  • July 12, 2025, 06:13:50 PM
Author Topic: Aeropoxy Light  (Read 3615 times)
Offline Crist Rigotti
Aeropoxy Light
« on: November 07, 2012, 04:41:28 PM »
My Aeropoxy Light filleting material finally went bad after 6 years.  I went online and PTM (the manufacturer) sells it for $28.90 for 1.47 QT. plus $8 shipping.  I bought another QT size.  $36.90 delivered to the door, not bad.
http://store.ptm-w.com/c-2-aeropoxy.aspx
This post is intended for those who want to use the stuff but don't want to pay $18 + shipping for a small jar of the stuff and not intended to start a debate about other fillers, etc.  This is just some info in case anybody wants to buy the stuff.
Offline Bob Hudak
Re: Aeropoxy Light
« Reply #1 on: November 07, 2012, 07:55:46 PM »
Crist,
 The link came up with a large variety to choose from. Could you provide the sku # of the one you find working for you ?
                                                     Thanks,  Bob
350838
Re: Aeropoxy Light
« Reply #2 on: November 07, 2012, 08:02:13 PM »
Bob,
AEROPOXY LIGHT LIGHTWEIGHT FILLER: Qt. Kit
SKU:WAPLTE - Net Wt: 1.5 lb. Net Vol: 1.47 Qt.
Price: $28.90
Quantity:
Re: Aeropoxy Light
« Reply #3 on: November 07, 2012, 08:09:47 PM »
Bob,
Price: $28.90
Quantity:
   That's the stuff!
Re: Aeropoxy Light
« Reply #4 on: November 07, 2012, 08:12:35 PM »
I'll stick with SuperFil. Thanks.
Offline Gene O'Keefe
Re: Aeropoxy Light
« Reply #5 on: November 08, 2012, 07:25:59 AM »
Thanks for the info, Crist.
Gene O'Keefe
AMA 28386
Offline RC Storick
Re: Aeropoxy Light
« Reply #6 on: November 08, 2012, 07:37:51 AM »
Super fill is by far the best I have ever found. Light and easy sanding. Like butter.
Re: Aeropoxy Light
« Reply #7 on: November 08, 2012, 11:27:18 AM »
  Super Fil sands a lot easier than AeroPoxy, and it works better as a filler. For fillets I use AeroPoxy because it's much tougher. Particularly on the tail, it spreads the load to the fuse sides much better and results in a much stiffer attachment. It's just enough easier to sand than Epoxolite than you can touch it up slightly if necessary.
   Back in the ST46 days one of the tricks was to use Epoxolite fillets around the wing on the inside AND outside to keep the front end attached and stiff. That's arguably not necessary for TP motors, but we have certainly found that sometimes you still have issues with engine runs from vibration on the bigger engines. The airplanes will stay together and not have much problem with stress cracking but the engine run can be affected. One of the reasons I think I have more consistent runs than most people is that I still build the front ends about as stiff as I used to. Not to the Big Jim ST60 degree but aside from the internal fillets no changes.
Re: Aeropoxy Light
« Reply #8 on: November 08, 2012, 11:58:48 AM »
Thank you Brett.  That is exactly why I use Aeropoxy Light, for its structrual properties.
Online Howard Rush
Re: Aeropoxy Light
« Reply #9 on: November 08, 2012, 12:25:20 PM »
Now you tell me.
Re: Aeropoxy Light
« Reply #10 on: November 08, 2012, 01:02:05 PM »
Now you tell me.
   You solved that problem a different way, did you not?
Eric Viglione
Re: Aeropoxy Light
« Reply #11 on: November 08, 2012, 01:29:10 PM »
Brett - Guess I'm still old school... interior fillets wise anyways. Using a monojet syringe really helps... you can make them very small and precise. Coming from ST60's and 46's, it took a while for Randy to beat me about the head and ears until I stopped using 1/2x1/2 motor mounts and 6/32's... LOL!
As to superfil vs/aeropoxy, I'll suggest a counter point or two for your consideration. Superfil is extremely ridged, and much lighter than Aeropoxy. I have been using it for years, since I stopped using Aeropoxy, and have yet to have a fillet crack or pull away, even post-mortem after a fatal crash. Not sure if the added strength is needed? So, if you can do a fillet nearly twice the size thats just as light and easier to sand, wouldn't that spread the load better? Plus, one major drawback I see with some uses is that when the fillet is hard to sand on a foam wing, some people have been known to sand into the sheeting and that's right where the wing is going to fold like a cheap tent. With Superfil, a finger whetted with alcohol slipped over the fillet at about half cure time almost eliminates the need for any sanding at all...
I'm genuinely interested in your thoughts on this, since I was pretty sure I was on the right track, you have me wondering what aspect I might have missed?
EricV
Re: Aeropoxy Light
« Reply #12 on: November 08, 2012, 05:48:53 PM »
I smooth my Aeropoxy fillets with a finger dipped in rubbing alcohol after they've been on the airplane after about an hour.  The Aeropoxy has set up enough to allow the smoothing and feathering.
« Last Edit: April 30, 2014, 05:59:33 PM by Crist Rigotti »
