  • July 18, 2025, 02:02:49 AM
Author Topic: Flute streak  (Read 1002 times)
Offline sadams714441
Flute streak
« on: April 09, 2015, 06:00:08 AM »
I have a flight streak trainer that I have had for years.  Decided to put together.  What line length do you guys suggest.  And should I use the solid lead outs they supply with kit. Or could I use braided ones instead
Steve Adams
Offline Phil Krankowski
Re: Flute streak
« Reply #1 on: April 09, 2015, 07:02:34 AM »
Solid leads are good, however they tend to catch, bend, and cause problems from this later while cable leads are flexible and tend to not catch or kink as easily.  I would say cable lead outs are better.
If you put a .15 on it it might like 50 ft lines better, with a .25 it might like 60 ft lines better.
Phil
Re: Flute streak
« Reply #2 on: April 09, 2015, 07:22:13 AM »
I had Streak Trainer with a plain bearing 35 and 60' lines.  It flew a lot better than you would think with the solid flat bottom wing.  I could get it inverted and do outside loops and lazy eights.
Offline Larry Borden
Re: Flute streak
« Reply #3 on: April 09, 2015, 09:24:17 AM »
I'm using the trainer to teach my wife to fly. OS 25FP on 52 .015 lines. Solid lead outs, no problem.
Re: Flute streak
« Reply #4 on: April 09, 2015, 09:31:57 AM »
I run an LA 25 or a full sized Flight Streak, and it flies just fine!
Solid leadouts on your Flute Streak will be fine.  50 feet with a 15 should be fine.
You'll be able to play a tune on it.
