  • July 17, 2025, 11:46:27 PM
Author Topic: Advertised Fuel Tank Volume  (Read 1609 times)
Offline Larry Fulwider
« on: April 21, 2010, 11:27:23 AM »
Do you check the volumes of tanks vs the advertised volume? It would be interesting if you could post what you have found from different suppliers and / or the same supplier with different sizes and shapes.
   The most inaccurate advertised volume I have found is the Great Planes Viper 500 which comes with the Top Flite ARF Nobler. Embossed as  180 cc (and advertised as 6 oz) it is only 132 ml, or 4.5 oz.  :o
Here is a somewhat random list of some tanks I’ve checked. (Not saying how the ones I’ve built came out compared to the plans!)
Viper 500 6 oz  4.5 oz
Du-Bro 406 6oz  6.0 oz
Brodak BH-489 Med Wedge ATF 4 oz  3.9 oz
Brodak BH-593 Profile 4.5 oz  4.3 oz
Methodology used: Each tank was filled, then fuel withdrawn through normal pickup with 2 oz syringe (and short 1” fuel line) calibrated in cc; syringe volumes withdrawn, noted and totaled. Results converted to ounces, and rounded to nearest .1 oz. Pessimestic estimated accuracy within 3 ml per tank.
    The clunk tanks had all internal plumbing in place, including uniflow tube, with overflow in max fill position.
   Larry Fulwider
Re: Advertised Fuel Tank Volume
« Reply #1 on: April 21, 2010, 11:40:17 AM »
Probably, when a tank is designed, volume in ounces is converted to cubic inches, and then the plug (in my case) or the bending template is made.  Actual volume might be a little less than calculated because (1) the overflow tube position leaves a little bit of air volume (2) the tubing displaces a small bit of volume.
It is normal to select a tank larger than necessary, and then measure the fuel load after several flights determine the correct amount.
Is that what everyone else does?
Floyd in OR
(driving directions to OR:  "Follow the cloud".)
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: April 21, 2010, 12:28:48 PM »
Sullivan 4 ounce slant = 3.75 ounces
Dubro 4 ounce all tubes forward 4.25 ounces
Offline Jim Thomerson
« Reply #3 on: April 21, 2010, 12:30:30 PM »
Perfect marketed two different size 3/4 oz long wedge tanks.   HB~>
Offline ray copeland
« Reply #4 on: April 21, 2010, 05:56:36 PM »
Agree , agree!!  I use quite a few of the Hayes plastic clunkers, 3,4, and 6 oz. They all hold quite a bit less than stated!!
« Reply #5 on: April 21, 2010, 08:02:40 PM »
Ray --
Hey, I think those old clapped-out McCoys just use more fuel than you want to admit  ::)
Interesting! The Du-Bro holds more than advertised? I think I have one, I'll check it also.
        Larry Fulwider
« Reply #6 on: April 21, 2010, 11:22:29 PM »
yes the Dubro does, I tworks out perfectly in a Viper Pylon racer, just enough fuel for a comfort margin when racing. also worked well in My Oriental, fits well, and just the right amount of fuel for my LA 46
Offline Bob Reeves
« Reply #7 on: April 22, 2010, 12:15:02 PM »
        Larry Fulwider
The way I checked was to prop the tanks up with opening at the highest point, no plumbing. Filled them up and then sucked them dry with a syringe. What prompted it was I had a 4 ounce Sullivan in my Saito 62 powered stunt ship and it wasn't running as long as the 4 ounce Dubro in my old Score. Wasn't sure if it was the engine or tank. 1/2 ounce difference between the two told the story..
