  • July 01, 2025, 04:40:12 PM
Author Topic: Just to whet your appetite  (Read 5044 times)
Mike Griffin
« on: February 24, 2012, 09:44:03 AM »
Just wanted to give you a sneak peek of the future kits i have lined up for this coming year at this time.  I will be posting specs/details in Vendors Corner and on my Wings On Strings website very soon.
The top two are pictures of Allan Brickhaus's Scepter
The bottom picture is a Spinks Akromaster.
All wings are built up wings...not foam.
« Last Edit: February 25, 2012, 01:20:26 PM by Mike Griffin »
Re: Just to whet your appetite
« Reply #1 on: February 24, 2012, 10:10:10 AM »
Jim should take a close look at the alignment of the stab.
Offline W.D. Roland
« Reply #2 on: February 24, 2012, 10:56:29 AM »
Nice Mike!
Wondering if you know what % of wing area the Stab/elevator area is on the Scepter
David Roland
51336
« Reply #3 on: February 24, 2012, 11:32:43 AM »
Mike,
You're doing good things! Kudos!!
Hey! I see you offer Wing Kits, correct? Or at least Rib Sets, correct?
Might be a good idea to list the measurements of the completed wing? I don't know the models.  n~
Having measurements would help those that may need a wing for their own design. With changes.
Span, root cord, tip cord, airfoil thickness and LE setback is all you need.
I'll need a wing soon for a project. I hate building wings.
Charles
Mike Griffin
« Reply #4 on: February 24, 2012, 11:45:15 AM »
Nice Mike!
Allen is in the process of sending me all the data and specs on it...will get it posted as soon as I get them.  Good looking plane and Allen says the numbers on it are good.
Mike Griffin
« Reply #5 on: February 24, 2012, 11:50:26 AM »
Mike,
Hi Charles
On my website - www.wingsonstrings.com - I have Specification page for every model I list on the website that gives you the span, area and length of the model as well as the power ranges.  I do not list the root chord, tip chord and airfoil thicknesses because there are so many kits available.  It is mostly a time consumption problem.  Perhaps if you could tell me what you want then maybe I could get the information for you....
Charles
« Reply #6 on: February 24, 2012, 02:47:47 PM »
The Scepter is kinda close to The Brodak Legacy,(which is a modified Genesis).
Mike Griffin
« Reply #7 on: February 24, 2012, 03:07:16 PM »
Here is another one of Allen Brickhaus's designs I will be adding to future kits.  THE PIRATA.
Notice the dotted line on the rudder in the plans picture .. the rudder will be reduced in size to that dotted line.
Mike Griffin
« Reply #8 on: February 24, 2012, 03:22:12 PM »
Here are some specs you will be wanting on the future kits
SCEPTOR - Precision aerobatic stunter
Span - 59 7/8"
Wing Area - 675 Sq In
Nose Moment' - 10"
Tail Moment - 16.5"
Stab/Elevator - 23.5% of wing and flap area - 150 Sq In stab and elevator
flying weight - 59.5"
Power - 40 - 75 Piped - Evolution .61 non piped
It is NOT classic or Nostalgia 30 legal -
_____________________________________________________________________________________________________________
PIRATA - see picture of line drawing above.  all specs are there
Pollock SPINKS AKROMASTER
Span - 52"
Area - 550 Sq In
Nose Moment - 8 1/2"
Tail Moment - 14 3/4"
Online John Miller
« Reply #9 on: February 24, 2012, 03:35:05 PM »
The Legacy is definitely not a modified Genesis, rather, it's based on the larger Buccaneer, and incorporating changes in airfoil, percentages, and moments.
« Reply #10 on: February 24, 2012, 04:10:07 PM »
Gonna ask Allen on that one.
« Reply #11 on: February 24, 2012, 07:19:14 PM »
If there's a waiting list for the Scepter, I want to be on it. #^
Offline W.D. Roland
« Reply #12 on: February 24, 2012, 08:33:18 PM »
Thanks Mike! H^^
David Roland
51336
Mike Griffin
« Reply #13 on: February 24, 2012, 10:05:31 PM »
Hi Clint
I have you on the waiting list for the Scepter.  Thank you.  I will keep you informed of the progress.
Mike Griffin
« Reply #14 on: February 24, 2012, 10:06:12 PM »
« Reply #15 on: February 24, 2012, 11:09:12 PM »
I agree with Randy -
Check the Stab alignment - its WAY OUT.
My eyeball estimate is : Its over 2 " out...
Mike Griffin
« Reply #16 on: February 25, 2012, 11:18:36 AM »
OK.. thanks guys...I will take the picture off and get in touch with Tom Morris..he is actually building this//
« Reply #17 on: February 25, 2012, 03:18:46 PM »
Might possibly be distortion from the camera lens length...a wide angle lens can do some strange stuff.  H^^ Steve
