  • June 18, 2025, 03:43:09 PM
Author Topic: Aluminium or Carbon profile landing gear  (Read 1576 times)
Offline Stephen
  • Stephen Hollier 217629
« on: November 14, 2020, 11:12:38 AM »
Any suggestions on were I can purchase profile landing gear? Aluminium  or Carbon...
Offline Steve_Pollock
Re: Aluminium or Carbon profile landing gear
« Reply #1 on: November 15, 2020, 12:11:44 PM »
Check out Steve Wilk's "Eliminator Prop" listing down in the Vendor's section.  He makes carbon LG as well as carbon props.
Offline Brent Williams
« Reply #2 on: November 15, 2020, 12:26:10 PM »
Offline Stephen
« Reply #3 on: November 15, 2020, 07:47:38 PM »
The hobbyking landing gear is awesome but none in stock.
« Reply #4 on: November 15, 2020, 07:55:28 PM »
You might put a want ad in the classifieds section on this site.  Most control line guys are hoarders, so you might just get lucky!
Offline Craig Beswick
« Reply #5 on: November 15, 2020, 08:25:02 PM »
If this is the sort of thing you are after go to ebay and type in.
"Airplane carbon fibre landing gear".
You have to surf through the one piece but there are heaps.
AUS 87123
"The Ninja"
Offline Stephen
« Reply #6 on: November 16, 2020, 09:01:38 AM »
Thanks for the help guys !
Online Jim Hoffman
« Reply #7 on: November 16, 2020, 09:39:25 AM »
Steve Wilk of Eliminator is a consistent donor to our contests.  His products are excellent. I strongly recommend him
« Reply #8 on: November 16, 2020, 01:48:54 PM »
I make my own.  ;D
« Reply #9 on: November 16, 2020, 05:42:22 PM »
Brodak and SIG sell aluminum profile LG (pairs). I like the one for the SIG Fazer, with the legs narrowed and bends tweeked a bit. I believe one of the sets Brodak offers is the SIG Fazer LG. SIG also sells flat blanks that you can start with.
It appears that all model aviation aluminum LG's are 6061T6...maybe not optimal but works fine, and no need for annealing, bending & re-heat treating which would be needed for more serious alloys of aluminum....IF you radius the bends decently (say 3x thickness).
I'm not a sheet metal guy or engineer, and I've used both aluminum and CF LG's, but IMO, CF LG's seem to be too stiff and tend to bounce...and bounce...and bounce. Anyway, I prefer the aluminum LG as more forgiving, and suggest avoiding all the usual axles that the R/C bods use, 'cause they're really way too heavy for our use.   y1 Steve
