  • July 21, 2025, 05:55:16 PM
Author Topic: Adjustable Leadout Guide-Aldrich Nobler  (Read 2086 times)
Offline Garf
    • Hangar Flying
« on: June 09, 2011, 06:12:01 PM »
I want to add an adjustable leadout guide to my next Aldrich Nobler or maybe a NoblARF. Would I lose a significant amount of area by going to a plate or block tip? I suppose it would be possible to extend the wing by a bay on both sides to compensate.
Offline Mike Keville
Re: Adjustable Leadout Guide-Aldrich Nobler
« Reply #1 on: June 09, 2011, 06:23:50 PM »
See Bob Hunt's photo-equipped article on "Slot and Adjustable Leadout Guide", May-June issue of Stunt News, pp. 54-58.
« Reply #2 on: June 09, 2011, 06:46:30 PM »
Ive built and flown countless Noblers - there is no need to alter the plan of the tip template to accommodate a slot brodak style adjustable leadout guide. It needs to be run further inside the wing, before the outter tip itself rougly 1 1/2 inches inside the wing - adjustable with a 2/56 nut and socket .
Offline Jim Thomerson
« Reply #3 on: June 09, 2011, 07:57:12 PM »
You want the leadout guide as near the tip as practical.  I think I could figure out how to get one right out on the tip.  I've seen photos somewhere of one incorporated into a tip similar to the Nobler's.   I have put them in a tip rib and build a rectangular channel out in the tip for tips similar to the Nobler's.  It looked pretty good and did not need much figuring out.
« Reply #4 on: June 09, 2011, 08:03:50 PM »
The difference between on the tip itself - and on the outter most tip rib bay would be negligable. Esp in a Nobler.
Offline Garf
    • Hangar Flying
« Reply #5 on: June 10, 2011, 03:27:21 PM »
This is precisely what I am trying to avoid. I have 2 planes that have adjustable guides mounted on the tip rib and deep slots to the end of the tip. I hate them both. I store my planes by hanging from the leadouts, and it is difficult to impossible to hook the leadouts over the hanging post with the guide so far from the exit at the tip. I want to go to plate or block type tips. As a bonus, they are easier to cover.
« Reply #6 on: June 11, 2011, 08:19:12 AM »
If you want the adkjustable guide close to the tip, how about right at the tip.   A peice of hardwood cut to the shape of the tip.  A series of holes drilled to a press fit of Tom Morries 1/8 eyelets.  Then a slot is cut between the holes for the leadouts to move thru.  Once the final/optimal adjustment is made, a dab of glue will hold them in place permanenly.   I would do a search for you on lead out guides, but I am being extremely lazy this AM.  H^^
