The FX46 looks very much like the OS AX46II but of course, is discontinued. The FX is probably the forerunner of the AX series engines. Parts are discontinued but appear to be available in limited quantities on E-Bay.
The 46AXII can be used as a Control Line Stunt engine by just providing it with a venturi and needle valve assembly. Mine uses a Venturi provided by Jim Lee with a .270 diameter opening and a Randy Aero needle assembly. I would guess that the FX is similar and would work approximately the same, but it's only a guess. Should be worth trying it!
