, and it has been in the attic ever since.  It can be installed rapidly if I ever need it.  The Honda seat folds into the floor.  It looks like it can be unbolted to leave a nice well for fuel cans and toolboxes, but because the floor around the well is at different levels, and there is no floor behind the well, there is is no good way to mount a cover for the well.
The Plymouth, having no well for the rear seat, accommodates a full-size spare tire under the floor.  The Honda has a dinky temporary spare in a well behind the front passenger seat.  It would require some serious unloading of cargo if there were a flat on the way to a contest.
Both vans have electrically actuated rear windows, hinged at the front.  These provide nice ventilation.  The Honda's switches are on the driver's armrest, whereas the Plymouth's are overhead, and accessible to both people in the front seat and also the people (if any) on the second row.
The Honda 12V outlet is inconveniently located on the floor, and turns off when the ignition is off, making it difficult to charge batteries and requiring me to put my GPS on standby power whenever I stop the car.
The Honda dash has a hump in front of the driver, making it difficult to mount the GPS.
The Plymouth shifter has a detent at Drive, so you can shift into Drive without looking; the Honda does not.  You gotta check to see if you hit the right gear.  Sometimes I drive in third by mistake.
My Impact and canopy fit in the Plymouth.  I had to build a new plane holder to fit both the plane and canopy into the Honda. Both vans accommodate a 4 x 8 sheet of plywood, but above the floor the Honda is narrower than the Plymouth.
The Plymouth oil filter is accessible without putting the car on a lift.  I had to buy new, special ramps to raise the Honda to get at the oil filter.
The Plymouth oil drains without much mess.  Honda oil is very thin: 5W-something.  There is a lot of head on the oil pan.  When you remove the plug, which is on the aft end of the oil pan, the oil gushes aft.  When you remove the oil filter after having drained the pan, about a quart of oil gushes out onto the car structure.  There is no clear path for it to drain.
The Plymouth has a space between the front seats where one can put a basket to hold tapes, food, and other essentials.  The Honda has an obtrusive folding table that occupies as much space, but offers less storage.  Only when the table is up can a basket fit between the seats, but the table prevents basket access.
The Plymouth has reasonable armrests.  The inboard Honda armrests are dinky.  The outboard armrests do not go far enough aft, and are at a different height than the inboards.  You won't like it if your arms are the same length.
The Plymouth has a light under the hood.  Not so the Honda.
Chrysler allowed the Plymouth software guys to spend about the right amount of time thinking up the door lock logic.  The Honda guys had too much time and too little supervision.  The Honda doors, if unlocked by the remote device, relock themselves if you don't open the door immediately.  There is a sequence that sets off the alarm when you lock the doors and then open a door from the inside.  This resulted in our spending some time with a very nice police officer in Minneapolis on the way home from the Nats.  I imagine the Honda people as living in Tokyo and not having much experience operating automobiles.
The Plymouth's rear-window defroster shuts off after the condensation is gone.  The Honda's stays on.
The Honda's radio is inferior to that of the Plymouth.
The Honda's rear windows do not come down far enough to see the headlights of cars in the lane to the right at night.  Changing lanes is dangerous.
Rain pools on the side window such that you can't see the outside mirror well.   This is a problem in Seattle.
Things I like better about the Honda than the Plymouth:
The Honda has an annunciator that tells you when the cruise control is engaged.  So does our 1991 Accord.  I really like this.  The Honda cruise control works all the way down to 25 mph; the Plymouth's only goes to 30.
The Honda has a CD player; the Plymouth has a tape player.  There are some stereo system controls on the steering wheel.
The Honda's temperature control is better than the Plymouth's.  The Plymouth has a manual, mechanical slide temperature control.  The Honda has an electronic control that purports to be thermostatically controlled.  The setpoint and the stable temperature are different and have an unpredictable relationship, but it actually works pretty well.  It is not really automatic, but it is more stable than the Plymouth's system.
The Honda has an electrically adjustable seat, giving you a choice of many uncomfortable positions.  My wife likes it.
The Honda cupholders are better and more numerous.
The Honda glove compartment locks.  The Plymouth's doesn't, but the Plymouth has a lockable, unhandy drawer under the passenger's seat.  The Honda has a dinky drawer under the passenger's seat.  It has no detent in the open position.
The Honda has a second 12V outlet at the back of the cargo compartment.  The Toyota has three 12V outlets and optional 115V outlets, although probably much costlier than an inverter.
The Honda accelerates faster than the Plymouth.
The Honda second-row seat attachment seems more secure than the Plymouth's.
The Honda has side airbags.
The Plymouth's visor is not long enough to keep the sun out of your eyes when the sun is to the side of the car.  The Honda visor has an extension that solves this problem.
Features I wish the Honda had (and the 2005 does have, I think):
More driver legroom
Heated outside mirrors
Outside air temperature indicator
Offline Roger Vizioli
  • CLiner
« Reply #5 on: April 30, 2007, 08:53:42 PM »
Chev Astro or GMC Safari.
Used both types for K-9's and model planes for the past 20 years, no problems.
If they still made them (stopped in 2005) I'd buy another.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #6 on: April 30, 2007, 11:06:22 PM »
We have a Mercury Villager (a Nissan Quest with different badges). Don't buy one of these! Although the V6 engine runs like a Swiss watch, the rest of the van started falling apart at about 90,000 mi. It's not comfortable at all. Mileage sucks. Eats brake pads. A/C keeps leaking freon, plus the rear A/C makes some annoying clicking noise all the time. Visors won't stay tight and will bap you in the forehead if you accelerate to quickly. Stereo system is almost as good as the one installed in '62 Studebaker Larks. You need a knife to remove the CD cartrage. The transmission shift from 1-2 is about like a pro stock drag car, head snapping shift. Automatic doorlocks don't. Anti-lock brakes do.
 As I write this, the POS Merc is in the shop again for A/C repair.
Offline peabody
« Reply #7 on: May 01, 2007, 04:22:07 AM »
I'm a fan of the (now extinct) Astro......it has correct wheel drive.
That said, it's real tough to bail on a Chrysler van....they continue to blaze trails and raise the bar. Howard's analysis is good, but his examples are almost a decade apart....
In NYC, cab makes are controlled by the Taxi and Limo Commission. Currently allowed are: the Ford Crown Vic., the Toyota and the Honda, with some Ford Hybrid Explorers being used experimentally.....Large fleets must change cars every two years, small owners every three, I believe. The Ford is, far and away, the favorite.....
I recently bought a bus for hauling my demo equipment and am pondering a Subaru or, better, a Magnum as a driver"....but cooler heads will probably prevail and a Chrysler/Dodge van will more than likely be the choice....
Offline dennis lipsett
« Reply #8 on: May 01, 2007, 04:58:47 AM »
Had a 94 Dodge Caravan V-6 for 10 years. All was well for the first 5 then it was the van from hell. Everything started going on it. I had the transmission and the head gaskets go in the same week. I made it to 106,000 miles and the oil light wouldn't go out and it was taking a quart every 2 days. The air conditioner crapped out about 55k miles, the radiator needed to be replaced as it sprung a leak. The list goes on and on. Less you thiink otherwise I'm not hard on my vehicles and I had the oil changed every 3K and had the Tranny oil changed at the prescribed intervals also same for coolent.
To be frank the last 3 Chrysler vehicles I had were so bad I swore off American cars till they could demonstrate some real quality. Toyota still seems to be the nest bang for the buck.
Dennis
Offline Peter Nevai
    • C3EL
« Reply #9 on: May 01, 2007, 05:29:38 AM »
Why a mini van? Find yourself a 01- 02 land rover discovery. Note: they run forever but only come with a V8
Steve Kientz
« Reply #10 on: May 01, 2007, 05:45:17 AM »
the company I work for has a delivery system for our product(automotive heating and cooling).Our drivers average 1500 miles a week.We were using Astro vans but the reliability after 75000 wasn't there. We started using Caravans arond 2000,haven't had ANY issues other than typical maintenance(brakes ,oil changes).We had a Windstar but replaced steering components(3 times) in 2 years. So, even though I bleed FORD blue,I'd recommend the Caravan.
Offline Ralph Wenzel (d)
« Reply #11 on: May 01, 2007, 09:00:37 AM »
OK, Bob, I won't try to persuade you to buy other than another minivan, but I will mention an alternative approach.
When I decided to build something larger than a Cardinal, I also wanted the capability to carry several models simultaneously. I was (still am) driving a Nissan Pathfinder, which allows neither of these desires. My solution was to buy a small (8 x 10) trailer. It has a 2000# load capacity, although, model-wise, it'll never carry even a significant fraction of that weight.
Inside, I added a removable plane rack (made of PVC pipe) which will securely hold 6 largish planes. Trainers (U-Keys and such) are hung on the walls of the trailer. Field equipment goes in a "well" built from 3/4" plywood at the front of the box.
Total cost? Around $1800, including a spare tire. If I had it to do over again, I'd spring for the 2-axle trailer (another $500 - but 6x12). Not so much because of the size of the box, but I've learned that the single-axle trailer is a genuine, whirling SOB to back up! THe 2-axle trailers are much easier to control.
You, too, could follow this approach, and not have to bother reconfiguring the interior of the minivan each time you want to do a different task. Then you could also transport that 70" Plasma TV, the King-size bed, or a go-cart with very little bother.
Just a thought . . .
Ralph Wenzel
AMA 495785 League City, TX
« Reply #12 on: May 01, 2007, 09:37:55 AM »
Bob, its been quite a few years since I have had my little Chev 1/2 ton pickup with a cover.  I had been coast to coast, east to west, north to south.  The last four years no speedometer or cruise control.  We could get close to 20 mpg with three people and all the equipment.  Traded it for a Chev Astro.  It was good, but, I got stuck with the station wagon, a Ford.  Made several trips to VSC with the Astro hauling the wife, daughter, grandaughter and all the equipment needed.  I don't think it ever got over maybe 23 mpg.  After it started falling apart, side door fell off once, we traded it for the Suburban that made a couple of trips to VSC.  The 4 wheel drive got us thru the ice storm going to VSC one year.  Wife did not like the ride as it had heavy duty suspension.  12 sheets of cement board didn't even start to collapse the springs.  So we got the Chevy Venture and I fell in love with it.  It was as basic as I could get it.  Good gas mileage compared to the others.  A tank would get us from KC to Liberal Ks.  After 6 years the dealer made us a deal on the new Chevy Uplander for the Venture.  It is okay, but, is mucho different then the Venture.  Big enough tanks that we get close to 600 miles without stopping.  Handles good no matter the conditions.  The seats do not come out or fold down like the Venture.  But, all in all I wish I could have another Chevy 1/2 ton like I used to have.  DOC Holliday
Offline De Hill
« Reply #13 on: May 01, 2007, 09:52:44 AM »
Hi Bob,
Get a 2005 Dodge SXT or a Chrysler T&C. Make sure that you get the Stow and Go option; that is the greatest thing since sliced bread. Try to make sure that it is not an ex-rental car. Shop around; you can get one heck of a deal.
You will pay at least $6,000 dollars less for a 2005 Chrysler van than you would pay for a 2005 Honda or Toyota.
I doubt that you will pay $6000 dollars in repair bills on the Chrysler van during it's 200,000 mile  lifespan.
De Hill
Offline Bob Reeves
« Reply #14 on: May 01, 2007, 10:03:32 AM »
Thanks guys for all the replies.. All good points but a couple personal preferences..
The Chevy's drawback is that it's rear wheel drive, one thing I have learned to appreciate in the years driving the Dodge is front wheel drive is better when the roads are iced up. It does snow here and ice storms are fairly common.
Howard has convinced me the Honda (at any price) wouldn't work.
a trailer is completely out of the picture, I hate pulling the things mainly because when I am on a road trip I'm usually trucking along pretty good. Not unusual for me to run 85 to 90 for as long as I can get away with it.. Radar detector and CB listening to the truckers. No way could/would I do that pulling a trailer.
My Dodge is an 84 bought in 86 with 40K on the clock and it really has been good to me.. The transmission went out just under 200k, the paint went away couple years ago but other than that it hasn't had any major problems. In fact we are keeping it for a spare/work van.
Looking like I'll be searching for another Dodge, would like to have a 3.8 V6 but they are hard to find.. 3.3's which is what's in my 84 are everywhere.. Going to be a fun search, I hope...
De, doesn't the Grand Caravan and T&C have a longer wheel base than a standard Caravan? If so it would be a problem.. Although I am winding the business down I will still need to drive into a couple of amusement parks and sometimes tight quarters.
« Last Edit: May 01, 2007, 10:22:37 AM by Bob Reeves »
« Reply #15 on: May 01, 2007, 10:29:50 AM »
Just an fyi the Astro since I think 2001 comes only with AWD. and I have had two, no maintanance issues at all. smae drivtrain as all astros, s-10s and multitudes of others, flat floor, good visibility, plus, its a GUYS minivan lol, not a suburbanites wifey van
ok just kidding, its what I tell meself everytime I climb into MY minivan,,,,
Offline Dennis Moritz
« Reply #16 on: May 01, 2007, 10:41:09 AM »
As a sidebar to this discussion. Maybe relevant to one or two. My 96 Passat sedan stows three 40 sized stunt planes with the back seat folded flat. The trunk takes small notice of my Sears 3 draw tool box and my full size field box. Plenty of room for my clothes duffel, computer briefcase and a general carry stuff bag. The front seat is still free. If my wife ever stooped to do a contest with me, she'd sit there, plenty of room left in the trunk for her bag of clothes and books. 24 to 28 mpg on the open road with the V6 that revs like a motorcycle engine. I have made peace with this car that I still do not recognize in a parking lot. Having owned and driven American Iron for the last 30 years it has been wrenching and sad for me to give the VW it's due. I bought this appliance (it handles well when pushed hard, also, alas...) eight months ago and promptly racked up 15 thousand miles.
Offline Charlie Pate
« Reply #17 on: May 01, 2007, 11:46:58 AM »
A tip for all you Chrysler fans.
A race track, car inspector and friend of mine, was employed as a service adviser at a Cry/Ply agency.
He told me the v6 was tough enough! but advised changing anti freeze every two or three years as the cab over design made it run on the warm side and if you didn,t change anti freeze it could break down and cause the head gaskets to corrode and fail.(His words,not mine.)
I always change coolant every couple of years, so no problem.
As an aside, I have have to replace the A/C compressor and a front drive axle on my Voyger.
My boys Mother in law drives it to work every day. Only has 80 K on it but its 20 years old!
 The transmission people tell me they do a lot of Chrysler Vans:course I,ve known Ford  Super Duty 250 trans to fail
at 40k.Sometimes your foot has a lot to do with it. D>K
Offline Scott Hartford
« Reply #18 on: May 01, 2007, 12:06:34 PM »
I would have to say the Toyota Sienna is the highest quality (with the Honda nipping at its heels) of all the choices you listed. They cost more for a reason! But don't forget they retain more value when you go to sell them than the others by far. Think of it like this: The Toyota is a Saito or OS engine, while the Chrysler is a Fox. ( The Astro might as well be a Wen-Mac or Testors LL~) Some examples surely have their problems or great experiences, but when viewed as a whole, we start to see a trend! Consumer Reports has some pretty good info on this subject as does J.D. Powers and assoc. Toyota is the consistant quality king, and as a result, has just stepped into the #1 worldwide sales position without even really trying. The funny thing is many Toyotas contain more domesticly produced and assembled parts than, say, GM! HB~> Can you say "Hecho en Mexico!"  A good rule of thumb when purchasing ANY new (or newer) vehicle, is to imagine you have already owned this vehicle for 5 years and check Kelly Blue Book value on it. It will list original purchase price and current price and again we can start picking up on some trends here. So in summation, my choices would be first, Toyota, second, Honda, and third, nah....I'd take the bus! LL~
Offline De Hill
« Reply #19 on: May 01, 2007, 03:13:30 PM »
Scott,
I just sold my 1996 Town and Country minivan and bought a 2006 T&C.  Resale value doesn't matter if you plan to keep the van for 10 years or so. I didn't spend 6 grand on failed parts in my T&C either.
Consumer reports is very biased towards American vehicles that's why I dropped my subscription 20 years ago. I still read them every 6 months or so; they haven't changed.
Have you actually owned a Honda or Toyota minivan, or are you just quoting Consumers reports?
De Hill
Offline James Lee
« Reply #20 on: May 01, 2007, 03:27:49 PM »
Bob
To echo Doc Holliday's comments...  we had over 150K on the white Venture (1999) with no problems at all...   traded it for a 2006 Uplander (fleet vehicle no DVD player or power sliding doors!)...   Love the Uplander...Drives great and it hauls a bunch.  If I would maybe drive closer to the speed limit the mileage would be even better!!  So far its been to Fla and VSC without a hitch...
Later
Jim   ;D
Offline Bob Reeves
« Reply #21 on: May 01, 2007, 03:34:35 PM »
Just did a quick web search, wow! they are proud of the Toyota's also.. 06's are 6 to 8 thousand more than a comparable Dodge. Like De says resale value doesn't mean much if you are like me and drive em till they are all used up.
« Reply #22 on: May 01, 2007, 04:59:43 PM »
The point being, a Toyota isn't usually "used up" at the 10 year mark and still has an excellent resale value. Actually I do have a tad bit of experience with Toyotas of all flavors as well as most of the other makes as I am a Master Diagnostic Technician for Toyota by profession. Consumer Reports isn't "very biased against American vehicles", the fact of the matter is American vehicles have had some quality issues compared to Aisian and European marques and they are just echoing this fact.If you don't believe Consumer Reports, then just take a peek at the market! Once the cars are sold by Toyota, the pricing is out of their hands. If you see a used Toyota with a "proud" price, it is the "pride" of the owner who is selling it. And they are proud for a reason. ;D If the cars were "used up" or of poor quality they would not command the prices that they do. And if you ask me, resale value always matters! Unless you plan on scrapping the vehicle. Try this math: I bought a 1992 Toyota Pickup new for $8000. In 1 year it had APPRECIATED to $8500. 13 years and 187000 miles of troublefree driving later I sold it for $3900 in one day to the first person that came to see it. Ask anyone in the automotive business about Toyotas (or Hondas for that matter) reputation. We hold these truths to be self-evident..............
Offline De Hill
« Reply #23 on: May 01, 2007, 05:39:17 PM »
Scott,
I decided that you might be right, and logged into eBay to check prices on ended auctions for Toyota Sienna's and Dodge Grand Caravans. Here are some of the results.
1998 Sienna             $4,100
1998 Sienna             $4,050
1998 Sienna             $3,205
1996 Grand Caravan  $3,210
1996 Grand Caravan  $1,825
1997 Grand Caravan  $1,575
1997 Grand Caravan  $2,025
If the Toyota Sienna's hold their value so well, why aren't they bringing $6,000 to $8,000 more than they are? Equivalent new Toyota vans sell for $6 - 8 thousand more than the new Chrysler vans. I sure haven't spent that much on repair costs on mine.
Chrysler vans are the biggest bang for the buck.
De Hill
« Reply #24 on: May 01, 2007, 05:51:56 PM »
Your curiosity sparked my curiosity so I checked Kelley Blue book for 1998 models with 85000 miles, excellent condition, private party sales and the figures were: Sienna XLE- $8510, Dodge Grand Caravan ES- $5815. If you are looking best bang for the buck, as in no regard for resale, one owner, just need something to drive, etc...., the KIA Sedonia would be my choice for best bang for the buck. H^^ I wouldn't personally want one but it is cheap............... ::)
Offline De Hill
« Reply #25 on: May 01, 2007, 06:10:05 PM »
Scott,
Even with your Blue Book figures, The Toyota vans aren't holding their resale value that well. They should be worth $6 - 8 thousand dollars more then the Grand Caravans.
If you bought a Kia Sedona, you might have deep regrets.
De Hill
Offline Bob Reeves
« Reply #26 on: May 01, 2007, 07:27:25 PM »
Didn't check eBay I looked up dealer asking prices on 05's with under 50K and the Toyota's were significantly higher.. Not that thats necessarily a bad thing, Toyota's may be well worth it. If money wasn't an issue I would get a Hummer. Instead I have to settle for what I can afford and to me the Dodge seems to be middle of the pack winner. I would rather have a 2 year old Dodge with 30K miles than a 5 year old Toyota with 90K.
« Reply #27 on: May 01, 2007, 08:11:01 PM »
I wouldn't have a Hummer if I won it in a raffle! LL~ Reliability and graceful aging aren't their strong suit! %^@ The Caravan is by no means the bottom of the barrel, and is probably above average in most respects, but a Sienna is just a better built, longer wearing(without feeling worn) inside and out, higher quality car at an admittedly higher price. But that higher price is not just money tossed out the window. Remember, you would be driving this van for quite a while. If you enjoy it more than driving something else, that is a value worth some price. If it is worth the actual price is solely up to you to determine. Sort of like if you were hungry and you had to make a choice; Taco Bell, or a fine steak house. One could argue that Taco Bell was indeed a better value, but if you had to make that choice for 10 years, would you eat Taco Bell every night? And just so you know, if I was buying the van for myself(assuming I was going to buy a properly maintained van in good shape) I would definately take the Toyota with 90k over the Dodge with 30k.(or the Astro with 3k! LL~)But that's just me.......
« Reply #28 on: May 01, 2007, 09:07:51 PM »
I vote for the Dodge. I bought a new one in 99 that has 104,000 on it without a hitch. Also bought a new 2003 that has about 45,000 on it. I love them both as they are very comfortable, don't require much maint., and I do drive my vehicles till there is not much left so don't worry to much about resale.
Offline Bob Reeves
« Reply #29 on: May 02, 2007, 08:35:32 AM »
Hey Jim,
Wanna sell the 03  **)
« Reply #30 on: May 02, 2007, 08:59:01 AM »
Bob, I'd recommend going with a few year old Dodge or Chrysler.  Yes Toyota's and Honda's tend to have better reliability, but the Dodge's and Chryslers are so much cheaper the point is kind of moot.  If you get a Dodge, I'd highly recommend the double sliding doors, and the 3.8 l engine.  It holds up better than the 3.3 l. Get the highest trimline you can, it will be much quieter and better riding.  All the Dodge cars have had trouble with the 4 spd. automatic transmission for various reasons.  Get the tranny checked out thoroughly and plan on replacing all the fluid at least every other year.
The stow 'n go seating is for folks with grand kids primarily.  It's a waste for a plane hauler.  Get one with the regular click in seating(4 captains chairs and the bench seat).   Like Howard says, store the bench seat in the garage for emergency people hauling duties.
The AWD option really works well in wet, slippery weather.  The AWD's are also supposed to have excess problems, according to CU,  but changing the fluids routinely should help.
The Dodges in the last series, '98-2004, have really big interiors.  Plenty of room for a 60 in. plane behind the second row of seats, over 48 in. between the wheels.
« Reply #31 on: May 02, 2007, 11:30:24 AM »
You do realize that you will get extra appearance points when you take those fine planes out of a Toyota, right? LL~ H^^
Offline Peter Nevai
    • C3EL
« Reply #32 on: May 02, 2007, 05:00:13 PM »
One of the most useful sites when planning to buy a used car especially if you are not familiar with that models history. On this government web site you can search for all recalls, service bulletins, and complaints filed with the national highway transportation safety administration.
Searching through these databases can give you a good picture of what you can expect or look out for on every car sold in the US since I think 1972
http://www-odi.nhtsa.dot.gov/cars/problems/complain/
« Reply #33 on: May 02, 2007, 07:46:56 PM »
Good site. Our theoretical 1998 vehicles; Toyota Sienna and Dodge Caravan, scored as follows:  Total NTSB complaints: Toyota-303, Dodge- 758.  Total Safety recalls: Toyota-1, Dodge-10. D>K :!I think I see a trend! %^@
« Reply #34 on: May 02, 2007, 08:01:32 PM »
Moer good info:http://www.kbb.com/kbb/NewCars/Review.aspx?VehicleId=NS80LzIwMDd8MjM5MDU%3d&ManufacturerId=10&VehicleClass=NewCar&ModelId=75&YearId=2007    http://www.kbb.com/kbb/NewCars/Review.aspx?VehicleId=NS80LzIwMDd8ODMxMTc%3d&ManufacturerId=49&VehicleClass=NewCar&ModelId=299&YearId=2007
Offline lee_kirby
« Reply #35 on: May 02, 2007, 08:02:40 PM »
Bob"just my two cent's but having spent 9 yrs with a toyota, honda dealership,I can tell you that i have seen toyota's and honda's pushing 400K and still running strong body and drivetrain try to find a one owner or factory certified used vehicle.toyota and honda have a very strong pre certified checklist they go through.food for thought!I am not knocking american auto's here by no means just my experiance.Lee #^
« Reply #36 on: May 03, 2007, 09:15:35 PM »
To me, it makes the most sense to buy a Honda or Toyota if you're looking for a new vehicle, because they don't depreciate too fast. I've had a couple of Mazdas, and the last one was a sweetie ('81), until I got smashed in the rear end by a Ford. They depreciated pretty fast in those days, but I can't say about the new ones. Their van is kinda small, but it might be worth a look. I've never had much luck with automatics, and manual gearboxes are difficult to find these days. VW might have a stick shift mini-van...but you might also look for one of the Dodge/Daimler "UPS" vans...I forget what they're called, but will remember it as soon as I hit the 'post' button. Ugly danged thangs.  S?P Steve
« Reply #37 on: May 07, 2007, 01:51:07 PM »
Come on Christ, it is still a mini van!
Chris...
« Reply #38 on: May 07, 2007, 01:54:26 PM »
Chris...
Chris,
Do you own a 2007 Odyssey?
« Reply #39 on: May 07, 2007, 04:45:16 PM »
I have actually driven new Toyota and Honda minivans and they both handle rather well, minivan or not. Also the taller Dodge van is the Sprinter and has an enormous amount of room to go with its peculuar looks.
Offline Jim Pollock
« Reply #40 on: May 07, 2007, 06:23:06 PM »
Bob,
I used to have a 1996 Pontiac Trans Sport van.  The only complaint I have about it, was that it would cut
the edges off the tires quicker than a sedan would.  That could have been the tires I was using too.  Tires were
Firestones.
Jim Pollock  ::)
Offline Warren Wagner
  • Bradenton, FL
« Reply #41 on: May 08, 2007, 08:43:34 AM »
 Bob,
I have to put in my vote for my Chrysler Town & Country van.   It's a 2003 model with about 48,000 miles, and it's always been a pleasure to drive.   It is the Lxi model, so it's got a few nice features like leather seats, lumbar adjustable support for the driver, and 6 CD changer ( which helps immensely on those long trips).   It has a very comfortable ride, and a surprisingly short turning radius that make maneuvering (see how cleverly I snuck that term in) in tight places very easy.
Bottom line.....I like it well enough to buy another.
Cheers.
Warren
Warren Wagner
AMA 1385
« Reply #42 on: May 08, 2007, 07:34:04 PM »
But remember, the best you've driven is the best you know. Have you driven them all? :! Might be a surprise.....
Offline Bob Reeves
« Reply #43 on: May 09, 2007, 07:29:50 AM »
Was hoping the deal that is going to generate the 10 grand would come together in time for me to have the new van to drive to Brodaks but it's looking like I won't have my hands on the funds till a week before >:(
Unless I just get lucky don't feel I will have enough time to find that special deal I'll be searching for. Guess I could head out in the old van with 10 grand in cash.. If it dies, leave it and hope to find something close to where it dies  ~>
« Reply #44 on: May 09, 2007, 09:37:13 AM »
Hey I remember the VanSants of speed and racing fame doing just that going to one Nationals.  Seems the engine went capoot and while mechanic was working on it. Senior traded it for a brand new one.  Been quite a few years ago.  DOC Holliday
Offline Bob Reeves
« Reply #45 on: May 09, 2007, 09:57:22 AM »
Almost did that exact thing once, was driving to Chicago to put a system in Great America and just outside Lbanon MO had a rocker arm break. Limped into a Dodge dealer right on the highway, would have traded on the spot but the dealer wouldn't come to my terms. Ended up renting a car, let the dealer fix the van and picked it up on the way back home.
